Question about Buckner Garden
Where can I get the manual for Buckner Mt 12 34212 sprinkler system?
    Top Expert:
  • Buckner Master
  • 54,386 Answers
Google (buckner)(mt1234212)(manual) without parens Or contact Buckner directly to request it.
Posted on Oct 13, 2019
  • Buckner Master
  • 10,438 Answers
2 Suggested Answers
6ya staff
SOURCE:
josh1111
  • 398 Answers
SOURCE: Need the instruction manual for a Buckner Model MT8/32008
send me a pic of it ill figure it out quickly and explain it to you. i know irrigation like the back of my hand;) joshuad03@hotamil.com
Posted on Nov 07, 2009
System quit watering. Tried man/adv and won't energize sprinkler valves. I can operate sprinkler valves manually. Tried unplugging power source to reset. Any suggestions?
Most sprinkler valves run on electricity from the timer. If the time doesn't send electricity out, the valves don't open. If an animal has chewed through a wire, that valve won't open.
You can take a meter and check the voltage on the wire at the timer. If nothing, replace timer.
If you get correct voltage at timer, measure at valve. if voltage good there, replace valve.
May 31, 2015 | Rainbird Rain Bird Esp-6tm Sprinkler Timer
What is half way point from cassville mo to buckner mo
Looks like Nevada, MO if you take I-49.
Nov 30, 2014 | Cell Phones
Orbit sprinkler timer manual
Contact the manufacturer. They usually will have the manual online for downloading.
Jul 30, 2014 | Orbit Irrigation 57856 6-Station Easy Dial...
Is there a manual for the orbit h2o-6 gear drive sprinkler on tripod?
Jul 24, 2014 | Orbit 58565N H2O-6 Gear Drive Sprinkler
Rainbird sprinkler manuals
Normally, when there is a battery for an item that has a cord that plugs into power, it is to keep "Memory" of anything programmed, in case power goes out.
Jun 01, 2014 | Rainbird Rain Bird Simple Set 6-station...
One of my zones keeps sprinkling after I shut the timer off
Which timer do you have?
Copy following link for sprinkler timer manuals
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Add comment and describe timer in detail
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 20, 2013 | Orbit Sprinkler System Power Source...
How do I adjust sprinkler head properly
Check to see if the small slotted screw is flush with the top of the spray nozzle. If so, it has been manually lowered. Turn the screw counter clockwise until it stops, be sure to hold the nozzle to keep it from turning. If no, unscrew the nozzle and remove debris from around filter. Tell the gardener to just mow the grass and not to touch the sprinkler system he is usually why it was turned down 9 times out of 10. If he says "No touch, No touch. He is lying fire him.
Apr 13, 2013 | Orbit Sprinkler System 2-inch Soft Top...
How do I install a sprinkler system?
1) Copy following link for general sprinkler-system design, and for identifying brands of sprinkler timers.
http://waterheatertimer.org/pdf/Garden-watering.pdf
2) Feb 2012. Add comment and say what you are doing, and what equipment you are installing, and which timer you are going to use.
Feb 23, 2013 | Rain Bird Hardware & Accessories
Do you know where I can get the part for my Nelson Tractor sprinkler? It is the black part that holds the sprinkler.
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Apr 30, 2011 | Nelson Sprinkler: Traveling Tractor
Nov 03, 2009 | Garden
Garden Logo
46 people viewed this question
Top Buckner Garden Experts
roeb
john h
Marvin
Marvin
Are you a Buckner Garden Expert? Answer questions, earn points and help others
