Question about Coffee Makers & Espresso Machines
Cordon Bleu Steam Espresso and Cappuccino maker Model 12086 Manuel
  • Coffee Maker... Master
  • 10,438 Answers
Unsure if this model is from 2006, so difficult to find reference other than Amazon.uk listing.
https://www.amazon.co.uk/d/Home-Kitchen/CORDON-BLEU-STEAM-EXPRESSO-MAKER/B000LYZMT4
Possible generic instructions for Cordon Bleu in case they are of any assistance to you:
https://www.ehow.co.uk/how_7772949_use-cordon-bleu-coffee-machine.html
Posted on Oct 12, 2019
Testimonial: "Thank you very much for your help."
  • Terry
    Terry Oct 13, 2019
    You're welcome.
    Top Expert:
  • 54,386 Answers
Google (cordonbleu)(12086)(manual) without paens OR contact Cordon Bleu directly to request it.
6ya staff
SOURCE:
Anonymous
SOURCE: Betty Crocker BC 1725-Instruction Manual
my Betty Crocker model bc-1725 is broken. i want this model.
Posted on Dec 25, 2008
SpotBert
Suzanne
  • 231 Answers
SOURCE: Need the instruction manual
The 866 was superceded by 874 and 888.
Here's the manual for 874 =>
http://www.krupsusa.com/NR/rdonlyres/C1F9A0BF-7C73-4009-B552-9B75D43B6DDC/2419/CAFEPRESSOF874_endefrnl.pdf
Here are the manuals for 888 models =>
http://www.krupsusa.com/NR/rdonlyres/FEFA75D6-E1B1-4AEF-86BE-86239F8F5C11/19888/88843CafeCentro.pdf
http://www.krupsusa.com/NR/rdonlyres/55222C7A-5B29-4DD2-9828-679A73F140F0/7908/F888_NAm.pdf
http://www.krupsusa.com/NR/rdonlyres/A025B3F7-4253-45C9-95CA-AF3036FD2914/2430/CAFEPRESSOTIMEF888_multi.pdf
You can call KRUPs to see if there are any major differences.
Posted on Dec 28, 2008
Anonymous
SOURCE: Steam leak in GB Mia Espresso Coffee maker
I had the same trouble before and probable causes were:
too much coffee powder in the funnel?
or
the coffee beans are ground
too much, makes the power clogging in the bottom of the steam tube?
Posted on Dec 29, 2008
Anonymous
SOURCE: Starbuck's Barista steam wand leak
remove the cover from the machine, loosen the allen screw that fastens the steam knob to the shaft, move it slightly and retighten to allow the knob to close the valve a bit more. I have had to do this a few times in the 9 years I've had my machine as either the knob loosens or the valve threads wear a bit.
Posted on Mar 03, 2009
Gregg Rene
  • 86 Answers
SOURCE: I need a user manual for a Salton Ex45 Espresso
Here's a link, you can download the manual or print it from this page:
http://www.scribd.com/doc/5580961/Cappuccino-Maker
Posted on Mar 22, 2009
No water coming out
Espresso Makers FAQs at MrCoffee.com.
www.mrcoffee.com/.../espresso-makers/espresso-makers-faqs....
Mr. CoffeeBrowse our Espresso Makers FAQs to find answers to common questions about Mr.Coffee products. ... Why isn't espresso coming out when I try to brew a cup?
Steam Espresso & Cappuccino Maker (ECM160-NP) - Mr ...
www.mrcoffee.com/.../mr.-coffee...espresso...maker...-/ECM1...
Mr. Coffee
Rating: 2.7 - ‎32 reviews
coffee-steam-espresso-and-cappuccino-maker--ecm160-np-/ECM160-NP.html ..... Thecoffee grounds don't come out wet like the other unit. ..... too much as the steam pressure only (no pump) isn't enough to force the water through the "cake".
Repair Your Clogged Coffee Maker - Instructables
Dec 21, 2015 | Mr. Coffee Coffee Makers & Espresso...
Cappuccino and latte macchiato buttons blinking
The unit is heating the steam - the lights should switch to contant once the right temperature is reached. Make sure to always descale the machine if the cappuccino button light turns orange.
Mar 29, 2014 | De'Longhi Nespresso Lattissima Plus...
Continuous steam coming out of my cappuccino machine
I have a Dacor Coffee System/ Built in...when i turn on the CN12- check steam temp. and steam comes out. how do i fix this?
Rick
Aug 18, 2013 | Dacor CM24P-1 Coffee Maker
Oster Espresso / Cappuccino model 3216 manual
tenho uma oster 3216 e gostaria de obter o manual. seria possivel me enviar por email?
margarete_oliveira@msn.com
grata
margarete
Feb 19, 2013 | Oster 3216 Steam Driven Electric Espresso...
I have a expresso cappuccino maker model CC30. It is a Maxim-it is white with a red push button on top.. Does anyone have instructions for this..i don't and need some.. Thank you-gerry
nothing to know, put water in it..plug in..no steam should be coming out, until you push the red lever..put in your milk or cream
stick probe down at bottom of cup. steam until mixture gets thick
Jul 13, 2010 | Salton CC30 Plus Coffee Maker
Saeco cappuccino royal wont steam or ventilate
Hi
You have a stuck solenoid or a plugged stream tip.
May 23, 2010 | Saeco Royal Cappuccino Espresso Machine
Hi, no coffee is coming out of Jura S9. The water comes out of steam exit - even in cleaning program rgds
This is a really strange error, but it makes some sense if you own a S9 One Touch model. Then there`s a problem with the squeezing valve located behind the steam/cappuccino outlet. If this is an older model, then it could be a problem with the ceramic valve, but normally this makes the water flud all over the frontpanel and inside. In both cases, i would recommend to send the machine to the nearest servicecenter.
Nov 10, 2009 | Jura Capresso Impressa S9 Coffee...
I have just blown the valve on my bialetti cappuccino maker, can I reuse it?
The valve no, it is dangerous. Steam under pressure is a bomb. If you can detach ?unscrew? the old valve and find a new one, it will be fine.
Nov 08, 2009 | Bialetti Stovetop Espresso Maker Espresso...
How do I make cappuchino cofee?
If you are looking for a manual, you can contact Jura Capresso directly. If you are just looking for directions for making a cappuccino in general:
Brew the espresso.
Use the steam wand/frothing element and a pre-chilled frothing pitcher (the pre-chilling is optional, but it is considered good form) to steam about 1/4 to 1/2 cup of milk.
A true cappuccino does not involve pouring all of the milk directly into the espresso - you would use a spoon to take about two spoonfuls of the top of the steamed milk and place it on top of the espresso.
You can sprinkle cinnamon, use a cinammon stirring stick, or pour cinnamon cappuccino flavoring on top of the cappuccino for good form (but this part is optional).
Enjoy!
-Tha Mp3 Doctor
Mar 22, 2009 | Jura Capresso CapressoBAR 351 Coffee...
Coffee Makers & Espresso Machines Logo
47 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Pierre Laplante
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
