Question about Science & Laboratory
Porter autoclave SES 2000E error code 2 heat gets up to 100 then error 2 comes thanks
  • 2,498 Answers
The fault table is on page 15 of the following document.
http://frankshospitalworkshop.com/equipment/documents/autoclaves/service_manuals/Eschmann_SES2000_-_Service_Manual.pdf
Further support may be channeled through the distributor. As with many devices, it is suggested to have mainteance and repair done by personnel trained specifically in such for the devices. There is quite a bit of information in this manual one might wade through Page 28 lists error codes and error 2 listed refers to door open during cycle.
UK Customers Eschmann Equipment, Peter Road, Lancing, West Sussex BN15 8TJ, England. Tel: +44 (0) 1903 765040. Fax: +44 (0) 1903 875711. Overseas Customers Contact your local distributor. In case of doubt contact Eschmann Equipment.
Posted on Jun 19, 2019
5 Suggested Answers
6ya staff
SOURCE:
kuuren
SOURCE: My sterilizing autoclave, SES 2000 Little Sister
Press any program button, hold it down, then turn on the power switch. Release it after 2 secs.
Posted on Aug 26, 2010
vetteman3002
Rodney Clark
  • 2299 Answers
SOURCE: My autoclave ses 2000 turns
I would say that there is a problem with the thermostat. There is a small relay that pulls in to heat. And the relay opens when the thermostat reaches desired temp. I say it is the thermostat because it is pulling in the relay and heating. And if it is going to 107 degrees every time then the thermostat is pulling in the relay. So that tells you that the relay is working properly. So it would have to be the thermostat.
Posted on Sep 14, 2010
drhqaisi
SOURCE: i have a autoclave ses little sister 2 when l
dear sir
i need catalogue for little sister 2
thanks
Posted on May 30, 2011
emissionwiz
Marvin
  • 85206 Answers
SOURCE: ses 2000 autoclave showing h2o
You are in the wrong product section, thisis cars and trucks.
Posted on Jun 14, 2012
My sterilizing autoclave, SES 2000 Little Sister has flashed with error ELECT on the screen, it apparently has something to do with a power cut we may of had today, but how do you fix it?
Check the fuses located on both sides of the mains connection in the back of the autoclave. One of them has blown. If both check ok, then check the connection tho the mains. You may have a faulty ground. If you are not comfortable doing this, contact Eschmann at tel:+44 (0)1903 753322
Fax: +44 (0)1903 875789
info@eschmann.co.uk
Mar 06, 2018 | Science & Laboratory
Autoclave saying ES what does it mean
There are a variety of brands/models of autoclaves and your model is not adequately identified. There are ES models of an autoclave of a particular brand but I have no knowledge of their designation system. A search of an autoclave manual did not reveal an "es" error code. Why not contact technical support or the sales forces of the manufacturer with the query?
Aug 31, 2017 | Science & Laboratory
At aproc 103 degrees I get ERR1. Any ideas what is wrong
Here is a link to the technical manual:
http://www.njcautoclaves.com/pdf/LS3-None-Vac-Parts-Explosion.pdf
It doesn't list an error code of 1 just 2-9 so I have no ideal.
Nov 29, 2014 | Cars & Trucks
WHY IS MY EZ 10 GIVING A LOW HEAT CODE
Message is displayed and sterilization does not start if the autoclave has not reached sterilization temp. after heating for 50 mins. while in wrapped or unwrapped programs (80 mins in the Glassware program).
1) Clogged air jet, clean air jet.
2) no pwer to the heating elements.
3) Low line voltage delaying heat up. Not enough power to supply unit.
May 06, 2014 | Tuttnauer EZ10 Automatic...
Error 3
Error 3 is a Door lock error and has nothing to do with the water sensor. Tighten the door down snuggly, but don't over-tighten. If it still doesn't work it may need a door rebuild or switch replacement. Call for service if it doesn't restart.
Apr 16, 2014 | ESCHMANN Little Sister Autoclave Tabletop
Err 01 little sister ses
This is a power failure alarm, meaning the prior cycle failed due to a power failure/ outage.
Verify your power supply is correct for this unit's needs.
Check the fuses.
Beyond that, it may be a wiring/power supply issue. Call for service.
Jan 29, 2014 | ESCHMANN Little Sister Autoclave Tabletop
Short beeping with no error code
...no informative error? bacteriological filter? time for maintenance?
Jan 09, 2014 | Joyfay 12L Vacuum Steam Autoclave Medical...
Ses 2000 autoclave showing h2o
Jun 14, 2012 | Cars & Trucks
Science & Laboratory Logo
Top Science & Laboratory Experts
Pokinhas
Tom Chichester
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
