Question about Whirlpool Washing Machines
Whirlpool cabrio platinum washer won come on.cycle was ran w/o any clothes & ended, 15 min later it started beeping & all the lights around the washer cycle button were on incl/DL.
Coldcut
  • 1554 Answers
SOURCE: Maytag Nuptune Washer
These units seem to all use the same control board and have the same issues. the intermittent and door lock issues are random and frustrating. it will take a person that wants to fix it. see this link for what to do. I have other links that explain the same.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
Posted on Jan 29, 2008
aborcass
  • 2651 Answers
SOURCE: Blinking light cycle won't start
sounds as if you have a bad door latch assy, the unit is not recognizing the door closed, so when the button depressed probly only beeps 3 times at you. check the lock/latch for an obvious broken part
Posted on Nov 20, 2008
SOURCE: Is there a reset button for my Whirlpool Cabrio
Check the lid switch and its actuator on the lid. The pause you're getting is likely an open lid sensed by the washer control. Also try to push and pull the inner tub up and down a few times - if I remember correctly these washers have a floating basket, which engages the gears when there is enough weight inside. If there is not enough clothes it may not wash correctly (I don't remember exactly, but try it anyway, what do you have to loose? ;) ).
Posted on Nov 02, 2009
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool duet dryer does not run. The control
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Daniel S
  • 4323 Answers
SOURCE: The drying cycle on my
Hi
The issue is either with the thermal fuse of the unit that is bad or the motor that has gone bad. To check what is causing this, first check the fuse which is located inside the rear panel to the exhaust duct and try to jump start the thermal fuse or test its continuity with a voltmeter, no continuity means bad fuse. If the fuse is okay then replace the motor as that part usually makes a hum sound when it is unable to run. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 23, 2011
Top load washer smells like rotten eggs when water is draining into tub
As someone who has had a deep well drilled and found water, but water contaminated with iron and sulfur, I can tell you first hand about the rotten egg smell. The water softener will remove the iron that can turn clothes orange, but doesn't do anything to remove the rotten egg odor. You will need a charcoal (carbon) water filter to eliminate the sulfur smell.
Sep 19, 2014 | Whirlpool WTW8600YW: 4.6 cu. ft. Cabrio...
I have a whirlpool cabrio washer for a while now here and there i was pulling out soaking wet clothes.and ofcourse my warranty ran out yesterday and now it will not start any cycle all its does is sense...
This particular washer has a test that we can run to see any errors. This can be confusing on this model.
I am including a document below that will describe how to view the old error codes. Use the section that starts with Activating the service diagnostic modes. You can start with the cycle selector knob at any position.
  1. Be sure the washer is in standby mode (plugged in with all indicators off).
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc. There is an error code chart in the image below.
If there are no error codes stored, I recommend that you start from the beginning (step 1 above) and then run the Automatic test mode. If this unit detects a problem, it will display the error at the end of this test.
Here is a list for the errors.
Post back your results.
Sep 14, 2013 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
I have a WTW6600SW1 Whirlpool washer that stays unbalanced even when empty. How do I fix it?
A memo was issued by service matters to remove the counterweight on the base of the machine and add springs to stabilize lateral movement.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 21, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
My cabrio waher will not spin on the last 12 min of the cycle...it displays ul everytime...it is not unlevel we have checked
My washer dose the same thing even with no clothes in it, cause i'v leaveled it and redistrbute the clothes in nothing wroks
Jan 18, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio WTW6600SBT Top Load Washer: every light flashes and just beeps...
You have to check whether the main board is ok or not for that first hold all the buttons in the operational panel except the cancel button and switch on the machine it will process to check all the cycles in few mins.
then check the machine whether it is functioning normally
If not functioning properly means kindly change the main board
May 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer is not washing the clothes properly. Skipping cylcles
If it's new - check if it's under warranty. Let them solve it. Save you money. You've already paid for it once.
Mar 21, 2009 | Whirlpool Washing Machines
Machine continues to display F1 and other F displays. Moved clothes around and pushed power which started machine again, but interupted again shortly afterwards with beeping.
There is a recall on this washer.
Please call Whirlpool...800-253-1301
There is a recall on the Cabrio Whirlpool washer for the F1 code.
The problem is the main computer brain - it is a common defect that whirlpool likes to keep quiet.
Hope this is helpful for you. There is, unfortunately, no end-user fix.
Thanks for using FixYa - a FixYa rating is appreciated for the time taken to answer your FREE question.
Mar 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
26 people viewed this question
Sal De
Marvin
Marvin
jimorris77
