Question about Samsung Cell Phones
I get as far as pushing the button on tracker to connect then the circle just goes round and round and never sets it up. Trying to set up android samsung galaxy
SOURCE:
  • 6 Answers
SOURCE: KitchenAid Superba double oven: can't set clock.
If you turn the center knob (marked 'time') to the right, it sets the timer; but if you turn it sufficiently far to the left, it goes into clock set mode. When you get to the correct time, press start.
Posted on Jun 30, 2009
Semi-Driver
  • 434 Answers
SOURCE: Brother 2170W "fails to associate"
Have you tried the SecureEasySetup method of connecting your HL-2170W to your wireless network?
Basically, it involves no wires:
1) Press the wireless setup button on the back of your printer (you may need to use a pen or pointed object)
2) Press the SecureEasySetup button on your router
3) Let the two sort it out - Green Go button on printer indicates success.
A complete guide for using the SecureEasySetup for your brother model:
Brother SecureEasySetup Method
I hope this helps!
Posted on Jan 26, 2010
Mykel_N
  • 315 Answers
SOURCE: samsung galaxy android unlock..cannot unlock my
Hi, I have a couple of idea for you to try.
1) Log in to your google account on your pc, the same account you registered for your phone
2) After logging in look at the top right corner of your inbox/email page, it would say your google username. Like say if you name is John, and you have a google id thats registered to your galaxy s as , john123@gmail.com. Now this google id on the top right corner of the page would be displayed as john123@googlemail.com
3) Type in the google id, thats visible on the right hand top corner of your page (like john123@googlemail.com) into your galaxy s handset locked page, and type in the password.
TADA AND YOUR ON TO THE NEW SCREEN TELLING YOU TO PUT IN ANOTHER PATTERN.
or theres this one:
Take out the battery, the sim card, and the SD card leave the phone for 2 to 3 hours like that.. Put everything back in and boot up the phone.. This should work.
You could try this instead of waiting 3 hours, just remove battery and press power on switch for 20 seconds but this may not work.
or if you've tried everything, the only other way would be to take it to a Samsung mobile phone shop.
or do a factory reset:
THIS WILL ERASE ALL YOUR DATA THOUGH
Go into recovery mode - vol up & home & power. Once in the menu, select factory reset.It may take you a couple of attempts to get to the recovery mode but it does work, just keep trying.
Regards
Mike
Posted on Oct 12, 2010
SOURCE: Mobile Tracker setting on Samsung Star
i have samsung gt-e2120b mobile...i wanna rest it but wen i use dis code (*2767*3855#), it asks for password...and i have tried alll default passwords but its not working and d mobile tracker is also active and i dont know the password of it....
Posted on Apr 01, 2011
jaisonthomas
  • 356 Answers
SOURCE: Can i upgrade my samsung galaxy s android 2.3 to the android 4.0?
At present u cant upgrade samsung galaxy s to ics 4.0.. Presently samsung only confirmed ics update in samsung galaxy s2 and samsung galaxy note.
Posted on Apr 06, 2012
How do I speed up my 8" polaroid tablet
You can't really. You can look for an Android upgrade for it (usually the later versions are a little faster) and delete apps that you no longer use. If apps over a wifi connection are slow then you can try checking your wifi connection for interference and maybe change some of the settings.
Otherwise a lot of it really depends on the specific app your trying to run that's "too slow". Maybe look for a users forum for that app and see if other users have any performance improvement tips?
Nov 02, 2016 | Polaroid Tablets & eReaders
How do I delete my info form the FitBit flex? I want to return my new flex to buy a FitBit Surge.
HOW DO I DELETE PROFILE DATA FROM MY TRACKER? Fitbit uses your height, weight, and age measurements to properly calculate your stride length (which helps determine your distance), calorie burn, and active minutes.
To delete your profile measurements from your tracker, the tracker must be set up to a different account. Once a tracker is set up to a different account, it will automatically unlink itself from the dashboard and all of the tracker's stored data will be permanently deleted from the tracker. You can find instructions on how to create a new account in the following articles:
May 14, 2015 | Fitbit Flex Wireless Activity & Sleep...
Power button missing
Usually there is a pc. of plastic that appears to be a power button but inside of the case there will be an actual button connected to wires that is pushed when you push the button outside of the case. Should be able to use a toothpick to push in on the little circle u see inside of the case. If not you can remove the cover and order the part that is broken.
http://www.androidtablets.net/forum/wondermedia-based/12092-android-2-2-via-chipset-7inch-epad-mid-power-button-not-working.html this person dropped theirs and the wires came loose inside of the case.
Jun 14, 2014 | ZEEPAD MID Android Tablet 7 Inch WiFi
My EM543 tablet will turn on, the word tablet "Tablet" comes up with a rotating circle underneath it . Cannot open the tablet.
This works with devices having physical home button:-
1. Press the power button and the home button together for a while, long enough until the screen appears with Android bot and a progress bar which shows that it's formatting the internal memory.
With NO physical HOME button:-
2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds.
3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings.
NOTE: You'll not only lose the apps on your internal memory and the data associated with it. All the device updates will also be lost and you'll have the version of Android your tablet came with.
Reset Factory from safe mode android, watch video in my blog
http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
Dec 26, 2012 | Tablets & eReaders
Controller won't connect with xbox
Im assuming that it is wireless.
Turn on your xbox.
push the small round button on the front of the xbox, the light on the xbox should be rotating.
then push the small circle button on top of you controller
Jan 02, 2011 | Microsoft Xbox 360 Controller
CAN NOT CHANGE THE TIME ON THE CLOCK ON THE RADIO ON MY 2004 GMC TRACKER
procedures say to push and hold hour button for 5 seconds untill you hear a beep then set the hour by pushing one at a time sequence. same with the minute button ...hope this helps..good luck
Nov 26, 2009 | 2004 Chevrolet Tracker
IS THERE A MASTER RESET?
There is a reset but as far as i know there is no master reset .
It goes as follows >>>>>
Select OK with ^ on the control button, then press the black circle in the middle, the message "initialize all settings ready?" appears.
Select OK with ^, then press the black circle.
All settings are reset to default setting.
Make sure that the power is NOT disconnected while you reset the camera.
Good luck
Jul 29, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
Mar 09, 2009 | KitchenAid Architect® KEBS277S Electric...
Cell Phones Logo
20 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
