Question about Whirlpool Washing Machines
F7/e3 whirlpool duet washer - Whirlpool Washing Machines
SOURCE:
SOURCE: WHirlpool duet washer is stuck on "controls locked"
we ended up holding the drain/spin button for a period of 15 or so seconds and the issue resolved.
Posted on Aug 10, 2008
  • 107 Answers
SOURCE: My Whirlpool duet washer is not draining. I am
If you hear the pump running and not draining, then take the toe panel off. Should be 3 1/4" screws on bottom. Remove the "coin catch". It looks like a BIG screw and it's white. Turn counterclockwise. There may be a sock, change ect...clogging it up. Dump it out and run machine. Have towel or bucket ready when removing coin catch.
Posted on Mar 20, 2009
  • 220 Answers
SOURCE: What id a F28 code on a whirlpool duet washer
Can be the machine control or the motor control here is a link to the Repair manual....
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Posted on Sep 13, 2009
jsrock516
  • 5911 Answers
SOURCE: how to replace the belt on a whirlpool duet washer
To replace the drive belt on a Whirlpool Duet washer, follow these steps:
1. Unplug the washer and remove the rear panel.
2. Place the drive belt on the drive motor pulley with the ribbed side on the drive motor pulley. Leave a one-groove gap between the belt and the end of the pulley.
3. Take both hands and pull straight up on the belt and place on the drum pulley beginning on the left hand side.
4. Hold the belt firmly in place and slowly turn the pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
NOTE: This may require some effort to get the belt in place.
If you have any questions, please let me know. I hope this helps you.
Posted on Sep 28, 2009
Testimonial: "Thanks for the info!"
blueextc3221
  • 15935 Answers
SOURCE: whirlpool duet washer ghw9250mw1 door won't close ...
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
http://media.fotki.com/1_p,wkkrqtwwwgtsgwdxgtqsskgwtqkq,vi/krqsddwkbxktttdstrw/1/1303472/5961857/image48287img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Whirlpool Duet washer error E3/F8
RTM. Read the manual. If you misplaced the manual, get on by going to Google, put in your make, model and the word manual and you should get the .pdf file of your manual, download it and read it.
Oct 12, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Drum on duet washer is not finishing load, getting stuck, wont turn
Hello
you need to clean the filer on the front of the machine , or check the pump for a faulty impeller , a good. Clean of all the draining system would be a great start,
Oct 08, 2014 | Whirlpool Duet GHW9150P Front Load Washer
F2/e3
What cause E2 -3 appear in Toshiba Washing Machine AW-9790S and unable to open the door due to the lock button is on?
Apr 27, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Error code e3
its a long drain which means you have 8 minutes to drain and its taking to long you need to remove the bottom panel 2 to 3 screws and clean out you drain they will have water in there so be ready for about a gallon or two to drain out and also check to see if your drain hose isn't kinked
Mar 09, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loading washer
your inlet water valve is not closing and needs replacing, in mean time turn water off between washings.
Apr 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
29 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
