Question about Garmin GPS
Garmin Street pilot 2720 touch screen not work. Unit powers up, screen starts out bight then suddenly darks a bit in all light conditions, maps come up and push button functions work but no response to touch screen. Updated with latest software from Garmin. Aksed Garmin and they told me to calibrate push screen but can't do that without push screen working at all. Any ideas ?
Did you ever get your touch screen to work mine stopped working also i have the 2720.
Posted on Aug 27, 2009
SOURCE:
I have a discontinued model Garmin 2820 Street Pilot - How do you update mapping software?
I had a problem when I went to the Garmin site to update my 2820. After the update, the touch screen function didn't work--it would freeze and I'd have to reboot it. In contacting Garmin, even though this was a high-end GPS and was not inexpensive when it came out, they said they would no longer support it and they wouldn't offer any suggestions as to how or who to go to in order to return its functionality. It looks like what happened when they stopped their customer support that they combined the software from the 2820 with their Nuvi software and while that might work for the map, it deactivated the touch-screen and bluetooth function. My unit still does not work.
Jun 23, 2014 | Garmin StreetPilot 2820 GPS
Can i use garmin C320 street pilot in italy
Most stock units are equipped with a US & Canada map if purchased in the US. Yes, the unit will work in Italy but you will need to add a Europe Map on an SD card, as the internal memory may not be large enough to hold both maps.
Feb 17, 2014 | Garmin StreetPilot C320 GPS Receiver
I have a garmin street pilot 2720 I bought a garmin nuMaps lifetime product to up date, would like to up date for the 2nd time can't find where to go about this, I have the product key and the...
Log into your account at www.garmin.com by using the myGarmin link.
With the unit connected to the computer go to the myDashboard link.
Your Street Pilot 2720 should show up on the dashboard.
From there you should be able to apply the update.
You may also want to contact Garmin support for assistance.
http://www.garmin.com/us/support/contact
Sep 27, 2011 | Garmin StreetPilot 2720 GPS Receiver
My garmir street pilot 2720 is not powering up. what to look @ first
In order
1- Check using another device the power outlet
2- Check the garmins power cord, are the connections still firm, if they are loose and sloppy, bend the metal tangs out a LITTLE bit
also note the metal tangs in the power outlet may be bent in from continued use bend them into towards the centre of the plug NOTE PULL THE RIGHT FUSE ON THE VEHICLE BEFORE BENDING OR STICKING ANYTHING INTO THE HOLE TO ADJUST THE TANGS
3- In the end that you plug into the cars power outlet is a 1 amp fuse, is this still good.
4- Does it work in somebody else's car
May 10, 2010 | Garmin StreetPilot 2720 GPS Receiver
My Garmin C3550 street pilot will power up but screen is only white.
Try recalibrating the touch screen. Turn on unit while continuing to press the power button for about a minute. You will then be prompt to touch a series of dots on the screen. Once prompt to do so, release the power button and touch the dots. Press OK when calibration is complete. The unit will continue to power on. Good Luck.
Aug 11, 2008 | Garmin StreetPilot c550 GPS Receiver
Garmin Street Pilot III map source data card not accessible
Garmin has issues with the newer (ROHS Compliant) cards, so If you recently bought this card get a replacement from garmin.
I had these issues too with a 256 MB, garmin replace the card with 2 128MB cards, worked fine after that.
Mar 26, 2008 | Garmin Streetpilot ColorMap GPS Receiver
2720 street pilot replacement
The screens are not interchangeable. The 2610 screen is 3.3x1.7" and is 305x160 resolution. The 2720 is the exact same size but 454x240 resolution.
Jan 13, 2008 | Garmin 010-00358-00 GPS Receiver
Cracked screen on Garmin street pilot 330
Given the cost of buying a new LCD with touchscreen is about $130 USD + shipping. Your best solution is to sell the existing unit and buy a new Nuvi or recondition C330.
Garmin will repair the unit for $150 and provide the lastest update and map.
Jan 01, 2008 | Garmin StreetPilot C330 GPS Receiver
GARMIN STREET PILOT 2720
Is the power connector fully seated on the GPS unit?
Dec 11, 2007 | Garmin StreetPilot 2720 GPS Receiver
GPS Logo
331 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
