My phillips tv 42pfp5332d/37has a blue light with a red flashing light no piture or sound
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 20 Answers
Main board.
Posted on Jan 13, 2019
    Top Expert:
  • Televison & ... Master
  • 50,983 Answers
Open internal fuse or power supply failure
  • 52 Answers
SOURCE: Power Problems - won't turn on
first thing to do is determine if there is a blink code as that gives a direction for t/s. regardless, what you should do first is offload the y main and x main sustain boards from power supply one at a time as there is a common issue where these boards can cause load on power supply and if voltages come up with either one offloaded that board should be replaced before proceeding. if y main is the issue there is an upper and lower buffer board to left of that board and also should be replaced at same time as 3 boards complete a circuit and replacing one could cause damage to others.
Posted on Aug 18, 2008
  • 52 Answers
usually blink code on front gives direction but first thing to do would be to determine if surrounding sustain boards are causing draw on power supply by disconnecting them one at a time from power supply. y is on left looking from back and x is on right looking from back. if led goes solid with either board disconnected check supply voltages and if come up and stay up replace that board. if no change then you would need to verify vs on command coming from logic main to power supply. should be labeled on power supply connector and should be 3 volts. if present replace power supply if not present verify if logic main board sitting underneath signal board has one solid and one blinking led on if verifying normal operation and if so replace small signal board
Posted on Aug 19, 2008
SOURCE: Phillips 20 inch flat tv
sound keeps going up to full and remote wont bring it back down to level i want
Posted on Dec 25, 2009
  • 6 Answers
SOURCE: my plasma tv has a red light flashing on the
You have to bad compacitors on the power board. They will be buldged on the top. Once replace you TV will live again. The parts will cost you about $4
Posted on Mar 04, 2010
  • 17 Answers
SOURCE: Phillips 42 inch LCD 42PF9730A Redlight flashing
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Posted on May 13, 2010
Black screen
It is likely that you now have power supply trouble.
May 26, 2013 | Philips Televison & Video
Phillips 42PFP53320 42" Plasma TV. No picture,
Hello jporter...
welcome here in fixya..
That problem is one of the common problems of plasma TV (have sounds but no picture)..As a expert of flat panel for more than 5 years I already encounter that kind of problem many times..
Actually that problem is caused of either X,Y or Z sustain board or even both 3 boards are faulty..Because some models when the one of those boards have short circuit or bad there are possibility that other sustain board are affected..But most the problem like yours is "Y-SUSTAIN" board..
I can't find your model online please double check it it either Phillips 42PFP5332D/37 or 42PFP5532D/05
And for specific and easy way to find replacement please try to look at the part # of that board (it is usually printed on the sticker attach to the board itself..
Hope it helps and please don't forget to rate my answer..
Have a nice day!!!
regards,
Chester.
Feb 04, 2012 | Philips Televison & Video
I have a sony 55"
3 times red standby light flashing indicates that lamp cover (first thing that you removed from tv to replace lamp) is not fixed properly on tv, make sure lamp cover is attached correctly with tv to solve this issue.
3 times blinking is not problem of fan or anything else, it is related to lamp cover that engages safety micro switch inside to turn On tv.
Thanks.
Jan 27, 2011 | Sony KDS55A2000 55" HDTV
52" tv making clicking sounds
Does the blue light just stay steady or does it blink? Also please tell me the make and model of the tv. Sounds like a problem due to capacitor plague but I would like to be sure.
Sai.
Dec 12, 2010 | Philips Televison & Video
I have had my TV-- a 42" Philips plasma-- for
it can be a poor contact or puffed capacitor in the power supply board
Dec 06, 2010 | Philips 42PFP5332D 42 in. Plasma...
Philips 55P8288A tv has a dull color and a red hue.
This sounds Like the the coolant for your piture tube has become cloudy and needs replacement (usually blue or green tube - thats why the image seems ovrely red).It's a big job (labour wise) since completee dissassembly is required ($200-300). It can be done youreself - check out TVrepairkits.com to get the coolant and instructions.
You can confirm that this is the problem by dissassembling the unit to the point where you can view the face of the CRT's (red green and blue) directly.
Nov 28, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
When I plug the TV in, it will click, no picture will happen, I can see green lights through the back of the TV flashing the same time the clicking happens. Phillips model number 42PFP5332D/37 serial...
You may have a problem with the power supply circuit which is a common issue with these types of TVs. Inspect the circuit for burnt parts, leaking or swollen capacitors and loose solders.
Nov 06, 2009 | Computers & Internet
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
