Question about Frigidaire Refrigerators
Have a Frigidaire model FPHB2899LF3. Cannot remove ice bucket even though trigger release button is depressed.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 14 Answers
The bucket is probably frozen in it mount. Turn off refrigerator until it defrost enough to release it
Posted on Jan 12, 2019
peyton32034
  • 410 Answers
SOURCE: ice despenser
your refrig has a solenoid that opens and closes a flapper in the bucket to bypass the ice crushers look on the bottom of the ice container and there is a brass rod that is bent at the end. if yo will find where the end of that rod inserts into the dispenser motor inside the freezer there is a saddle that has most likely frozen in the up position. you can use a hair dryer to warm the area up and pull the saddle back to the down position. its kind of hard to tell you with out pics but hopefully you get an idea of wht i'm trying to describe..
Posted on Jan 07, 2008
SOURCE: ice maker sensor arm
the arm is hung up on a srcrew that is on the divider wall to the right of the icemaker pull the arm off the screw. The icemaker is a mechanical one so the arm will not just drop down so put the ice bucket back in and turn the icemaker back in the control panel further problem call customer service for assistance for over the phone help 1 800 222 7820 they will be glad to assist their customers unlike other manufactures.
Posted on Apr 29, 2008
  • 10 Answers
SOURCE: pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Posted on Apr 20, 2009
plnolte
  • 62 Answers
SOURCE: won't make ice
Have you changed your water filter lately. On many side by sides there are built in water filters that will slowly stop making ice and giving water because the filter is in need of changing...if this is not the problem write back and I will walk you through the other possibilities...
Posted on May 18, 2009
  • 125 Answers
SOURCE: ice maker only makes crushed ice
on the bottom of the bin there is a metal rod, this goes into the back wall where the solenoid is. find the square hole it goes into, pull down the white plastic piece with your index finger. you should here a clunk. now put the bin back and check to see if ok. if not you may need to replace the solenoid assy.
Posted on May 27, 2009
Ice not coming though door of frigidaire refrigerator model plhs239zdbr ice bucket full
The dispensing solenoid switch may have failed, causing ice to back up in the chute.
Aug 29, 2018 | Frigidaire Refrigerators
Kenmore refrigerator model 106.5786*801
Sometimes the ice melts then refreezes. Make sure the button is depressed. Or open the door, tape newspaper across the freezer section to keep the cold air in, leaving the door exposed to room temperature will allow it to thaw. Or speed it up by using a blow dryer to thaw it.
Jul 12, 2014 | Frigidaire Kenmore Washer Tub to Pump Hose...
Cant remove ice bin kitchenaid
This is an ice freeze up in the mechanical release mechanism. Leave the door open for a few minutes. But if you are impatient like me, warm the area with a hair drier for about 20 - 30 seconds, and you should be good-to-go.
May 13, 2012 | KitchenAid KSRD25FK Side by Side...
When i depress the paqddle to dispense ice the auger does not engage and no ice will come out
Make sure the ice bucket is fully seated into the space below the ice maker where it rests, if not in all the way, the auger cannot engage and or the switch that tells the auger motor that the bucket is in place will not be triggered.
Good Luck !
Mar 14, 2010 | KitchenAid Architect ® Series II KSRX25FT
Frigidaire Model GLHS68EGSB2, ice maker will only dispense crush ice even if you press the ice cube dispenser
You need to take out the ice bucket, empty it, let the bucket sit in the sink for a few hours. Ice builds up in the crushing blades and jams them, let all the ice melt out of it and it will be fine
Oct 27, 2009 | Frigidaire Refrigerators
Even though the cube ice button is pushed, it gives me crushed ice instead..
You have a faulty solenoid problem. If you remove the ice maker bucket you should see a lever on the bottom of the bucket that engages the solenoid at the back of the freezer. You will have to remove the back cover to access this part. hope this helps
Jul 31, 2009 | Frigidaire Refrigerators
The ice maker on my Fridgidaire will only give crushed ice, even though we've never pushed that button. We only want cubes.
check to see if your ice solenoid on the rear of the ice maker bracket is seized up with ice. if so you can remove this and run warm water over to unseize solenoid. remove ice bucket and u should be able to see the solenoid close to rear wall. it is attached to the metal bracket that holds the ice bucket in place. usually two quarter in screws holds it in place
Jun 21, 2009 | Electrolux Refrigerators
When dispensing ice we only get crushed ice even though the button is on ice cubes.
your actuator is probably bad its a little solenoid that the ice bucket rod sticks in to at the back remove the ice bucket find the square that the actuator rod sticks into look in it if you see a bar about halfway down in the square see if you can take your finger and pull it down then hold in the door switch on the cabinet not the one that runs the freezer light and have some on actuate the ice disp to see if the bar goes up and down if not you will need to replace the solenoid also clean the bucket and check that the rod is moving the door in the bucket
May 24, 2008 | Frigidaire Refrigerators
Refrigerators Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Sal De
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
