My delonghi won't pump water
Changed the pump and cleared the filter still won't pump the water
4 Suggested Answers
SOURCE:
  • 1073 Answers
SOURCE: Changed water filter and water
make sure that the filter is completly inserted into the housing
Posted on May 16, 2008
heatman101
  • 43501 Answers
SOURCE: my dishwasher won't pump out. I've
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Posted on May 10, 2011
  • 47 Answers
SOURCE: delonghi steam station iron wont take water pump
this sounds like a blockage to me have a good look, good luck
Posted on Oct 02, 2011
Delonghi Magnifica won't brew or rinse
Sounds like the pump or its internal valve are not working. Check for voltage with a multimeter at the pump when it brewing. If voltage is present likely the pump has failed. Also check hydraulic pipes are clean and clear and that any filter screens are not blocked by scale.
Dec 07, 2014 | DeLonghi Coffee Makers & Espresso Machines
How do I fix the water pump of a delonghi BC4264B? It's not pumping any water to make espresso. the machine heats up well, the steamer works fine, the drip brew side works fine. I'm not getting any...
Is there any water coming out of the group head when the porta filter is not used???the group head has a filter on it and it could be totally clogged
Jun 11, 2014 | DeLonghi DE500P Dehumidifier
Delonghi split system (inverta) leaking
clear drain line with air or water. If unit is really old possibly drain pan rusted with holes. make sure to change air filter this will cause coil to ice up if restricted.
Jan 23, 2010 | Heating & Cooling
Dehumitifier wont condense water
This happened to me after the unit was turned on after being off all winter. I've had it just two years. After speaking with "support" I gather that it needs a new condenser, perhaps just because the freon may have escaped. It may be a sealed unit. Anyway, the math works out to simply discarding it and buying a new one. For me, this means not buying a DeLonghi. By the way, their service centers are strategically placed in remote areas to attract the fewest claims HD
May 03, 2009 | DeLonghi DE500P Dehumidifier
How to clear a delonghi dishwasher error code 4
Try removing all dish trays and salt softner lid, check if the salt softner compartment is full of water, if so place the machine on its side and allow all the water to drain from the compartment, once this is done your machine should be good to go. This is how i resolved my problem. The salt softner is located next to the water drain filter.
Jan 03, 2009 | Dishwashers
Delonghi Espresso Maker Issue
check the water temp and make sure the grind is not to fine. if both of these checkout ok then it may be a weak pump. you will have to find a replacement pump.
Mar 06, 2008 | DeLonghi EC140 Espresso Machine
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
