Question about Dryers
Trying to clean oven. pushing oven clean button and start. getting a buzzing noise and FSE1 shows up
  • 4,345 Answers
You getting a short pull out the plug turn off then clean it
Posted on Jan 12, 2019
SOURCE:
localwonder
  • 6784 Answers
SOURCE: code fse1 comes up when a few minutes after pushing start to cle
F5 - E1 Self clean latch will not lock
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Posted on Apr 02, 2009
  • 56 Answers
SOURCE: buzzing when push start button
the motor is siezed
Posted on Jun 30, 2009
localwonder
  • 6784 Answers
SOURCE: whirpool range type p30
HI. the keypad is experiencing issues at this time. follow the steps below to address this problem.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Posted on Nov 02, 2009
heatman101
  • 43501 Answers
SOURCE: self cleaning oven function does not work. display
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Posted on Sep 07, 2010
heatman101
  • 43501 Answers
SOURCE: Have Whirlpool self clean electric oven model #
heatman101
Posted on Jan 20, 2011
Whirlpool gas range self-clean cycle produces FSE1 on display and door doesn't lock, audible alarm sounds
I found this on an appliance forum. It sounds the same as your problem. They say the code is F5 E1. Apparently the door lock latch is stuck.
Appliance Repair Forums
Dec 30, 2014 | Whirlpool Kitchen Ranges
FSE1 CODE just popped up on the stove and the latch started going back and forth and the interior light would go on and off. We weren't even using the stove or oven when this happened. What does
The F5 E1 error message indicates the latch motor was unable to lock the door. When the self clean cycle is started, the control board will turn on the latch motor which is mounted on the rear of this range. The motor is connected to a cam that transfers the motors motion to a rod that runs under the cook-top. Here is the part to order.
Dec 10, 2012 | Whirlpool GR460 Electric Kitchen Range
Fse1 shows meaning? Want to clean
heatman101
Feb 15, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
I have a Whirlpool Super Capacity 465 self-cleaning oven. I tried to use the Auto Clean function tonight, but after about 15 secs., the oven displayed error code FSE1, beeped multiple times, and then...
I researched your question regarding error code FSE1. I could not find a response regarding a self cleaning oven. If you will provide the model number on the below listed website under "cooking" you may get a detailed response.
http://producthelp.whirlpool.com
It seems that a general "fix" for error codes is to got to your electrical panel and shut off the breaker controlling your device for 1 minute. This resets the device and will reset the error code. (May not fix your issue but will reset code.)
Your manual should have a list of error codes to help you resolve this issue. If you have misplaced the manual, you can also download one for your device from Whirlpool's website as well.
If all else fails here are the U.S. and Canadian telephone numbers under "Contact us". I do not know if this is a pay line or Whirlpool will answer your questions and attempt to resolve at no cost.
US: 1-866-698-2538
Canada: 1-800-807-6777
Jan 02, 2018 | Ovens
Have Whirlpool self clean electric oven model # F368LXKQ. Am trying to self clean-get a F5E1 or FSE1 error code and it will not start to self clean/heat. Any idea what the problem is?
heatman101
Jan 19, 2011 | Whirlpool Ovens
Self cleaning oven function does not work. display shows fse1 meassage
heatman101
Sep 05, 2010 | Whirlpool Kitchen Ranges
Code fse1 comes up when a few minutes after pushing start to cle
1. If door latched:
  4. Re-apply power.
Apr 01, 2009 | Ovens
Buzzing noise when pressing start button
does the buzzing noise sound more like a hum, if so could be a bad motor or possibly something stuck in blower wheel.
Jan 05, 2008 | Dryers
Dryers Logo
50 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
