Question about Beko Refrigerators
I have a Beko Fridge Freezer....freezer one side fridge the other. Freezer: ice machine stopped working. RED snow flake on screen. Fridge: Fan has stopped working. Don't know where model number
  • 1462 Answers
SOURCE: SAMSUNG SIDE BY SIDE FRIDGE FREEZER
these appliances are a pain in the butt. fault with water dispensor is oprob that the water bottle at bottom of fridge is frozen. rise in temp is prob that defrost not taking place. not a diy unless you are experienced
Posted on Mar 20, 2007
  • 833 Answers
SOURCE: Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
Posted on Mar 09, 2008
  • 29 Answers
SOURCE: Our beko frost free fridge
the thermostat in the fridge is turning off your compressor before the freezer has completed its job.this is because it doesnt care about the freezer temperature only the temperature where its located in this case the fridge,try completely defrosting the fridge and restarting it
Posted on Aug 13, 2008
deby69
  • 16 Answers
SOURCE: whirlpool side by side freezer not working fridge is fine
Pull out the fridge and unplug. Remove the back cover. Clean the condenser coils and fan. If they're difficult to get to, use compressed air to blow out. (you can get a can from walmart). That should fix the problem. If that doesn't work, then write back.
Doug
Posted on Jan 05, 2009
Bogie Boy
  • 46 Answers
SOURCE: my mothers beko fridge freezer making bubbling sound
Sounds like the evaporator fan is doing its job. Nothing to worry about. Good hearing is a blessing all fridges make different sounds some click loud while others gurgle loud. Some pop and snap. Till I got my hearing aids I didn't know mine ran so loud and clicked.
Posted on Dec 16, 2009
I have a Beko frost free fridge freezer kept in a garage that has all of a sudden just stopped working. I noticed that the bread I'd put in the freezer hadn't frozen and then noticed that the fan had...
If the fan has failed or intermittent, the freezer wont freeze the food properly but usually you get a mountain of ice build up at the back of the freezer. This ice jams and stops the fan from turning. Alternatively, there could be a defrost problem. Unless it is a fully electronic defrost machine, there is usually a little timer on the back of the fridge to force a defrost after a certain time. The fridge will turn off, the defrost heater operates to melt the ice and then usually with 20 to 45 minutes, the defrost timer will "click" back on and start the fridge running again. If the timer is sticking, the fridge may stay on its defrost cycle and never start again, thus, it doesn't get cold. If you find the defrost timer, have a close look for a little shaft or slotted screw type stud sticking out of the middle of it. A slight turn of this and you should hear it clicking around. When you hear a loud click, that is either the start or end of the defrost cycle. If you have a full electronic defrost system, it may be a failed board, heater, thermostat or defrost safety fuse.
Jan 05, 2015 | Refrigerators
Why has my fridge freezer started to make a louder humming noise?
no problem with that it is normal..your ref working properly it is just the motor you hear
May 22, 2012 | Beko Refrigerators
My kenmore side-by-side refrigerator is less than 4-years old. freezer works but refrigerator stde does not get cold. ice accumulates on lower vent in refrigerator.
all it does is the evap fan blows cold air from the freezer into the fridge section and returns through the bottom air vent,so if there's ice there most likely one of the doors was left open,check the freezer for frozen water droplets on packages or on the walls and shelves of the machine,if you don't see that open the freezer door,if you don't hear the fan blowing you could have a bad evap fan motor.if the fan is blowing in the freezer from the bottom remove the second draw or bin and put your hand on the back inside wall of the freezer,if there's frost or like snow on the back wall you have a defrost problem,bad defrost thermostat,defrost heater,timer or board depending on what model you have,if the fan is blowing and you don't see any problems that i talked about you could have a bad damper,on some machines there's a damper door that opens and closes to let cold air into the fridge section,if it's bad it won't open and no cold air can blow in from the freezer,if you think the door was left open,remove anything that's in the way,in the freezer side and the fridge side,shut the machine down or unplug it and with a hair dryer melt out the ice,don't keep the heat in one place for to long,you can melt the vent if it's plastic or styrofoam,after you think it's melted out start the machine and put your hand up in the left hand corner in the fridge section and see if you can feel any cold air blowing in,there could be ice up there too,next time send the model number so i can look up your model,on a side by side you'll find the tag on the right hand side wall in the fridge up near the ceiling or on the ceiling near the light.hope this helps,if you have another fridge you could move the food and just shut the fridge down with the doors open and let it melt out on it's own overnight.good luck
Sep 05, 2011 | Kenmore Side by Side Refrigerator
The freezer works well but the fridgedoes not get cold enough
all the fridge does is blow cold air from the freezer down into the fridge section so if the freezer is working then either the evap fan isn't working or the air ducts are frozen up.first thing open the freezer door,you should hear the fan blowing,if not the fan motor could be bad,if it is blowing,touch the back inside wall of the freezer,is there any ice or like snow on it,if so you have a defrost problem,one more thing to check,open the fridge door,look under the bottom draws,is there any water there? or any water dripping into the fridge section from the freezer,if so you have a blocked drain and the air ducts are frozen.let me know what you find,send the model number off of the fridge,open the fridge door and look on the left side up near the ceiling,you should see a tag with the model and serial numbers just send the model
Jun 05, 2011 | Kenmore 21.7 cu. ft. Top Mount...
My fidge wont cool down
Most likely a defrost problem..check the defrost thermostat, timer, heater, fan... if the fan in the freezer compartment running?? sometimes ice will form in the vents...check the easiest things first ..like the vents and drain tubes,,
Aug 20, 2008 | Refrigerators
Our beko frost free fridge freezer has stopped freezing. The fan is working and the freezer section cold but not cold enough. Thermostat is in the fridge - the fridge is icing up.
Aug 12, 2008 | Refrigerators
Beko fridge freezer not working... not cooling
yes it can b fixed is the fridge running ? if it is it will need re gasing which is a common fault with beko and you should not pay more than £40 for the re gas if it is not running it will b either your thermastat which again you should nt pay more than £48 4 or the compressor which will b aprox £120 supply and fit none of the above should b done by a novice good luck
Sep 07, 2007 | Refrigerators
Fridge is not 'freezing', Looks like fan stopped working
could be due to ice build up jamming the fan. take back panel off and check for ice. if ice present the defrost system has failed. also on some models, the fan stops when door is opened. check door switch is operating
Mar 22, 2007 | GE GSS25JF Side by Side Refrigerator
Refrigerators Logo
27 people viewed this question
Top Beko Refrigerators Experts
John Tripp
John Tripp
gbob59
Are you a Beko Refrigerator Expert? Answer questions, earn points and help others
