Question about Refrigerators
I have a Mitsubishi MRLX630 Fridge and the digital control panel does not light up l have tried resetting but nothing I do seems to work.. Kevin..
SOURCE:
SOURCE: My dryer seems to be partially working.
gkfgk
Posted on Oct 23, 2007
  • 206 Answers
SOURCE: Mitsubishi HDTV 1080
The set is trying to tell you somthing by blinking this light. And the bad news is that it's sayiny the DM board is not booting up, there are several problems that might cuase this all from bad capacitors to a shorted diode or a compleatly replacing the DM board. but all these are not for the weakend tv tech this one has to go into the shop
Posted on Feb 07, 2008
localwonder
  • 6784 Answers
SOURCE: control panel on my fridge
Pull the power cord for 5 minute to reset the control board. if this control panel malfunction still exist after the reset, replace the control circuit board.
This is a typical control fault that should be corrected by pulling power for 5 minutes. if not, this reset will confirm major damaged to the circuit board.
Posted on May 25, 2009
aasc
  • 1606 Answers
SOURCE: GE Profile model PFS22MISBWW stopped working, panel problem?
Replace the main control board on the back of the refrig . PT# WR55X10656 . It's behind a panel about 10" x 6" .
Posted on Aug 08, 2009
  • 74 Answers
SOURCE: Front panel beeps when I push any button or
possible bad dispenser board
Posted on Nov 17, 2010
Mitsubishi WD-52525 projection TV volume control
Check owner / operator manual for "panel lock" selection or
go through menu pages until you spot it........
This selection is made so guests or children cannot operate tv.
In case this suggestion fails, you might try hard reset = unplug
AC cord overnight,then try again...........T.
Nov 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
No temp lights on fridge or frezer panel.light on in frezer not in fridge
Try cycling the power. Switch of the fridge at its isolator (or wall socket), leave for 1 minute and switch on again.
Consult your owner manual for guidance.
If still under warranty, contact your dealer.
Apr 16, 2014 | Refrigerators
Mitsubishi WD-60735 Control issues
This set has aside from the recessed front reset two more done with the Mitsubishi remote.
The soft reset "should" be with set on Menu, 1,2,3, enter
The hard reset requires a 4 digit number code and is based on model number and also done with the Mitsubishi remote--try to see if soft reset works at all on this model.
Mar 31, 2012 | Mitsubishi WD-60735 Projection Television
I have a WD-52525 set that the green light kept blinking after a power outage. The reset button never worked. I unplugged the set for 30 seconds and re-plugged it back in. The light began blinking between...
Bad digital/power module. Contact Mitsubishi, they may cover part of repair, I am serious. If not, have a an authorized servicer send module to Mitsubishi for rebuild program. The only economical solution.
Jan 18, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Control panel on my fridge
May 25, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Control panel not working Samsung refrigerator model rs2533sw. Not cooling.
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Apr 02, 2009 | Samsung Refrigerators
Ws-5511 Mitsubishi
On these models we have found that a switch is sticking on the control panel not allowing the set to operate properly.
Disconnect the control panel.
You will be able to use the remote on it.
To find the plugs for the control panel:
Remove the speaker grill and front panel, then follow the wire to the connection.
Remember to unplug the set before putting your hands inside of it.
Dec 13, 2007 | Mitsubishi WS-65908 TV
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
