Question about Watches
Can I use hand wave to show time - Watches
Casio wave ceptor hands running 8 minutes slow. Digital clock showing correct time. Hands 8 minutes slow even if I change time manually.
You may need to recalibrate the hands. Sometimes the hands are out of sync with timekeeping. Go to the Casio website, download the manual for your model, and follow instructions for resetting the position of the hands (might be referred to as zeroing or recalibaration).
May 30, 2016 | Casio Watches
I have a disallignement of 10 minutes between the digital and the analogical time. The digital time is perfect how can I allign the analogical one?
You have to know that analog time "follows" digital time.Any hour/minutes correction on the display has direct effect on time/minutes hands.Some times, mostly after battery replacement,hands might have declination.That is why there is a function so called "Hands home position adjustment".Using this function you can align both hands to 12/00 position.If there is any declination (I think is your case) you can correct.Try to enable this function by pressing for 4-5 sec the upper left button(A) until "HAND SET" appears.If hands are not aligned exactly to 12/00 position, you must correct by pressing the lower right button (D) for forward movement or the upper right button (B) for backward movement.In fact, minutes hand is aligned,hour hand follows.When both hands are set to 12/00 (home position) press button A again.Time Mode returns to the display.Normally hands will now show exactly according to digital (display) time.I hope this will help.
May 23, 2015 | Casio WVA105HDA Wave Ceptor watch
Casio Wave Ceptor 3353. Digital time is correct. Hands are about 15 minutes fast ahead . Cannot correct.
I have the casio 3353. When I read hte manual to do different things, it always startes the instruction by saying "in timekeeping mode". In the instuction booklet at page 8 it shows a picture of the watch face in timekeeping mode and in the picture the face shows the day and date. My face is showing the digital time here. How do I show the day and date,or the timekeeping mode?
Sep 09, 2010 | Casio DW9051B-1V Wrist Watch
My wave cepter wr100m recently had the battery changed and now the time is completely wrong. I have manually setting the time but the hands are still showing the wrong time (it's out by 6 hours 23 mins).
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box.
Aug 19, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
There is a 35 minute difference between the dislplay and what the hands are showing with the display having the correct time and the hands behind.
If you haven't got instructions on how re-set the analogue hands, you can get instructions from the Casio web site.
watches;
Accept terms
May 31, 2010 | Casio Wave Ceptor WVA430A-1AV Wrist Watch
Oh, one additional thing about my CASIO 'WAVE CEPTOR' watch: After I got (finally) the manual and set up the watch, it set the DIGITAL display to the correct time & date, but the ANALOG display re-set...
You can align the analogue time with the digital time by pressing the mode button until you reach the hand setting position (HS) and then press one of the right hand buttons to change the hand position.
(Check out this with the instructions- it is all there!)
May 07, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
How do i turn the time back on my casio wave ceptor 4756
Press the lower left hand button until the display shows "HS"
Use the upper or lower right hand buttons to adjust the hands in the appropriate direction.
Jan 01, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
The digital display shows the correct time but the hands do not.
hi there when you replace batteries in wave ceptors all hands have to be set to the home position (straight up at 12 oclock), as the instructions vary wildly from watch to watch you will have to download the manual from www.casio.co.uk you will need to put in the module number (found on the back plate of the watch), this will be in PDF format, you can download adobe reader for free from www.adobe.com to read PDF files. good luck
Aug 20, 2009 | Casio WVA105HDA Wave Ceptor watch
Analogue display does not sync with digital
Go to the Casio web site. Download the manual for the watch. Go to the section called "To Adjust the Analog Time." The answer is there, step by step.
Sep 22, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Casio Wave Ceptor Watch Model WV 109 HA
I found a hand setting mode. Press lower left button 6 times until the readout shows HS. Press and Hold Upper Left Button (A) until flashing. Press lower right button (D) to move the hand forward. Press upper right button (B) to move the hand backwards.
Apr 22, 2008 | Watches
Watches Logo
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
