Question about Watches
My watch has water inside it, How to remove it?
I got it from my uncle so I am not sure from where he bought it but it is espirit watch.
  • 2,894 Answers
Hello, Bivek - See the information here from another question and answer forum, Just Answer: https://www.justanswer.com/clock-repair/5qzju-does-one-dry-crystal-watch-face-grandson.html
Best wishes.
Posted on Jan 10, 2019
2 Suggested Answers
SOURCE:
  • 2501 Answers
SOURCE: how to remove water from inside the wrist watch
Try putting the watch in a warm place for a day or two, to let it dry out. (one maker said that some moisture is not a problem but I guess that is depends on how much "some" is).
If the problem persists, take it to a watch repairer.
Posted on Jul 17, 2010
Mositure in watch how can I get rid of it
You could remove the back and place the watch somewhere warm and dry for a day or so. As your watch is an automatic, you would have to be very carefull to make sure no dirt or contaminants entered the watch.
However, I'd recommend thath you have it looked at by a professional - the watch is supposed to be water-resistant to 50 metres but there is moisture inside which suggests that the seals have failed.
Jun 25, 2015 | Fossil Watch Style # ME1026 Watch for Men
Help my daughter bought me a puma hart rate watch ? Can't set it ? No directions?
This is the car and truck category. Please repost in correct category.
Jan 23, 2015 | Watches
I bought edifice casio watch and when i use while washing hand the water goes inside at the first moment ???
unless it is waterproof you should remove electronics before going near water....
even water proof and water resistant electronics can get hairline fractures that will allow water to seap in.
once wet it will stop working.
BUT - - if you dry it thoroughly and replace batteries (if they also got wet) it can work again but you must be sure all water is dried before returning power to machine
as an example, a CRT tv i owned years ago was submerged in water for a while... of course it no longer worked.
but after three days of having a fan blow air over it it was completely dry and again worked
WARNING: only works for CRT tvs the flat screen tvs likely will allow water to seep into the screen so while you think it is dry it is still wet in the screen
Jul 02, 2014 | Watches
How to prevent water leaking inside,after replacing the batteries.. should i replace the gasket to? after replacing the batteries....
Normally gasket has not to be replaced after battery change.But all depends of the use.For example if you wear the watch in salt or pool water and never flash it with fresh, clean water after,it may be a cause of gasket wear.Remove the back cover.Replace all 4 batteries(be sure first that you can do this with extreme caution as all parts are tiny).Remove gasket.Check gasket condition(cracks,gasket too dry and hard).If gasket OK, apply a small amount of special silicon compound for watch gaskets,all around and to all sides of the gasket,put it back in place,carefully.Be sure that gasket is set correctly all around.Put the back cover in place and screw with much caution (not too tight-a little resistance).Your watch now normally is water resistant.But if you want to be 100% sure,take the watch to a serious repair center where it will be tested under pressure ( 3 Atm average).Then they will tell you if your watch is 100% water resistant.
Oct 11, 2010 | Casio PRG-40T-7 Pathfinder
I just bought a fossil watch ch2331 and need to remove a link. how do i do it?
Some of the links are removable on this watch & some are not. Look inside the band you should see some tiny arrows on the removeable links. You need to push the pin through in the direction of the arrows & remove the link. Then to put the band back together you need push the pin through in the opposite direction of the arrow. Make sure the widest part to the pin goes in last or it won't fit.
Mar 09, 2008 | Fossil CH2331 Wrist Watch
Watches Logo
67 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
