Question about Samsung Refrigerators
What is a 41 C error code after the PC CH code flashes and you try to reset using the cool select and energy saver buttons on a Samsung fridge?
Bad temp sensor
jgwhomeequip
  • 1902 Answers
SOURCE: Have a kitchenaid dishwasher KUDS25SHWH1 - the
Unplug the unit for 15 minutes then plug it back in. This should reset all your computer system and make everything work again
Posted on May 28, 2009
  • 212 Answers
SOURCE: Amana energy saver not keeping fridge section cool enough. HELP!
if there is frost build up on rear wall of freezer section the unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow to the fresh food section. one of three things are bad. defrost heater, defrost thermostat or defrost timer. if no frost on rear wall you might be low of freon.
Posted on Jun 24, 2009
erpaalai
  • 999 Answers
SOURCE: kitchenaid KUDS25SH
Hold the button down until it beeps and the light goes off. Eric
Posted on Sep 03, 2009
SOURCE: the kitchenaid dishwasher (model KUDC25CHSS1)
On my unit, I had the same problem (child lock LED on, or flashing.The cancel process of pushing anything was not possible, as a bad/stuck switch prevented any input from the control panel buttons.
The underlying cause of the problem turned out to be a faulty switch associated with the "Light China" button. I determined this by removing the control panel from the door and using a digital multimeter with OHMS and DIODE settings, was able to check each individual push-button switch using the following table to check the 12 switches (applies to the KUDC25CHSS1 model).
There are 2 ribbon cables, it is the larger of the two cables you need to check. Pin 1 is noted on the ribbon. You can use 2 normal sized paper clips to insert into the ribbon cable and make your connections. (My Ohm meter has aligator clips on its leads which helps a lot...maybe another set of hands would help if you don't have these kind of leads).
-Using OHMS: the reading should be infinite (open circuit, so no reading/no connection inside the switch) when not pushing the button, otherwise you will receive a reading when you push the switch.
-Using DIODE/beep: Ensure polarity is followed in the table below. When connected, pushing the associated button will cause a beep to occur, otherwise there will be no beep and no reading.
+Positive Lead -Negative lead
Antibacterial Sw 13 3
Rinse Only Sw 13 2
Light China Sw 11 2
Normal Switch 13 4
Delay Switch 11 4
Energy Save Dry 13 5
Cancel 12 5
Start 11 5
Soak & Scrub 12 6
Super Scrub 11 6
Short Wash 12 4
Sani Rinse 11 3
All my switches checked out OK, except for the "Light China" switch. On the OHMS settings I was never able to measure an open circuit for that switch, which means the switch was always closed. or connected.
I noticed that "Light China" was pin 2 and "Rinse only" also used pin 2, which happen to be cycles I never use. With power turned off, I carefully removed some of the plastic surround of the matching connector on the Control Board right next to it's associated Pin 2 all the way to the bottom. Then I carefully bent over pin 2 as close to the connector base as possible. Making sure all the remaining pins were straight, I plugged on the control panel ribbon cables and all is well again.
Prior to trying this I was resolved that I needed to buy a new dishwasher because I wasn't going to pay over $350 for a new control panel. Instead, I eliminated 2 unused cycles at no cost, and maybe I can get some more use out of this dishwasher.
Posted on Aug 02, 2010
SOURCE: Samsung RM255LASH - flashing error code 98 a8 after power glitch
Just happened to me with a power flash- fixed it by pressing and holding the Freezer and Frig buttons together until the screen flashed and reset. Wheww! Though it was a gonner! Fine now:) Hope it works for you!
Posted on Nov 25, 2010
I leaned against control panel and now it reads 0 FF
Samsung Refrigerator OF OF Code On Display - How To Clear ...
https://removeandreplace.com/.../samsung-refrigerator-of-of-code-on-display-how-to-...
Oct 6, 2016 - When your Samsung refrigerator shows the OF OF or OFF code, here is how to reset it... 1 - Press the POWER FREEZE and the FREEZER buttons at same time. 2 - Hold the 2 buttons for 3 to 5 seconds. 3 - This will reset the refrigerator back to normal and the fridge will begin cooling again.
How to Turn Cooling Off Mode On/Off (RF4287) - Samsung
https://www.samsung.com/us/support/answer/ANS00048861/ To disable Cooling Off mode, touch and hold the Energy Saver and Power Freeze on the display panel simultaneously. Continue holding until you hear a distinctive chime sound and both temperatures for the freezer and fridge are displayed.
Apr 22, 2018 | Computers & Internet
How do I get my Samsung fridge model #rs25hs5000bc off demo mode? I tried holding down energy saver and power freezer but doesn't work.
IT is three buttons not two. Cooling Off mode (also called Shop mode), is designed for use by retailers when they display refrigerators on the shop floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and the refrigerator and freezer do not get cold. To start Cooling Off mode, press and hold the Energy Saver button, the Freezer button and the Lighting button for 5 seconds during normal operation. The refrigerator chime sounds and O-FF appears on the display. To cancel Cooling Off mode, press and hold the Energy Saver button, the Freezer button and the Lighting button again for 5 seconds, until the chime sounds. Cooling Off mode is only available on refrigerators sold in the U.S. Instructions are on page 20=> HERE
APPLIANCE911
Apr 12, 2016 | Samsung Refrigerators
Model RB215LABP reset temperature display after power outage
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
Dec 22, 2015 | Samsung Refrigerators
How do I reset blinking code, 33 E, on Samsung French door fridge after power outage?
33 E code, hold energy saver button and the lighting button at the same time for 6 to 10 seconds
Oct 13, 2014 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
Samsung RM255lash stopped cooling
As long as you haven't unplugged it you can run it through diagnostics for error codes press the energy saver and lighting button at the same time until the screen flashes and a code should pop up
May 08, 2014 | Samsung RM255LASH Side by Side...
My refrigerator shows a code "OF" or "0F" where the temperature settings usually show, we tried to put the temperature settings back but couldn't. We unplugged the refrigerator to reset it but it sti
Cooling Off mode (also called Shop mode), is designed for use by retailers when they are displaying refrigerators on the shop
To start Cooling Off mode, Touch and hold the Energy Saver button and the Power Freeze button for 3 seconds during normal
operation.
The refrigerator chime sounds and the temperature display flashes OF OF.
To cancel Cooling Off mode, Touch and hold the Energy Saver and the Power Freeze buttons again for 3 seconds.
Source: http://downloadcenter.samsung.com/content/EM/201104/20110414114919054/110323-QS_Guide-POLARIS-EN.pdf
Dec 30, 2013 | Samsung Real Stainless Steel 30 Cu Ft Side...
Samsung Refrigerator Error Code 1E or IE
I'm not sure what all the wild goose chase answers are all about, but you guys are WAY overthinking this and not solving the problem. I'm a 45 year old stay at home mom, decidely and possibly forever "un-handy". The solution is simple, as I just administered it this morning after a self-imposed power outage: Press the "Energy Saver" + "Lighting" button simultaneously for 3-5 seconds and you should be back in business. When this happened on a previous occasion, we had a repair guy come out, although the fridge was operating perfectly bc we weren't sure if that error message was indicating something important. Well, I felt like a schmuck when the guy showed me how to reset the panel (and we were both a bit irritated that phone tech support didn't do a better job of level 1 troubleshooting). So there it is...if your fridge is working fine but showing 1E, press Energy saver + Ligthing at the same time (you may need a flashlight since the panel will be dark).
Aug 20, 2012 | Samsung RF4287HARS French Door...
Samsung side by side RFG297AAWP display shows 88 88
Press and hold the energy saver button, and the lighting button at the same time until it beeps and clears, 10 seconds. When it goes back to normal panel do the same thing again which will put the fridge in a running diagnosis mode and see if any parts of the 8's are flashing, if so look on the back of the fridge at the error codes.
Nov 24, 2011 | Samsung RFG297AAWP Side by Side Bottom...
Refrigerators Logo
63 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
