Question about Samsung Refrigerators
Samsung refrig ice maker and water supply doesn't work. What to do?
Check filter and water inlet if ok check water solenoid
roadbird383
  • 40 Answers
SOURCE: Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Posted on Dec 05, 2007
SOURCE: Ice maker not working
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
Posted on Mar 08, 2008
SOURCE: Samsung Ice Maker on Mdl RB215LASH
ice maker fill line frozen up
Posted on Apr 07, 2008
TJBENGR
  • 121 Answers
It is quite possible the water line near the ice-maker is frozen. I would try a warm hair drier to thaw it out.
Posted on Apr 21, 2008
I recently had trouble with both my water dispenser and my ice maker. I determined that my filter was clogged, so I replaced it. That fixed the water dispenser but the ice maker still wasn't working. I investigated further and found that the water inlet tube was frozen solid. Aparently, when the filter was clogged the water came in so slowly that it froze before it got to the icetray. I tried pouring hot water over the inlet tube to melt it and it mostly worked, but there was still some ice in the tube further back where I couldn't reach. Finally I defrosted the freezer so all the ice could melt and turned it back on and now it works great! Hope this might help.
Posted on Mar 31, 2009
Samsung refrig, side by side, won't eject ice. How do I turn off the left hand light to quit ice?
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
If your ice maker doesn't make ice, check out these expert do-it-yourself ice maker repair ... W. Branner Side by side GE fridge, stopped dispensing ice both cubed and crushed. ... But now that it's cleared the motor won't run to dispense any ice (water .... Our Samsung French door ice maker is not working & is making noise.
Jan 01, 2016 | Samsung Refrigerators
LSC27926ST REFRIG/freezer. Ice maker is leaking water that freezes on items in freezer, ice is messed up and had to unclog ice maker. Still a logjam of ice around ice maker. has been churning out ice...
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn't take much to eventually block the fill tube.
Sep 10, 2011 | LG LFX25960ST Stainless Steel French Door...
No ice, water does not fill ice maker, but water flow is OK.
if Ice maker cycles and you get no water into it you have a clogged/frozen fill tube. If a broken line the water would go on your floor every 15 min. None of those indicates your refrig valve is bad. Dual solenoid water side works Ice doesn't.
Aug 13, 2011 | Maytag MSD2756GES Side by Side...
No water entering ice maker.
Replace the solenoid valve , the piece the wall water line connects to , on the refrig . With both ice maker AND valve replaced , that is the complete ice production new .
Jan 01, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
I have cold water but the ice maker is not working, there is no water in the ice maker
The refrig has 2 coils on 1 valve . 1 coil is for water dispensor and the other is for the ice maker . You need to replace the water valve behind the refrig . This is the piece that the wall water line connects to on the refrig .
Oct 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE adora side by side refrigerator DTL181C5RRBS
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker won't work
Check your wiring to the timer motor. UNPLUG IT
Take off the cover look for any loose wiring. If all the wiring is in place you may have a bad timer motor.
Jun 28, 2009 | Samsung RS2630WW Side by Side Refrigerator
Apr 21, 2008 | Samsung RB215LASH
Refrigerators Logo
87 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
