Question about Konica Minolta Office Equipment & Supplies
How do i fix touble code c-1196 on konica minolta c754e fitted with fs-535.
All jams have been cleared (even from inside the folder) but i'm still getting this trouble code. i've also tried re-setting by holding down the Rset button and powering on and off, to no avail.
  • Konica Minolta Master
  • 6,850 Answers
Tri-folder motor malfunction. or bad motor
Posted on Feb 18, 2019
SOURCE:
  • 48 Answers
SOURCE: KONICA MINOLTA magicolor 2490MF paper jam. It
I believe the duplex door is in the back of the printer.
Posted on Jun 01, 2009
firecontrol7
  • 6850 Answers
SOURCE: Konica 7022 with Problem code F-26-1
There is toner/starter spilled onto a sensor near the drum, it mite just need to be cleaned, this sensor monitors the drums abililty to develope a image, if the cleaning does not work it mite be the sensor or the drum. The drum needs to be removed to clean the sensors.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Aug 01, 2009
SOURCE: Konica 7022 (code F-26-1) Pls call service 0870-2425050)
i have a konica 7022 it say call service code F-35-3, what's wrong with it, help me.
Posted on Sep 25, 2009
SOURCE: machine trouble call service c0500
Try to power it up with the STOP button pressed.
If not call service team.
Posted on Oct 10, 2009
  • 7 Answers
SOURCE: PRINTER TROUBLE CODE C-0210 KONICA MINOLTA
on previous models with this code check that there is no paper caught behind the tray open and close door to clear code
Posted on Mar 04, 2010
Sir I have Biz hub konica minolta 601 and he show me a trouble code c-2804 kindly solve this matter
Remove the drum and clean the two sensors facing the drum one is white the other is clear, DO NOT use a wet rag. clear one monitors for a paper jam the white one monitors the drum
Nov 09, 2017 | Konica Minolta Office Equipment & Supplies
Konica minolta c650 error code c-0105 clear
check the paper trays 3 and 4. jam paper behind the trays????
Jan 01, 2017 | Konica Minolta BizHub C650 Copier
Konica Minolta BH164 Copier gets paper jam in LGL and FS size papers only what to do
then place the LGL and FS in tray one does it work??? is this printing or copying???
Jul 11, 2016 | Konica Minolta Office Equipment & Supplies
Why do i get a error code c1105 on my bizhub c554e and how do i fix it
Sorry your having trouble. Your code suggest you have an optional KM FS-534-535 finisher attached to your copier. The code is triggered by an internal part within the finisher and should be thoroughly inspected only by a certified factory trained service technician. I would suggest you contact your local repair company.
Attempting to resolve this issue on your own could produce negative results.
May 31, 2014 | Konica Minolta Bizhub 222 Black and White...
Konica Minolta Bizhub c754e Blue Lines after installing new machine
The blue toner cartridge or drum are damaged. First, try a different toner cartridge. This will probably eliminate the lines.
Apr 08, 2014 | Konica Minolta Office Equipment & Supplies
C11-32
The issue is with the punch unit. It may have a bad connection. It may also be something stuck in the paper detect sensor or the sensor is broken. All possibilities are with the punch kit.
Feb 18, 2014 | Konica Minolta bizhub Office Equipment &...
Konica 7140 gives error code fs516 what is this
FS -516 is the finisher that part of the copier that staples hole punches etc,
Apr 21, 2011 | Konica Minolta Konica-Minolta 4599161...
Konica Minolta Magicolor5440DL Error Code
error 0094h = 2nd image transfer pressure/retraction failure
basically it means that either a sensor or cable is not fitted supposedly and reseating could possibly solve the issue.
you can research the error code in the following service manual:
http://printer.konicaminolta.com/drivers/other/Manuals/5400/smfs_54.pdf
Mar 09, 2010 | Konica Minolta magicolor 5440 DL Laser...
In Konica Minolta 2430dk, I had a media jam in the fuser. I cleared the visible paper, but there is still some stuck inside the fuser that is impossible to clear (I can't get my fingers to it), so printer...
The only solution is to take the fuser unit out of the printer, then you may be able to manually rotate the rollers to clear the jam. If there are any marks or scratches on the fuser rollers, you will need to replace the fuser unit, or you will get marks on your prints
Jun 21, 2009 | Konica Minolta magicolor 2430 DL Laser...
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
114 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
