Doesn’t spin counter clockwise and doesn’t go into fast spin
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 164 Answers
What are we supposed to do with this little bit of info?
Posted on Nov 04, 2018
Stop Wasting your time on searching online check this website for help iVapeUK
Posted on Jan 02, 2019
  • 1462 Answers
SOURCE: PAV2300AWW tub spin on wash cycle
fault may be tacho on motor fallen off or round magnet that turns inside the tacho coil has become unscrewed. remove motor and check tacho. it is located at opposite end to the belt pulley
Posted on Sep 07, 2008
  • 217 Answers
SOURCE: doesnt agitate and there is a gronding noise during wash and spin
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth  is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.
Maytag Dependable care washer.....Locate a 1/4 inch screw on the side of the agitator, ( about 3/4 of the way down) remove this screw and lift up on the agitator...picture.
Maytag Atlantis, Norge, Performa by Maytag.....Remove the cap and softener dispenser by pulling it off and locate the agitator bolt, remove bolt and lift up on the agitator...picture.
Water level controls - The water level control is also know as a pressure switch, this is where you set the water level ( small - medium - large ). The water level control is responsible to shut off the power to the fill valve and direct that power to the timer so the washing machine can start up. The WLC has electrical contacts in it that sends power to the fill valve and when the WLC is satisfied the water level is correct the electrical contacts open power to the fill valve and send the power to the timer and the washer starts. Picture of this here. How the water level control knows when it is time to shut the water off is, a air tight hose runs from the outer washer tank to the water level control. As the water fills the outer tank air is pushed up the hose, depending on which setting you have made ( small- medium - large ) is takes a certain amount of this pressure to make the WLC cycle over and shut off the water and send this power to the timer. If this hose develops a leak or a pin hole the washer can over fill as the WLC may not be able to shut the water off. The water level control can also break down and allow the washer to over fill as well.
Testing a  water level control or a fill valve can be done by using a Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter.
A couple of tips from readers (Thankx!! ):
~ If you have a loose hose on the water level control or tank end, use a plastic wire tie to help hold the hose tighter and make a tight fit.
~ The water level tube (tube that runs from the square box), access panel on the outer drum where the bleach tube also ends) from the pressure sensor switch (front panel) can become clogged.  Or the two holes from the outer tub into this square box panel on the outside of the outer tub can become clogged. Either clog, I am told by my help repair guy can cause the sensor to think that there is still too much water in the tub and so will not allow motor to activate spin.
~ If the water level control contact is bad, it may also stop the filling ok, but not tell the washer to start agitating.
Posted on Nov 29, 2008
  • 198 Answers
SOURCE: dryer spins counter clockwise
When installing new belt the belt comes off the right side of the drum and through the idler and around the motor shaft, then up the left side
Posted on Jan 07, 2009
mickey813
  • 472 Answers
SOURCE: I have a toro 521 snowthower. The throttle slides
turn it clockwise
Posted on Oct 16, 2009
  • 107 Answers
SOURCE: which way does a whirlpool dryer spin? clockwise
They Spin Clockwise.
Posted on Dec 01, 2009
Why do the left propeller on aircraft spin clockwise and the right engine spin counter clockwise?
Its easier to control the airplane with that balance, a twin like that would be easier than a single for the same reason that the prop rotation makes the plane easier to turn to one side than the other.
Jan 04, 2017 | Aircrafts
Why does my ceiling fan 897 only spin slowly
If it has chain controls, one changes the direction, Clockwise, Counter clockwise. The other one alters the speed in 4 pulls, from OFF, SLOW SPEED, MEDIUM SPEED, FAST SPEED, and back to OFF. If there are three chains, the third turns the light on an off.
Sep 19, 2015 | Dryers
Chopper spins clockwise . How do I fix it
It is spinning around because one of the rotors is not spinning at full speed. This happens when you bump a spinning rotor against something. Determine which one it is by observation or logic (i.e, the one that turns clockwise will produce counterclockwise torque, which is to be balanced by the other rotor spinning counter clockwise. So the counter clockwise spinning rotor is slow) Tighten the screw that holds that rotor that is spinning more slowly. Use the screwdriver that came with the spare parts.
Dec 15, 2011 | JCPenney Gyropter RC Helicopter
Which way should the line be fed clock or counter clockwise. Spins clockwise.
I,m no expert but you could try feeding it the oppisite way it spins. so i would say counter clockwise. if not it,s 50/50 it must be the other way
Jun 28, 2011 | Homelite Curved Shaft Trimmer Bump Feed...
I have a Maytag Model A412, series 11 washing machine. After the machine fills with water the machine appears to start its cleaning cycle but the agitator doesn't work. The water starts & the...
if this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
Jun 08, 2011 | Washing Machines
Dryer spins counter clockwise
Jan 07, 2009 | Whirlpool LGV4634JQ Gas Dryer
Front load drive motor on Kenmore washer will only turn the drum in a counter clockwise direction an there is no fast spin
you could have choosen the gentle care mode or delicate mode where in it would only run in one direction and would spin slowly.
tnx 4 using fixya,
drcool
Jul 28, 2008 | Whirlpool Washing Machines
Mar 24, 2008 | Bosch WFLI 2440 Front Load Washer
Washing Machines Logo
1,493 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
