Question about Brother Sewing Machines
Have a problem with f05 error speed sensor on a brother machine
Brother machine innovis 950
  • 4,345 Answers
The start/stop button was pressed without connecting the foot controller while the setting for adjusting the stitch width using the sewing speed controller is set to [ON].
You have selected a pattern for which width control cannot be used.
Posted on Jan 12, 2019
SOURCE: I have a Brother Innovis
I know this isnt of much help but my manual says that any errors starting with F is a sign of malfunctioning and should be taken in to a service center. Wish I could help more.
Posted on Oct 29, 2008
SewTechWayne
  • 186 Answers
SOURCE: error on Brother Innovis 4000d sewing machine
You probably need to take it in for service. Thread guide pulse motor (TG-PM) is jammed with thread. There is a new shield that that can install to keep this from happening again.
You can gently try to move it with the machine on and see if that works, it is the little shuttle that goes up and down on the front of the machine, it is probably stuck where you can see it.
good luck!
Posted on Jan 31, 2009
  • 1116 Answers
SOURCE: How do I replace a broken spool pin on the Brother
If the spool pops in, you may be able to find a replacement where sewing machine parts are sold.
If it was a molded to a platform, a thread stand may be a less expensive method to use. You can find a single cone thread stand with sewing notions.
http://www.sewingmachine221sale.bizland.com/store/page24.html/
Posted on Mar 29, 2010
SOURCE: I have a Brother innovis 4000d sewing and embroidery machine. The embroidery pattern l am trying to sew has worked really well in the past, but now when it starts to sew it is not picking up the botto
try changing the needle
clean under the needle plate & in the bobbin area for loose threads or lint
rethread the machine top & bobbin
Posted on Apr 27, 2012
Testimonial: "Thanks so much for the help :)"
  • 12 Answers
SOURCE: brother pe-770 f05 speed sensor error - How to fix?
F05 error, speed sensor. I fixed successfully 2 of those. Speed sensor is located on a small board, under a protective plastic, located over the main front board. Remove front panel and bobin winder assembly. Remove the 2 screws of the small board. Remve CAREFULLY the small bord. Under, on the main shaft, are located the needle positionning sensors and the wheel of the speed sensor (left wheel on the shaft). The speed sensor is located on the board itself, it's very small. Clean carefully both the wheel and the sensor with Q-Tips and alchool, reassemble the whole thing and it should restart.
While U are there, take a thin nozzle oiler and lubrificate all the suppots of upper and lower shaft, all the needle bar mechanism and rotary hook central shaft and gears WITH VERY THICK oil. Needle bas assembly is the most critical point. I have 14 of those machines, almost all of those seized there before I learn how to lubrificate it. Also seized on the bottom shaft and on rotary hook pin
Posted on Jul 05, 2012
My brother sewing machine LB 6800 is showing FO5 speed sensor error what can I do to fix it
You may need to get the sewing machine serviced; the repair must be handled as if you are fixing a computer. The F05/F5 error indicates a problem with the timing shutter, the PCB board or the wiring between them.
If you are going to try this, first unplug the machine and check the wiring. Next clean the timing shutter if the wiring is undamaged. Replace the timing shutter if the error recurs. If the machine still gives the F05 error, the PCB board has to be replaced.
Some of the parts for the Brother LB6800 are here: https://www.sewingpartsonline.com/brother-lb6800-sewing-machine-parts.aspx?sort.ss_cat_sort=desc&index=157.
I hope this helps.
Sep 29, 2018 | Brother Sewing Machines
Speed control not working
Brother, unlike some companies, has terrific service and support. Their site is here, just pick the country, I'm sure they will be able to help you. I've never had anything but top notch service from Brother.
http://support.brother.com/g/b/countrytop.aspx?c=ca&lang=en
Oct 02, 2016 | Brother InnovIs QC1000 Electronic Sewing...
F05 speed sensor
Make & Model ??
Feb 28, 2014 | Sewing Machines
Malfunction error PF-PM on Brother Innovis 4000D. HELP!!!
try unplugging it and letting it rest for 20 minutes? Sometimes that will reboot it.
Dec 10, 2013 | Brother InnovIs 4000D Computerized Sewing...
Brother pe-770 f05 speed sensor error - How to fix?
Jun 26, 2012 | Brother PE770 Computerized Sewing Machine
Sewing Machines Logo
142 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
