Question about Brother Sewing Machines
I have a brother sewing machine cs6000i problem. I receive an E-6 error code, even if I remove the top and bottom threads. The motor makes a terrible noise with or without thread. Help! Monica
  • 4,345 Answers
Hi there
Q: What does E6 error message mean? A: The motor locked up because thread is tangled Q: How to fix E6 error message? A: Do the following:
  • The upper thread could be tangled. Remove the upper thread and any loose threads. Raise the pressure foot, raise the needle to its highest position and rethread the machine.
  • Remove the bobbin and bobbin case to clean any lint or loose threads. Install the bobbin case so that the projection on it aligns with the spring. Then install the bobbin into the bobbin case.
  • The needle could be bent. Replace the needle making sure the flat side is facing the back.
All best take care Clive
Posted on Jan 12, 2019
5 Suggested Answers
SOURCE:
  • 1116 Answers
SOURCE: bobbin thread won't engage.
The bobbin case is not in the shuttle.
Raise the needle to it's highest position.
Lift the lever on the back of the bobbin case and hold it open as you insert the case into the shuttle; arm on the case pointing up. You may have to turn a bit to the left or right - it will click when in place.
Posted on Mar 20, 2010
SOURCE: E6 error code on cs6000i
it's possible that it's a mechanical or electronic problem or something has worn or is loose, it needs to be serviced
Posted on Feb 09, 2012
  • 1564 Answers
SOURCE: I have a Brother CS6000i sewin machine and I'm
Mmmm Are you using the right stitch? Like zig zag or straight stitch only with a medium stitch length? Check that and test again.
Posted on Sep 07, 2012
SOURCE: brother NX400 SEWING MACHINE after changeing thread top and bottom it now makes a nocking noise?
try rethreading the machine again, make sure to use every thread
guide
make sure to not over fill the bobbin
make sure the bobbin is inserted correctly into the bobbin
case, this is very important
make sure the bobbin is turned the correct way in the bobbin case
the machine won't work right if the bobbin is not turned the right
way
clean under the needle plate and in the bobbin area for lint
Posted on Nov 02, 2012
Brother cs6000i thread tension issue
Logically, the top thread should not be affected by a walking foot as the thread operates independently of the presser foot.
Suggest removing the top thread totally from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Check that your walking foot is installed correctly--the fork-shaped piece needs to encircle the needle clamp screw.
If you continue to experience problems with the walking foot but none of the other feet, recommend contacting a Brother technician.
How do attach the walking foot Brother
Jun 26, 2017 | Sewing Machines
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Dec 21, 2013 | Brother CS-6000i CS6000i 60-Stitch...
Machine is showingE6
The motor locked up because the thread is tangled. Remove the tangled thread before continuing the operation.Clean the bobbin case to remove the tangled thread. After cleaning the bobbin case, insert the bobbin case properly. If the needle is bent or broken, replace the needle.Then, thread the upper thread properly, and continue the operation.
Sep 22, 2012 | Brother CS6000i Computerized Sewing...
Sep 06, 2012 | Sewing Machines
Thread keeps on bunching up on the bottom side of the fabric
try changing the needle
check the top thread tension to make sure it's not to loose
rethread the machine top & bobbin, make sure the bobbin is wound
correctly & inserted correctly into the machine
make sure the thread has not come off the thread take up lever
Jul 11, 2012 | Brother CS6000i Computerized Sewing...
Feb 06, 2012 | Brother CS6000i Computerized Sewing...
My sewing machine will sew for about 2" and then
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000470/bc21es20cs60ce50ex66xr6677ug10en.pdf
Above is a link to the PDF file for you sewing machine.
The error message E6 is The motor locked up because the thread tangled.
Solution - Remove the tangled thread before continuing operation.
Jan 17, 2011 | Brother CS6000i Computerized Sewing...
Error code 6 (thread in motor but there is none)
If you can turn the balance wheel by hand and the needle goes up and down it may be loose belts, if you can't turn the balance wheel by hand then there is definitely thread stuck somewhere in the raceway
Jun 24, 2010 | Brother CS6000i Computerized Sewing...
E1 error keeps coming up everytime I press the foot controller or start/stop button. Before this happened, the bobbin thread wasn't working. Only bunching lots of threads from top underneath cloth.
E1 means that the main motor is working to hard so the machine is keeping you from burning it up, make sure the handwheel feels smooth when turning if it doesnt clean your hook area and take the side cover off and make sure no thread is caught in the take-up lever
Jul 11, 2009 | Brother CS6000i Computerized Sewing...
Sewing Machines Logo
105 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
