Question about The Computers & Internet
So o bottle of water spilled on my decoder and it’s the primary decoder I switched it off and used a hair dryer to dry out the water switched it on .nw it’s showing a red exclamation mark and on the tv it’s showing nothing as if the tv is not connected to the decoder. What do I do ????
    Top Expert:
  • The Master
  • 53,736 Answers
Get a new decoder
Posted on May 22, 2018
t00nz
  • 4738 Answers
SOURCE: water spilled on camera
First try the obvious, and press your DISP button once with the camera turned on. If that doesn't work, next thing to try would be to reseat the LCD ribbon cable into its connector. This is not too difficult, but it does require opening up your camera. But before proceeding, note that the camera still takes pictures at this moment. There is a possibility that something might go wrong, and the camera will no longer be operational after the repair. Please remember that it's ultimately your decision to proceed with a repair.
The following webpage describes disassembly of the A520/540. If you decide to repair it, only proceed as far as the first two pictures to remove and then reseat the cable. Follow the LCD ribbon cable to where it connects to the circuit board. There should be a connector with little hinge points that you lift with your fingernail to unseat the cable. Clean and dry the exposed end of the cable with a Qtip with a single drop of rubbing alcohol. After thoroughly drying, reinsert the cable into its connector and push down on the hinge points to reseat it. Then reassemble the camera:
http://photography-on-the.net/forum/showthread.php?t=251630
Also please note that there is a risk of electrical shock. Please read the following to learn how to mitigate this risk:
http://camerarepair.blogspot.com/2007/11/important-warning-camera-flash.html
Posted on Feb 10, 2008
michigan man
  • 3533 Answers
SOURCE: LS400 1996 red warning light on dashboard
if you do not have an owners manual here is a way to get one online:
www.edmonds.com
check under instrument panel
Posted on Mar 08, 2009
SOURCE: new Saeco Odeo Go has solid red exclamation mark, doesn't budge
You have to 'manually' prime the pump: When the red exclamation mark shows, press the water switch on the right side (the picture of the water drip), then open up the steam nozzle and let the machine pump hot water into a cup until the red light goes out.
Posted on Aug 23, 2009
MUKHTAR
  • 2022 Answers
SOURCE: my HP 6110 printer is non-responsive
just replace the catridge and see.
Posted on Sep 09, 2009
  • 113 Answers
SOURCE: My HTC Wildfire is showing
It usually happens to me during text messaging. It means your messages is not sent. You can view the list at "Undelivierd Messages" (Go to Messages, then Menu->Undelivred). Make sure you have a load balance and a good signal, and retry sending.
Posted on Jun 18, 2011
Water spilled on the display
Not sure exactly what happened but I do know if anything wet spills on anything electronic... computer, tv, cell/mobile phone etc, I've gotten them all to work by pulling panels apart(when possible) and letting dry out and sometimes drying it with a hair dryer. Item should be left out to dry for quite a few days. Do not do this with any current hooked up.
Aug 05, 2013 | Televison & Video
How can i make my ds lite work after a spilled water on it
first of all take the battery out disasemble as much as posible take covers off use air to blow inside and dry leave over night upside down
use cilica to absorb moistrure if you have any leave in a dry warm enviroment use a low hair dryer all these might save it test next day see if comes alive
Jul 24, 2012 | Nintendo DS Lite - Onyx
Wife spilled water in micro model jes1651sj02 blew breaker dried spill some water still inside
Remove and use a hair dryer to dry the boards, it is important that ALL the water present within the board must be dried out.The board also can be removed and dried
Please check this link: Water in set
Jul 05, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
After my daughter spilled water on the keyboad the laptop won't turn on. any ideas? thanks ely
you could try drying the laptop keyboard using a hair dryer or use a fine air blower from a compressor making VERY sure there is no MOISTURE in the airlines make sure you have the battery disconnected when you dry it out and clean the terminals before you plug it back in
(dont get it to hot if you use a hair dryer do it a few times and let it cool down before drying it again)
hope this helps
Apr 03, 2011 | Computers & Internet
I spilled a bottle of water on my shift console. Our tempratures dropped and my automatic shifter is froze. Do I need to take my car to a mechanic for a fix?
You shouldnt need to, the only electronics located on the shifter are for the illumination. You should be able to heat it up with a hair dryer enough to move the shifter then dry as much of the water as possible.
Jan 22, 2011 | 2000 Plymouth Neon
Water
it depend on how you spill it,is it really soaked or just a litte wet?
remove the battery and dry it with a hair dryer it help
Jul 05, 2010 | LG CHOCOLATE VX8500 Cellular Phone
I need to know how to remove the keyboard so i can clean it. i spilled a little beer on it! and some of the keys are not working properly
Turn it off remove the battery get a spray bottle fill it with destilled water turn the keyboard upsidedown over a clean towel spray the keyboard till it drips clean;meaning the drops of water are clean. When finished spraying, Dry with a hair dryer for 30 minuts on low heat let set on clean dry towel for 12 hrs Check for resisual moisture. If any repeat drying proceedure. let set another 12 hrs on clean dry towel
till dry replace battery fire that muther up
way simpler tham removing the keyboard and cleaning it.
best of luck
May 20, 2010 | Computers & Internet
Viking gas cooktop vgsu161-6b sparks continuously. There is no gas leaking. I spilled water on the controls and it is only when I turn on the 3rd knob from the top that this happens.
The water that you spilled onto the cooktop has shorted out the ignition switch in the gas control knob. Don't worry though no permanent damage has been done. Leave it unplugged from the electrical outlet for a day or two until the liquid dries out. You can manually light the burners with matches or a BBQ lighter in the meantime. If you want to try and speed up the drying process you can use a hair dryer.
Oct 20, 2009 | Viking 37 in. VGSU161 Gas Cooktop
I spilled some water on my tv and now the sound is broken
Turn the TV off imediately. Remove the back cover and heat up the wet area with an hair dryer to thoroughly dry the board. Then try tv again.If it doesnt solve the problem look for the board that the speaker wires connect to and replace that board..You should be able to buy online.
Oct 17, 2009 | Insignia IS-LCDTV32 32 in. Television
Laptop starting issue
Did you spill the water while you were using it or turn it on shortly after the spill? If so, you fried something. It's electronic, it doesn't mix with liquid at all, you're lucky you don't have a nice expensive door stop, use a bottle with a screw on cap if you absolutely have to have a drink while working with your laptop. Also it takes days, if not a week, for a laptop to completely dry out inside, a dryer isn't going to do much good unless you take it apart. Either deal with the issues or take it to a shop and have it diagnosed. It's going to be a hardware issue consisting of the motherboard.
Jun 22, 2008 | IBM ThinkPad T42 Notebook
Computers & Internet Logo
131 people viewed this question
Top The Computers & Internet Experts
Inky Fingers
Inky Fingers
Fred Sops
Fred Steinberg
Fred Steinberg
Level 1 Expert
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
