Question about Konica Minolta Office Equipment & Supplies
How do I rest a drum on konica minolta C554e
I have replaced a drum on Konica Minolta C554e but its still showing replenish drum unit
  • Konica Minolta Master
  • 6,850 Answers
Then the drum you replace is not new there is a chip on it which tell the copier its new
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Mar 04, 2018
SOURCE:
  • 118 Answers
SOURCE: Konica Minolta Magicolor 2400W drum cartrige-how to replace?
Did you buy a whole new drum unit, or just change the cartridge? If so, the fuse may still be blown. Also, you may need to empty the spent toner out of the old cartridge.
Posted on Nov 18, 2008
taminol
  • 62 Answers
SOURCE: Hi In our office Konica Minolta C250 ,it show message mulfunction. error:- c0206
C-0206 relates to tray 3.
With the copier turned on do the following
Open paper tray 3, remove paper, close tray, open then shut front door, load paper into tray 3 - hey presto!!
If the fault comes back you could have paper stuck behind the tray or have a defective lift up motor.
Regards
Taminol
Posted on May 27, 2009
  • 51 Answers
SOURCE: konica minolta bizhub
whot is the error code and whot model of bizhub u have???
Posted on Aug 30, 2009
  • 13 Answers
SOURCE: Reset Chip on Konica Minolta 8031 Imaging Unit
I can provide you with a programmer to reset the chip. They are only about $500-$700. Still interested?
Posted on Sep 13, 2009
  • 99 Answers
SOURCE: how to replace drum unit for a konica-minolta
Press left side top cover release.Open top cover,open cartridge >open drum unite.
Posted on Dec 12, 2009
Hi all. I've been having a problem with my bizhub c554e that i've been working on. which is when i change the drum core (K) and also the drum blade, the printing for (K) became not satisfiable. which is...
Black drum for the 554e is the same as the c364. Replace the drum as OEM not third party and DONT do it your self replace the whole drum from a Konicaminolta and the developer unit also
May 10, 2018 | Konica Minolta bizhub Office Equipment &...
MY KONICA MINOLTA BIZHUB 283 SHOWING MESSAGE REPLACE DRUM UNIT
have a tech come out and replace. you cant buy it. it is done with a drum cleaning blade and developer buy each part
May 27, 2017 | Konica Minolta Office Equipment & Supplies
Bizhub c224e error code 2558
Konica-Minolta bizhub C224e Code: C2558
Description
Abnormally high toner density detected black TCR sensor
The TC ratio of the toner determined by the toner replenishment control is detected to be the predetermined value or over for consecutive times.
Remedy
1 Reinstall developing unit. 2 Reinstall toner cartridge. 3 Check the connector between developing unit-FRB CN13, CN14, CN15, CN16, CN10 for proper connection and correct as necessary. 4 Check the connector between FRB CN1, CN3-PRCB CN7, CN9 for proper connection and correct as necessary. 5 Replace the developing unit. 6 Replace FRB. 7 Replace PRCB.
http://www.printcopy.info/?l=en&mod=erc&brand=Konica-Minolta&model=bizhub%20C224e&code=C2558
Aug 22, 2016 | Konica Minolta bizhub Office Equipment &...
Konica Minolta BizHub C252 - pale colors on the long side
Konica Minolta BizHub C252 Repair Questions,... - Fixya
www.fixya.com > Forum > Printers & Copiers > Konica Minolta
Konica Minolta BizHub C252 - pale colors on the long side · Konica Minolta. ... I have a Konica C250 machine which cannot print red color at all. I had changed ...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - On the right hand side of the drum (the part that has the large green handle) that easily slides out. There is a ..... I have konica minolta bizhub c252 colour printer. ... The K light came on a long time ago and is constant on now.
How to clean the drums/i units on the konica minolta number ...
? 0:28
https://www.youtube.com/watch?v=eD8HdNq0MlE
Nov 23, 2011 - Uploaded by Tennants Nottingham
How to clean the drums/i units on the konica minolta number plate printer ... Fix or repair color laser printer with fading, lightprint, or lines samsung clp 300 ... Imaging Unit Reset for Konica Minolta Bizhub C203 / C253 / C353
Dec 14, 2015 | Konica Minolta BizHub C252
Konica minolta bizhub C253 is showing me trouble code C- 2556. What should I do to pix this problem
Konica-Minolta bizhub C253 Trouble Error Codes List page 4
Code C2556
Abnormally high toner density detected yellow TCR sensor
• TC ratio in the developing machine, which is determined by toner replenishing amount control mechanism, is 11 % or more for a given number of times consecutively. • When the connector of the TCR sensor is disconnected.
Solution:
1 Reinstall imaging unit. 2 Reinstall toner cartridge. 3 M3, M4 operation check (At this time, IU must be non-installation.). 4 Change imaging unit. 5 Change PRCB
Extract from:
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Konica-Minolta&model=bizhub%20C253&page=4
Nov 14, 2015 | Konica Minolta Office Equipment & Supplies
Konica C554 printing colors faded. Doesn't need new cartridges. What can I do to fix it?
Hi Macalla,
The only thing that comes to mind is possibly the drum unit needs replacing. These machines are normally under a service contract. You should have gotten either a drum unit needs replacing message of toner needs refilling message on the screen. The drum replacement idea is just a GUESS!!. see link below
http://kmbsmanuals.konicaminolta.us/c554e/contents/id11-_101378852.html
Aug 03, 2015 | Konica Minolta bizhub Office Equipment &...
Konica minolta di3010 how can i reset drum unit?
You replace the drum and developer. Pior to that you clear counters and run the require procedures after because if you reset your drum unit without replacing it the codes will begin to show up the copier works on the counters when you clear it then the copier thinks the drum is new an set voltages as required since it is not new then you get problems . Replace the drum, cleaning blade and developer and do it right!!!!!
Dec 02, 2013 | Konica Minolta bizhub C250 All-In-One...
187 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
