Question about Konica Minolta Office Equipment & Supplies
How do I reset a drum if the machine is showing replenish drum unit after I've replaced .Its a Konica minolta
I've logged on to the service mode ,counter,life,k drum rotation but I can't find the option to reset it.MINOLTA C554E
  • Konica Minolta Master
  • 6,763 Answers
Because there is a chip on the drum to tell the copier i am new
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Mar 04, 2018
djgillstudio
  • 107 Answers
SOURCE: I just replaced the drum
hello, first did you follow instructions of reseting machine when you replaced drum, if not here is the istructions, with machine in ready state, press go button and up arrow at same time, the reset parts life comes up, use up arrow or down arrow to scroll thru to drum replacement, press the ok button when you get to drum, the machine will have drum unit ok?, press okay, machine will cycle and reset drum.
Posted on Nov 03, 2010
timeattack
SOURCE: Replaced new drum unit but LCD keeps saying Drum Near End of Life
Front cover must be open
Press The "Clear" key on the top panel
Press 1 to reset the drum count
Close the over
Posted on Feb 06, 2009
  • 413 Answers
SOURCE: How can I reset my Drum Life Counter on my Printer?
http://my.okidata.com/PP-B4250.nsf?opendatabase
Guide Users: B4250 download user manual
American English
Posted on May 07, 2009
Patzky
  • 240 Answers
SOURCE: Need to reset parts life for belt unit, replaced
Hello mstjean,
You can access the reset menu by pressing the 3 and 9 button at the same time.
Posted on Mar 25, 2010
Testimonial: "Thank you for this timely and simple solution to my problem. I never would have figured it out without your help!"
djgillstudio
  • 107 Answers
SOURCE: how do i reset drum
hello, i am going to ball park this, with machine on, open up front cover as if you are going to replace toner, press the clear button, on the display it may say, new drum press 1 for yes 2 for no, then close front cover. normally the drum comes with the instructions on this, but sometimes its missing, but also brothers web site has the info on this. i work on these alot so most of the resets are the same
Posted on Oct 08, 2010
Hi all. I've been having a problem with my bizhub c554e that i've been working on. which is when i change the drum core (K) and also the drum blade, the printing for (K) became not satisfiable. which is...
Black drum for the 554e is the same as the c364. Replace the drum as OEM not third party and DONT do it your self replace the whole drum from a Konicaminolta and the developer unit also
May 10, 2018 | Konica Minolta bizhub Office Equipment &...
How do I rest a drum on konica minolta C554e
Then the drum you replace is not new there is a chip on it which tell the copier its new
Feb 27, 2018 | Konica Minolta Office Equipment & Supplies
Installed new drums in konica minolta bizhubpress c6000 drum counter did not reset automatically. How do I reset them?
service mode then clear the counters, should have done it before installing the drums.
Oct 25, 2016 | Konica Minolta Bizhub Press C6000 Copier
Konica minolta bizhub 195 shows M2 error after changing the developer how to reset M2 error?
Did you also replace the drum, clear the developer counter first before installing the developer, and run the required F 8 procedure after the developer was installed, As the machine uses the counter to control voltages to certain assemblies, not replacing the parts and resetting the counter will cause codes and image issues.
Jan 19, 2016 | Konica Minolta bizhub Office Equipment &...
Minolta EL 1054 giving drum sign how can I reset please give me the simulation
first replace the drum, then clear the counter, machine works off the counter, clearing the counter without a new drum will have the machine set voltages to certain assembly according to what a new drums needs when in fact it is old causing image problems. to reset go to service mode stop 0 stop 01
Mar 14, 2015 | Minolta Office Equipment & Supplies
Monolta izhub 362 hwo to reset drum counter
Bh 362 is the upgrade of Bh 200, 250 and 350 and on that model you need change drum and developer together. The drum counter message can be reset in service mode by a qualified tech after replacing those parts.
Aug 23, 2014 | Konica Minolta Bizhub 362 Copier
How to solve error c0650 on minolta di2510
Did you changed the home sensor? If yes, is the sensor working properly? Try the sensor function in Service Mode.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 18, 2014 | Konica Minolta Office Equipment & Supplies
Please set replenish toner unit correcty
Replenish toner unit is the unit that is secured with two screws and comes to the right and these are unscrewed. The presence of this unit is signaled by a sensor positioned under the top cover. Check that sensor for proper functionality in Service Mode.
Jun 01, 2014 | Konica Minolta Bizhub Press C6000 Copier
I want to change the setting of my drum unit on a konica minolta C-360
Enter in the service mode by press following keys:
Utility - Meter count-Check details - Stop - 0 - 0- Stop - 0 - 1 - Stop -0 -C - setting IU life stop setting and select NO STOP.
Feb 20, 2013 | Konica Minolta bizhub C250 All-In-One...
107 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
George Mclaughlin
Clive
Clive
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
