MY dstv DSDD 1132 decoder is flashing red and green lights but yellow light is steady. tv is black and remote not responding
    Top Expert:
  • Televison & ... Master
  • 76,140 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Jan 12, 2017
SOURCE:
How do I clear error BEi or BE1 on dual view dstv decoder.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/..
Aug 17, 2016 | Televison & Video
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Apr 02, 2013 | Televison & Video
I want to couple my DSTV Decoder through my new THT-3017HDMI Home Theatre System to the TV. How do I do that? I am very much technology disatvantaged.
THT-3017HDMI to hook with TV.
Get RCA Cables, red and white from your DSTV straight to your DVD.
The Yellow (Video) Straight from your DSTV to your TV yellow input.
Set your TV to Input 1 or 2 depending on the port you used. PLease but your volume will be only controlled via DVD, if you switch your TV off it will still sound the TV channels via DVD speakers,
Sep 03, 2010 | Televison & Video
When connecting up to charge red light comes on 'power on' button on front and no charging happens - any ideas? thanks
What does indicator light mean?
  • Steady red light: Battery is charging.
  • Steady green light: Battery is fully charged.
  • Flashing red light: Battery needs charging.
  • Flashing green light: The music receiver is switched on.
  • Flashing red/green light: The music receiver is available to be added to your phone.
Aug 24, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
Need to connect my DSTV decoder through my sony amplifier (5.1) not sure of a the cabling or the connections, does someone perhaps ahve a wiring diagram to connect TV, dstv decoder and sony 5.1 amplifier?...
well this is easier than you think, get yourself a set of RCA's (the red and white and yellow cables that DVD players come with) look behind your decoder and place them colour to colour, then behind your Amp you will read (TV IN) do the same, then with just one yellow RCA plug it into (monitor) that one will then go to the (AV input) behind your TV.. And presto!!! now set your amp input on the remote to TV and your off!! good luck
Jun 29, 2009 | Fujitsu Siemens PlasmaVision P42VHA40...
Black and white dstv
look on the TV menu for (system) in south africa we use PAL, if you cant change it on the TV, with the decoder remote press menu then 7 then 4, it will ask for a pin code press 9-9-4-9 it will read "RF modulator" press OK, it will then read 1 MODULATION press ok again and it will highlight PAL I now press the right key and press OK, if this persists then the decoder it probably faulty... good luck
May 28, 2009 | Sony KP-EF61 61" Rear Projection...
Televison & Video Logo
487 people viewed this question
Top Televison & Video Experts
Ekse
