Question about Konica Minolta bizhub Office Equipment & Supplies
Konica minolta bizhub 282 c2557 code appears after F8 ran and new related parts were replaced?
Developer and drum unit replaced and relevant counters cleared F8 ran code still appears and F8 is done could this be firmware related?
  • Konica Minolta Master
  • 6,825 Answers
Did you replace the developer unit along with the new developer? mite have bad ATDC sensor bottom of developer unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Oct 02, 2016
Como solucionar el c2557 de la konica minolta 282
When was the last time the the drum and developer was replaced in the developer unit? If has been replaced, then you might have a bad ATDC (Automatic Toner Density Control) sensor Located right below the developer unit. If the developer was replaced when it was done was a vacuum cleaner used? IF so the static electricity from the vacuum clear destroyed the sensor, NEVER USE a VACUUM cleaner to remove the developer. Also when the developer was replaced, was counter cleared to tell the copier developer was replaced, the copier uses the counters to determine certain voltages for certain assemblies, if not image problems and codes can appear. Finally, was the F8 run after the developer was installed before ant prints or copies made? If not buy new developer and start over, counter is to be cleared first, then developer replaced, then F8 run.
Mar 28, 2017 | Konica Minolta Office Equipment & Supplies
Konica minolta 282 c2557 code appears after developer was replaced and counters were cleared and f8 was run
After clearing the counters did you touch "END" and then power off the machine. Check your counters again if they did not clear get new developer and drum and start over
Sep 21, 2016 | Konica Minolta Office Equipment & Supplies
The error code appearing on our bizhub250 is c2557
. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST. IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Jun 11, 2015 | Konica Minolta 250 Bizhub Copier Fax...
How can i fix code error c2557
Have you had the developer and drum replaced or does the screen say Replace PC Drum? Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST. IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum. YOUR Code deals with the sensor located at the bottom of the image unit. Which monitors the Toner and developer mixture
Nov 14, 2014 | Genuine Konica Minolta Konica Bizhub...
Konica bizhub 282 error c2557 appears, what to do?
Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the TCR/F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN TCR/F8. Make sure the fax line and Ethernet cable is removed can't print anything until the TCR/F8 is run. Or you will start all over again with new developer and a new drum.
Try this site for parts as start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
May 06, 2014 | Konica Minolta bizhub Office Equipment &...
Bizhub 350 error code c2557
Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Apr 22, 2014 | Konica Minolta bizhub C250 All-In-One...
Malfunction code c2557
Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Try this site for parts as a start
Feb 04, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
What part of the machine is affected in error code C2557 of Konica Minolta bizhub 350
Sir/Mam, Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Jan 16, 2014 | Konica Minolta bizhub C250 All-In-One...
Bizhub konica minolta 200 error code c2557
Does the control panel say replace PC drum? You need to have the Drum/Developer and the Developing unit replaced. Make sure that the counters are cleared before removing the old unit and make sure F8 is run after the new image unit is installed
Apr 23, 2012 | Minolta bizhub 200 All-In-One Printer
323 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
George Mclaughlin
Clive
Clive
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
