Question about U-Line Wine Captain (2015WC) Wine Cooler
Describe your uline wine cooler Problem ULINE WC2015: Light comes on but unit won't run. Cleaned as discussed in owners manual. Need help!
  • 286 Answers
OK if you have a 20 series and you have a light and no fan or compressor then you need a thermostat. This will have 2 wires to it and if you bypass the thermostat the unit should run. If it does then replace the thermostat
Posted on Jul 20, 2009
  • lsull654 Jan 18, 2011
    I bi-passed the thermostat and the compressor kicked in!! Thanks for the tip
SOURCE:
ULINE wine cooler 3018WCSA... Freezing occurs at the bottom of the unit.
Yes, the thermostat is full open. It needs replacing.
Apr 12, 2018 | Refrigerators
Uline wine refrigerator won't get cold
how old is it thay usely last a year or so set it tovery cold
May 25, 2012 | U-Line 15WC Wine Cooler
Uline 75WC Wine cooler: light works but fan and compressor do not come on. Wire cnnections are fine.
Does the compressor vibrabte? If not, the PCB isn't working and should be replaced or worst case is your compressor burned out.
Jan 22, 2012 | U-Line 75WC Wine Cooler
Wine cooler (uline) not cooling, previously had thermostat replaced
Make sure that you have enough air flow around the unit and that the grill on the bottom is clean and free of dust/pet hair ect..also take into consideration of the location of the unit... make sure it is not next to a heated appliance like a dishwasher or range. and remember that it is not a frig it is a wine cooler so it will not get really cold.... if it has a glass front make sure it is not sitting in direct sunlight for extend periods of time as this will cause the unit to run excessively. I hope this helps.. I hate warm wine..
Nov 11, 2009 | Refrigerators
Wine cooler not running. When thermostat was
You have either a week connection or a bad thermostat. Check your connections. Part # 2767-s
Oct 06, 2009 | U-Line 75WC Wine Cooler
Uline 2075WCS not cooling
Hi!! I'm a uline authorize servicer and yes the repair man is right. you have a leak in the evaporator..remember make sure to call uline ans see if you have warranty on your seal system of the wine cooler..good luck..
Jan 03, 2009 | U-Line 15WC Wine Cooler
Uline wine cooler 2075wc doesnt work, light goes on ????
If nothing runs but the light is on then change the thermostat. #2767-1 and you can find a part from a distributor. To find one visit www.u-line.com and under customer service you will see parts locator
Nov 01, 2008 | U-Line 75WC Wine Cooler
Unit not working
could be a thermostat problem, check the thermostat for continuity. it should have, if not, then replace the thermostat.
tnx 4 using fixya,
drcool
Oct 01, 2008 | U-Line 75WC Wine Cooler
U-Line 15WC Wine Cooler Problem
Cheak The Compressor relay is fault
May 20, 2008 | U-Line 75WC Wine Cooler
Open Questions:
See all U-Line Wine Captain (2015WC) Wine Cooler Questions
U-Line Wine Captain (2015WC) Wine Cooler Logo
781 people viewed this question
Top U-Line Refrigerators Experts
Elie Balas
Marvin
Marvin
brokenrubber
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
