Question about Cell Phones
How do i set the wireless wifi?
I've got a new TV as stated above and im getting confused on the Wireless WiFi-how do i set and turn it on?
    New Friend:
  • 20 Answers
Look for network settings. Turn on the wifi... Wifi settings adjust to your preferred wifi... Password needed to fill in...
Posted on Dec 09, 2014
Testimonial: "would this be the wifi router pw?"
  • Jocelyn chan Dec 09, 2014
    Yes. If your going to use your wifi router at home.. Or if your going to connect to some other wifi... Ask for their password.. E.g. Starbucks free wifi
Tip
How to configure wifi on Sharp Quattron TV.
Brand new Sharp Quattron TVs all come wifi enabled with Netflix and other applications built right in.<br /><br />Setting this up can be confusing however, just plugging the wireless dongle into the TV is not a solution, as you need to access the menu to configure the network.<br /><br />Something that is not obvious however, is that you need to be on the TV input on the television before you can do this. If you're on any input other than TV, the wireless setup menu will not appear and you won't be able to set up your network. This is a huge cause of frustration to many people as this is not outlined in the manual.<br />
on Mar 07, 2011 | Televison & Video
Do i have to have a router to connect to belkin wifi on my ipod touch?
Yes you need wireless router to use wifi in ipod touch or on laptop.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method.
Then click on wireless and enable it.
. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Mar 17, 2011 | Belkin (F5D7230-4) Router (587009)
How to turn off wireless of samsung color laser printer clx-3185FW
The manual doesn't specifically state this but it appears that if the printer is connected to a wired LAN connection the wireless function will be disabled if the printer is set up in infrastructure mode. When I tried this the 'wireless' light turned off and I wasn't able to find the printer's WiFi SSID using a nearby netbook. If your goal, like mine, was to disable the printer's WiFi from transmitting to reduce extra WiFi noise then this seems to work. One of the wireless troubleshooting tips in the manual states to disconnect the wired connection before attempting to set up a wireless connection so it appears the two can't be used simultaneously. It seems odd that there's no specific "off" setting for wireless though. The printer will provide a WiFi connection when also connected to a wired LAN port if it is set up as part of an ad-hoc wireless network so make sure you set it to 'infrastructure' mode to disable WiFi.
Feb 11, 2011 | Samsung CLP-315W Laser Color Printer
Im trying to set up a wireless modem, but i dont no how to r wat the switch looks like to turn on the wireless
usually there is not a switch to turn wifi on a modem you need a wireless device to try to access its wireless network
you need to plug a wired computer into your modem and type in default ip address 192.168.x.x they are slightly different for each brand EI: linksys 192.168.1.1 Dlink 192.168.0.1 telus: 192.168.1.254
so go into your router settings and you should have a wifi tab somewere in there you can set your SSID (what your wifi will be called) for something you will remember and maybe disable security untill you get your wifi device connected then add what ever security you like
when you try to access your wifi network witha wifi device you wifi light will come on your modem
Feb 05, 2011 | Acer Computers & Internet
Unable to connect to a wireless network...network strength is good.. uder device manager network adaptor was disabled then enabled them and rebooted the system again seen that the network adaptor was...
does the PC work with the ethernet cable connect to your router.?
cat/5/6 cable, it will most times. all times. usuallyu
NO PC stated, no OS stated, how can anyone guess
with just (2 words, computer + wireless)
wifi you meant Im sure but you can put on a 3/4G card and run that. and that too is wireless. but I be you don't have 4G.
does you CELL phone wifi connect to the router?
if not they you are using the wrong credentials.
what is wrong is simple (kinda)
1: the wifi card/chip driver is wrong /missing or 1/2 loaded.
2: the settings for wifi are wrong, in the setups.
what we do is go to the router, read what setup credentials are there. WEP /WPA or WPA2
the get the passphase from there (was word)
that begs the question who owns the router you or the ISP
if they own it , then its locked, and you must call them and get the to disclose the login credentials. (after its locked)
if not locked , tell me the maker name of the router and model and we can set it up.
if you can not CELL phone, (android ) settings, turn on wifi
if that fails , then you need help setting up the router
on most cases the ISP puts sticker on the back of the router
(nice IPS) that tell you your wifi settings.
if not , you must call them
Jan 19, 2018 | HP Smart Buy Notebook
No wireless network in range. My wireless network is set to automatic but I am getting the message above when I search for wireless networks. I know there are at least three here.
If you are so sure of three wireless networks in range then it could be the HW problem in the laptop. Is the green light indicating WiFi lighting on? May be your WiFi switch is non functional. So switch on the WiFi and then look for LAN. Login and not searching a LAN are two different problems. If you cant search the wire less LAN then how can you log into any. So it has to be HW problem as you cant locate any although there are three available. So start at the WiFI switch.
Nov 02, 2009 | Dell Latitude D510 Notebook
How do I turn the radio on the wireless card
When your computer is switched on, the WiFi radio is almost always transmitting or receiving signals. In certain situations, as in an airplane, signals from the radio may cause interference. Use the following methods if you need to disable the radio and use your notebook without emitting radio signals.
Use the Optional Computer Radio On or Off Switch
If your computer has an external switch installed, use it to switch the WiFi radio on or off. See the computer manufacturer for more information about this switch. If you have Intel® PROSet/Wireless installed, the current state of the radio displays in the Intel PROSet/Wireless main window and on the Taskbar.
Use Intel PROSet/Wireless to Switch the WiFi Radio On or Off
From Intel PROSet/Wireless, the WiFi radio can be switched on or off. The status icon on Intel PROSet/Wireless displays the current state of the radio.
To start Intel® PROSet/Wireless, use one of the following methods:
  • Click Start > Programs > Intel PROSet Wireless > WiFi Connection Utility.
  • Right-click the Taskbar icon prosettaskbaricon1.jpg located in the lower right corner of your Windows* Desktop to open the Taskbar menu. Click Configure WiFi.
  • Double-click the Taskbar icon to open Intel PROSet/Wireless.
Switch the WiFi Radio On or Off from the Taskbar Icon
To switch the WiFi radio on or off, click the Taskbar icon image1_ipswtaskbaricon.jpg and select WiFi On or WiFi Off.
How to use the Device Manager to Disable the WiFi Radio
The WiFi radio can be disabled (made non-functional) from the Windows* Device Manager.
Note: If you disabled the WiFi radio from Windows*, then you must use Windows to turn the radio on. You cannot use a hardware switch or Intel PROSet/Wireless to enable the radio again.
Windows* XP
  1. From your desktop, right-click My Computer.
  2. Click Properties.
  3. Click Hardware.
  4. Click Device Manager.
  5. Double-click Network adapters and expand the selection by clicking the Plus symbol.
  6. Right-click the installed WiFi adapter.
  7. Choose Disable from the menu.
  8. Click OK.
Windows Vista*
  1. Use Control Panel > Mobile PC > Adjust commonly used mobility settings (if you use Classic View, select Control Panel > Power Options.
  2. Click Turn Wireless Off .
Hope this helps !
Jul 03, 2009 | Acer Aspire 3000 Notebook
Wireless adapter radio
Windows* XP
  3. Click Hardware.
  8. Click OK.
Windows Vista*
Nov 05, 2008 | Acer Aspire 3000 Notebook
How to change (or update) wap to wpa encryption on ASUS WIFI-B Network Adapter
With this Asus wireless B adapter even the new driver dont support WPA wireless security , because right now sicne WPA is a much newer and higher type of wireless encryption only some wireless B adapter supports that and sorry to say this wireless adapter that you have don't support it even with the latest driver so it will be better to get a new wireless G adapter that supports WPA 100% , you can get the wireless adapter from Asus or from other wireless device manufacturer like Linksys, Netgear. Dlink and Belkin....
Nov 02, 2008 | ASUS WIFI-B Network Adapter
Cell Phones Logo
158 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
