Question about Zeiss Science & Laboratory
What CMOS-battery goes into the Zeiss Visucam lite (build 2006)?
    New Friend:
It use a 2032 battery (3 usd) , it is true, it is solder, you can take off it with a screwdriver slowly and then try solder some wires to the new battery and then sold it to the in the board. Caution: first solder wires to the new battery (it is complicate).
Posted on Sep 19, 2015
    New Friend:
  • 22 Answers
The battery is soldered to the CPU. People from Zeiss Germany said that it needs to replace all the CPU. Now a days there is no longer spare parts for that instrument. I recommen you just change the day and time each time you turn it on
Posted on Sep 10, 2014
  • trex
    trex Nov 22, 2014
    Replace 2032 battery by laying instrument on side and remove 6 torx screws. Remove bootom plate and find 2032 battery holder-remove dead battery and slide in new one.
6ya staff
SOURCE:
Hello I have to replace a mother board MED PIII of Zeiss visucam lite by a new one, please could you tel me the procedure. Thank you so much
Hello Rachid Ammar,
Having worked on serious industrial grade electronics both my adult careers.. I know these things come with serious technical service guides, bulletins & alerts...
Modern plug-n-play electronics is great fun... but
industrial grade equipment is an entirely different
kind of situation... and TYPICALLY amazingly...
Astoundingly EXPENSIVE.
If you know what ESD means... (you know better)
get the manufacture's guidelines...
ELSE
Put your hands in your pockets and back away...
I see there are videos on "YouTube".
If you are NOT HIGHLY SKILLED... don't even think about it.
https://en.wikipedia.org/wiki/Carnac_the_Magnificent
Jan 04, 2017 | Computers & Internet
Acuitus 5015 CMOS battery low message
yo puedo a yudarte a coregir tu problema amigo
Feb 06, 2014 | Zeiss Acuitus 5015 Keratometer
Cmos battery low How and where to fix it?
Hi! Insert a new battery. Download user manual for CPU board (NuPRO591).Connect 5pin DIN keyboard. Switch On. Del. In BIOS Features Setup PCI/VGA Palette Snoop: Enabled. In Standard CMOS Setup LCD&CRT change display interface.
Sep 13, 2013 | Zeiss Acuitus 5015 Refractometer,...
Will not start
Try this. Turn on headlite then try to start.Watch lite,if it goes real dim to off trouble is battery.If lite does not change,still bright,trouble is bad starter,or bendix or solonoid.Starter is not requesting power so lite stays bright.Don,t forget to check ground wires at battery and frame.You changed battery check connections.
Mar 19, 2010 | 2006 Honda VTX 1800
I've misplaced the manual for my Zeiss 526005 Monocular
I would take your monocular to Radio Shack which has an extensive line of battery replacements and a knowledgeable staff that will most likely be able to replace it for you!
ZEISS Manual download site @
http://www.zeiss.com/c1256bcf0020be5f/Contents-Frame/074647b5426c197685257245006ae435
I couldn't find any reference to a ZEISS 526005 Monocular!
Is that the product manual your looking for?
Feb 09, 2009 | Zeiss 526005 Monocular
CMOS replacement for ASUS d1
It's difficult to say but you will need to remove the underside screws and also maybe even the keyboard as it's often attached to the base. The cmos battery could also be behind the screen. Comment by sandrew, posted on Nov 12, 2006 I'm sorry but I dont have any personal experiences with your particular laptop, but the lcd's are generally held in with 1 screw in each corner normally covered by a rubber bung hiding the screws, I would be very carefull not to disconnect any wires behind the screen, if yor not sure take it to a qualified repairer. You will probably have to remove the top panel just below the hinges as they may be held in underneath
Nov 11, 2006 | ASUS Degatto Notebook
Science & Laboratory Logo
1,754 people viewed this question
Top Zeiss Science & Laboratory Experts
Gep Pep
 Brian Main
Brian Main
Terry
Terry
Are you a Zeiss Science and Laboratory Expert? Answer questions, earn points and help others
