Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Green curved lines going across my t.v.
I have a JVC rear projection tv model AV56WP74. A couple of weeks ago all three colors went out of wack but I was able to align them again. Then a week later the green line at the top left habd corner curved down and I was not able to fix it. Now the convergence is all out on all three colors but especially the green which is curving. Is this expensive to fix or am I better off with a new t.v?
  • 1 more comment
  • Anonymous Nov 06, 2007
    The green has a sag in it on the top of the screen that can not be ajusted out.
  • bigizin1724 Jan 30, 2008
    I have the same problem with my set. What can I do to fix this. I was told that I need a covergence mod. And it cost over 500.00. Is this true.
  • tisuvi
    tisuvi Jul 14, 2019
    It was never so easy to translate your dreams into reality by just working online living at your home. Spend few hours in working and get your high share. It’s awesome site offering you best answer of your problems. Here is........ www.jobsthings.com
    Master:
  • 274 Answers
Maybe your lens is becoming loose, give the side of the tv a very light tap and see if there are any movements in the lines, if so, lens is coming loose
Posted on Mar 11, 2015
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 545 Answers
Its going bad.
Posted on Mar 10, 2015
    New Friend:
  • 71 Answers
Vertical Power section problem. Check it with near by repairer.
Posted on Feb 04, 2015
    New Friend:
  • 90 Answers
If you tv took any ipact it would cause this.
Posted on Jan 07, 2015
  • 273 Answers
Good Morning
you appear to have a Hardware Failure in the set there are a couple ic's usually STK392-120 and probably will be a couple Bias resistors in the yoke return circuit damaged if your capable of using a Digital multimeter and have a soldering station less then a 100.00 in parts to restore it to operation if you have to have some one come out around 250.00
if repaired clean the optics they still have a fantastic picture
and will FAR out last the new sets .38 years servicing them and i have no idea what the manufactures have been thinking as everything there cranking out to day will never exists as long .
one thing to consider before repairing evaluate the set . are the colors still crisp and not mushy looking ?if you go in the menu and turn the color off look and see if the black and white is still nice and crisp if so then i would say its a safe repair
Posted on Nov 26, 2014
Change the green lamp
Posted on Sep 18, 2007
SOURCE:
I have a jvc av56wp74 double immages in red and
Ur tv have convergence problems,it dead.U must have soldering tools and know how to solders to fix the convergence problems.U must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 05, 2010 | JVC AV-56WP74 56" Rear Projection...
Black screen with 3 colored lines going across
Ur tv convergence ICS are dead.U have tools to do soldering,and know how to do soldering?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 28, 2010 | Hitachi 53UDX10B 53" Rear Projection...
The colors red, green and blue went out of focus after unplugging my TV. The text on the screen also is curved and out of focus. The TV was working fine before I unplugged it and it set for a couple of...
Please check convergence out chips on D board of TV that seems defective and causing problem.
Let me know exact model number of TV to provide you more info.
Oct 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Jvc AV-48WP74 i no its a convergen issue but..
you can get the convergence repair kit at the following link which usually fixes that issue. The kit contains the parts and detailed instructions on CD of how to do the repair.
http://www.tvrepairkits.net/
Jul 07, 2009 | JVC AV-48WP74 48" Rear Projection...
Red Lines
Are the red lines running on a slight angle razor thin with a slight curve to them? Respond to this same post and I will be able to help you repair the set.
Jul 01, 2008 | JVC AV-56WP74 56" Rear Projection...
Samsung TV Model HL-R5067W
go here they are adjusting speed of the color wheel
Feb 12, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Jvc av56wp74 rear projection tv
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 18, 2008 | JVC AV-56WP74 56" Rear Projection...
Lost the picture
RESOLDER CIRCUIT BOARD LOOK FOR CRACK SOLDERING AT TRANSISTORS FOR CONVERGENCES
Oct 22, 2007 | RCA P56812BL 56" Rear Projection...
Green Convergence on a JVC 56" rear projection t.v.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Aug 27, 2007 | JVC AV-56WP74 56" Rear Projection...
RCA 52inch TV
If the screen control for the green picture tube is set too high, then the colors will be greenish, there will be green where there should be black and there will be fine curved lines (retrace lines) in the picture. If you feel confident then you can open the set and look for the focus block which has the 3 focus and 3 screen controls. One row is labeled Screen and the green control will be the center one. Try turning that control down a little and see is the green background and curved lines go away. If they do not go away then there is something more serious wrong. If you do not have experience working on projection sets then allow a qualified tech to handle it for you.
Jul 13, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
370,296 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
