Question about FrancisFrancis! X1 - Stainless Steel Espresso Machine
My Francis Francis X1 has started to cause me some problems. On occasion when the green light is on and the coffee button is pressed, nothing happens. Just recently, shortly after turning the machine
Machine sometimes works, but mostly does not. Green light is on but when the coffee button is pressed, nothing happens. Recently after turning the machine on there is a constant beeping noise and the green light flashes.
    New Friend:
Turn the steam a let it run twice. Turn off and start the machine again as normally use.
Posted on Aug 28, 2012
6ya staff
SOURCE:
Anonymous
SOURCE: Francis Francis X1 Electrical Problem
Hello all, I had the same problem and I was not willing to pay to repare the machine so I opened it and had a look inside but could not find anything.
Then started connecting/disconnecting different parts of the machine to isolate the problem which turned to be the boiler. There must be some short inside it so nothing I could fix myself.
Instead what I did is to disconnect the ground connections (yellow cables) and now it's working fine! I didn't notice anything in the last couple of weeks so I'm enjoying the machine again.
Of course there must be a better solution for the problem but this "quick and dirty" trick turned to work out for me!
Posted on Apr 10, 2009
jmgldsmth
Jim Goldsmith
  • 2005 Answers
SOURCE: Francis Francis X1 - Cleaning lime from tank
CLR rinse followed by a vinegar brew then a clear water brew cycle
Posted on May 21, 2009
quady
  • 142 Answers
SOURCE: Where can I buy Francis Francis X1 coffee machine
europart
Posted on Sep 14, 2009
Anonymous
SOURCE: I bought a second hand Francis Francis X1 Espresso
Perhaps the heating element is broken. Does it heat up at all? If not, the steamer won't work and there will be nothing for the gauge to register.
Posted on Feb 09, 2010
bansheracer
  • 1089 Answers
SOURCE: Francis Francis X1 Popping noise - stopped working
Hi There are a couple of things that could have happened. The fuse could have blown, but you wouldn't get a pop usually. The main board could have blown, that will pop. There is a hole below the steam arm. up inside there is a screw that you can loosen. Then you can unscrew the steam knob. There are 4 screws on the bottom side of the cover that will allow you to remove the top. Make sure that the machine is unplugged.
Posted on Feb 14, 2010
The orange light on the start button comes on and nothing happens
prepare machine for use first.
half-fill water tank, switch on unit and insert yellow TDisk (service disc) barcode down. Close the locking unit securely loud click, press green light repeat these steps 3 times. After that you will have the stand by orange/amber. Remove the Service Disc and store in the recess behind the water tank, Insert a Coffee Disc, close the brewing unit with click and green light should be on. press and it should work.If not go to shop where pruchased. Warranty.
Dec 29, 2012 | Braun Tassimo Espresso Machine/Coffee...
It says 'ventilate' and nothing works. I have tried to turn it off and back on but it doesn't work.
Hi
Like the Royal Pro machine and Royal Coffee, there is a water button on the Comfort that you need to press to run water. If when you press it and nothing happens you have a stuck solenoid, probably from scale build up. See what happens when you push the button with the drop of water or it may have many drops depending.
Dec 07, 2010 | Saeco Magic Comfort Plus Espresso Machine
When the machine is on and the heating has completed, pressing the buttons to make coffee has no effect. They just blink once and nothing happens. The steamer seems to work fine tho.
This happens to us sometimes and we find that the problem is with the capsule holder. Try taking the capsule holder apart and then twisting it together again. If it's not quite in the right position, the machine will not dispense the coffee!!
Oct 28, 2010 | Gaggia Caffitaly K111 Coffee Maker
! light flashing... machine won't brew coffee - when i press the button to make espresso nothing happens.. I've tried all the troubleshooting options - nothing works.
The machine is sensing one of the following is not properly fitted in.
Check bean lid, brewing unit is properly latch in, dreg drawer and tray is in, and water tank. And make sure the knob is in off position. If all those are properly in ..the green light will start flashing and warming up. When it reaches the working temperature it will start rinsing and it's ready to use.
Oct 11, 2010 | Saeco Odea Giro Plus Coffee Maker
JUST HAD IT SERVICED. RAN TWO SHOTS OF ESPRESSO, STEAMED MY MILK JUST FINE. THEN WHEN I TRIED TO DO ANOTHER SHOT, PUSHED BUTTON AND NOTHING HAPPENED. STEAM LIGHT FLASHING, WON'T GO OFF.
Hi
If you steam and then try to make another coffee, you need to cool the boiler off. Turn the steam off by pushing the steam button again, then open the steam knob and running water until the flashing light turn to green steady. Then make you coffee.
Sep 10, 2010 | Saeco Magic De Luxe Espresso Machine
Platinum B70 sometimes won't brew
I also have the same problem. Is there a pattern here?
Jun 11, 2010 | Keurig Platinum B70 Coffee Maker
Brand new Saeco Villa machine won't prime
Press hot water button then open valve, then push the valve knob in if that works take it back and tell them that the valve is damaged.
Aug 29, 2009 | Saeco Vienna SuperAutomatica Coffee...
Dell XPS 200
Is the amber light blinking? Indicates PS not operating within specs. You can look at replacing the PS (~$79-99). GL
Aug 09, 2008 | Dell XPS 200 PC Desktop
After pressing the button nothing happens
We had this issue for a while. We solved it by turning the machine off, unplugging it, and then starting over. Sometimes we had to do this multiple times before it worked. Then, mysteriously one day it stopped and has been working fine.
Jun 17, 2008 | Keurig Special Edition B60 Coffee Maker
FrancisFrancis! X1 - Stainless Steel Espresso Machine Logo
781 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
andyandrews3
Level 1 Expert
ray gallant
ray gallant
Tom Chichester
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
