Question about Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator
Kenmore fridge Model# 106.56542400
Where is the defrost timer located on Kenmore Coldspot, side-by-side, Model# 106.56542400. Yr. model 2004.
Can i adjust it so the fridge side will get cool??
Freezer works perfect!
    Scholar:
  • 195 Answers
Open the fridge side, look up.
Posted on Dec 07, 2008
2 Suggested Answers
SOURCE:
Sea Breeze
  • 4656 Answers
SOURCE: Where is the defrost timer on a kenmore coldspot
I need a model number like this 315.00215478 Contact here> app....@yahoo.com or here=> http://appliance911seabreeze.com/index.html or here=>
http://appliance911seabreeze.com/Locating_the_Model_and_Serial_Numbers.html
Thanks, Sea Breeze
Thanks, Sea Breeze
Posted on Nov 28, 2010
Water drips from the freezer into the fridge.Upon disassemble, there is ice buildup under the coils. kenmore coldspot model #71184101
The defrost timer or the defrost heater element has probably failed. Go to the link below and enter your exact model number; you should find a line-drawing illustration and parts list for your fridge that you can use to locate these items and normally also determine how to remove or install them:
Sears PartsDirect
Apr 08, 2011 | Kenmore 52632 / 52634 / 52639 Side by Side...
I have a side by side kenmore coldspot model 52259100. The Refrigerator is not cold but the freeze is cold. Help!
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Kenmore Refrigerators
Kenmore coldspot model 106-54592400. The refrigerator is not getting cold enough, has been hovering around 45 to 50. The freezer is working.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Nov 10, 2010 | Kenmore 50522 / 50524 Side by Side...
Kenmore Coldspot freezer too warm
Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
Hope this helpout......
Jul 28, 2010 | Kenmore Refrigerators
Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Feb 08, 2010 | Refrigerators
Stopped cooling.
It is possible the cold control has gone bad. Or the defrost timer is stuck in defrost, or even the compressor has gone bad.
Dec 28, 2009 | Kenmore Refrigerators
Kenmore Fridge Defrost fan wont stop running
Hi, The defrost timer is located in the control panel. There should be 2-4 screws holding the control panel. Remove the screws and lower the panel to see the defrost timer. There are 2 screws holding the defrost timer in the control panel.
Please let me know if this helps you at all or if I can assist yyou further.
Vic
Jul 21, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kenmore Coldspot 106.9552610 not cold enough
Inside the fresh food compartment look for an opening that will allow you to turn the defrost timer clockwise slowly. When you hear it click the refrigerator should go into defrost. If the timer is bad it will need replaced. Let me know. Below is a photo of timer.
Part number 6
Feb 27, 2009 | Kenmore Refrigerators
Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator Logo
1,232 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
