Question about Citizen Skyhawk Eco-Drive JR306059F Wrist Watch
Analog clock not in sync with digital clock
My analog watch is currently 5 minutes faster than my digital clock Example: I live in Seattle. The Seattle digital clock shows 12:04pm. However, the analog watch hands show 12:09pm. My battery level indicator presently shows 2 out of 3 bars. Is this due to a low battery?
  • Anonymous Mar 15, 2014
    seting of analog clock
This problem may be due to your analog hands being improperly zeroed. To find out, try this: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero. If you do this and your minute hand points to 1 o'clock, or five minutes, you will know that this is the problem. If this is the problem, you can can correct it by zeroing the hands as follows: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero, or close to it. You should also notice the letters "HR" in the lefthand digital display. This allows you to move the hour hand by rotating the crown. If the hour hand is not pointing at 12 o'clock, rotate it so that it does. 3. Push the top button once. The letters "MIN" should appear in the lefthand digital display. This allows you to move the minute hand on the large dial, and the minute and hour hands on the small UTC dial. Rotate the crown so that the minute hand points directly to 12 o'clock. 4. Push the top button again. The letters "SEC" should appear in the lefthand digital display. Rotate the crown to point the second hand directly at 12 o'clock. 5. Push the crown back into its normal position. Set the digiatl time and date in your tie zone, and your analog hands should match the digital read-out. If the zeroing of the hands is not the problem, I don't know what is wrong with the watch.
Posted on Sep 27, 2007
  • 3 more comments
  • Levi Ford Jan 24, 2014
    I have a watch(found) and need to know what type of watch it is and makes it, the initials of the manufacturer is VS(WRITTEN ON TOP OF THE OTHER LETTER), the part/model # is F-IAFGI, it uses 377 battery,probably 2-377 batteries,I need what VS stands for and a picture or description of the battery, please.
  • Frank Means
    Frank Means Dec 10, 2016
    Thank you SO much. Even at the Citizen website their instructions do not tell you how to sync up the analog and digital time INCLUDING the second hand. This is important to me. I like everything to match. Big help. "Zeroing the analog hands", I gotta remember that one.
  • Anonymous Jan 05, 2017
    howie 50... U are a genius Sir. My Sailhawk was suffering exactly the same 'out of sync' digi VS analog issue by around 4 minutes. And your fix... simply fixed it! It was driving me crazy! My sad old eyes can no longer read the (tiny) digi display so it was all hands for me.. and they were annoyingly out of time. All fixed now thank you thank you thank you (And hey Citizen, how about sending howie 50 a brand new watch for his trouble... and including his 'fix' in your manual.) Cheers from Mark - QLD Australia
  • Scott Widmann
    Scott Widmann Sep 21, 2017
    Hell yes, you fixed my watch!!! Thank you.
  • Greg Zurbay
    Greg Zurbay Nov 07, 2018
    Howie 50 - thank you thank you thank you - simple fix once you have the proper advice. THANKS.
I cant fix the analog of my watch pasnew model PLG_1002AD GRADE A QC 6
Ignore the instructions I found its not as easy as they say first you need to sync the digital and analog to do this press all four buttons at once and hold for 3 secs tho sets the digital clock to 12 Now press mode till you see h-s hold reset till h-s flashes hold the start button in the analog will start moving its slow so be patient set analogue to 12 exactly ignore the minutes that have passed press preset the minute hand will automatically adjust once done press mode go to the main watch screen hold preset use mode to select hours minutes date year month etc and start to change the values keep it on 12 not 24 hour clock set the clock and press preset the analog will now automatically adjust to the time once done you can change to 24 hr mode if you wish
Mar 06, 2015 | Watches
The digital will not sync with the analog hands on my g shock
same problem here.. everytime i adjust the analog clock it moved but the digital clock dont so it means i can correct the analog but i cant correct the digital clock please help us..
Dec 30, 2012 | Watches
Sync time in gshock GA110-1A
Simple straight forward instructions in youtube video below:
https://youtu.be/R84_g7Wrw4E
Nov 15, 2012 | Casio G-Shock World Time Analog Digital...
How do I set the time and how do I get a user manual.
1. set time/datepush the pusher at 4:00 for couple second to start setting mode.pusher at 4:00 is to select time/date, pusher at 2:00 is to adjust time/date
2. if off sync between analog and digital clock happen. You need to resyn
step 1: follow the instruction 1 to set digital clock to 12:00.
step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync mode.
step 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.
step 4: push the pusher at 3:00 to exit the sync mode.
step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
Jun 18, 2011 | ESQ 07301132 Aerodyne watch
I just bought this watch but can't figure out how to set: time, date, and alarm. Please help. Thank you
2. if off sync between analog and digital clock happen. You need to resynstep 1: follow the instruction 1 to set digital clock to 12:00.step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync modestep 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.step 4: push the pusher at 3:00 to exit the sync mode. step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
Jan 14, 2011 | ESQ 07301132 Aerodyne watch
Setting time day date in ESQ Aerodyne
Jul 26, 2010 | ESQ 07301132 Aerodyne watch
Problem Syncronizing the Analog & Digital
Hi ...
Oh yes, a problem which I also had :) easy to overlook this moment - even in the original instructions. Very accurate description of all the features of Citizen Ana Digi Temp - including how to set the time - and Synchronize Analog and Digital watch, you will find on
CITIZEN Ana Digi Temp
Best Regards
Dec 06, 2008 | Citizen Blue Angels Skyhawk Watch
Setting the hands on this watch
press your "mode" button 5 times until it says on lower display "H-SET". Then press the "adjust" button until it beeps.
Now hold the "forward" button and the minute hand is moving.
Enjoy :o))))
Nov 28, 2007 | Casio Green G-Shock Street Rider with a...
Daylight Saving Time will not set correctly
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Nov 08, 2007 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Citizen Skyhawk Eco-Drive JR306059F Wrist Watch Logo
8,187 people viewed this question
Top Citizen Watches Experts
Arturs Kalnins
Arturs Kalnins
Felipe Valera...
Level 1 Expert
Are you a Citizen Watch Expert? Answer questions, earn points and help others
