Sd pvr remote
The remote no longer communicates with the decoder. The remote works fine but when a button is pressed nothing happens on the decoder it just shows 2 blinking dots
    New Friend:
    Problem Solver:
  • 5 Answers
It sounds like the remote needs to be re-programmed to work with the device. the 2 blinking dots illistrates that it is looking for a device to operate.
Posted on May 04, 2012
SOURCE:
SOURCE: Samsung TV remote control
I HAVE THE SOLUTION TO THIS PROBLEM.
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
Posted on Jan 26, 2008
  • 286 Answers
SOURCE: Harmony 890 Pro dropped.....everything looks fine but it no longer controls system
You will have to open the unit up and repair whatever broke.
When this has happened in the past to less complex remotes, I have found that usually the oscillator chip has broken off of the circuit board, but whatever it is will have to be resoldered back into its original position.
If you have never worked on electronics before, you will have to take it to a repair shop, send it to the manufacturer, have a knowledgeable friend repair it or buy a new one.
Posted on Aug 12, 2008
SOURCE: My Toshiba SE-R0161 Remote no longer works.
There is most likely nothing wrong with your remote. I just had exactly the same issue with my SE-R0161 remote. (I had just changed my remote batteries too and was getting a DR-2 code on the Toshiba DVR RD-XS52 unit's display.) My DVR and my remote had to be realigned so that they both have the same infared (IR) code. The remote and the DVR can have DR 1, DR 2 or DR 3 as remote codes. Pg 54 of the Toshiba Installation Manual explains how to align both your SE-R0161 and your based unit so that the remote works again. Good luck. Hope this helps.
Posted on Jun 27, 2009
dcramer531
  • 1654 Answers
SOURCE: 1) The remote is not communicating with any of the
I can give you several tips to try and see if we can get it going. First make sure you have the correct devise selected with the remote. For example if you are using it for the tv, make sure you have pushed the tv button on the remote first, and so on for all the other functions for your reciever. If this is not the problem try changing the batteries and make sure they are in correctly. Weak batteries will allow the red light to light up on the remote but it doesn't have the power to send the signal to the reciever. the other option is that the remote is simply wearing out, or has some type of dirt insde it not allowing the buttons to make contact with the metal strips inside the remote. You can sometimes find a store like Radio Shack that will be able to check and see if the remote is acdtually sending a signal, try calling around and see if someone has one of these detectors. If none of these help, try getting one of the universal remotes from a department store, they work with just about any brand of electronics and are much cheaper that a new remote. Here are a few links to sites that carry almost all brands of remotes in case you need a new one.
I hope this helped.
MrRemoteControls.com
Remotes.com
Posted on Nov 17, 2010
BeckiB_DISH
  • 286 Answers
SOURCE: SAT button not working on remote--volume controls
Hello, there! My name is Becki Barned, with Dish Network customer service. You have probably already getten this resolved, but just in case it happens again, or you have questions, here is a link to our website, where you can take the steps to reprogram your remote, which is what is needed in this case. http://www.dishnetwork.com/SupportSection/remote-control I hope this helps in the future!!!
Posted on Dec 28, 2010
Hi I have a PACE PVR Decoder which skips channels when p+ / p- is pressed
Hi, This may be due to one or two things. The remote and the box should have P+ and P- buttons. If the box operates ok but the remote doesn't the remote buttons are causing what is called switch bounce and needs replacing but if the box and remote jumps channels they are not the cause but programming and memory retention of the PVR.
Make sure the pvr is not recording anything first as this may inhibit some channels from showing. go to the update page and make sure that the box is fully updated. Another reason could be the aerial not giving strong enough signals for some of the multiplexed stations. To check this select the channel number rather than using P + or P-.
If the channel does not show it could be signal related or moved to another number and not updated. Tim
Aug 22, 2014 | Televison & Video
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Apr 02, 2013 | Televison & Video
Connecting pvr dstv decoder 3001
My pvr decoder model 3001 remote control doesn't work I checked battrey it works but no answer for decoder what shall I do
Dec 15, 2011 | Televison & Video
No communication between receiver and remote
amandaharwoo,
The first thing I would do, if you haven't already, is replace the batteries in the remote. The lights will still illuminate if the batteries are low but won't perform the remote functions. If that doesn't fix the problem, the remote may need to be readdressed to the receiver. I have provided the steps below. If you have further problems, please respond to the site.
  • Remote: All Other Remotes
    1. Go to System Info screen
    2. Hold down the SAT button until all mode lights light up.
    3. Enter a number between 1 and 15 using the numeric keypad on the remote.
    4. Press the pound (#) button
    5. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 3 will appear in the System Info screen under Remote Address.
Ray Calo
DSIH Network
Jun 13, 2010 | DISH Network 721 DVR Remote Control
My humax rm-f01 remote has stopped working. The PVR light comes on everytime you press a button but nothing changes on the tv?. I've checked the batteries and they are fine?
What are you trying to control with the remote? Try pressing the button on the remote that corresponds to the device you are trying to control first, and then try the remote again. I hope this helps, and good luck! Der Strom
Apr 05, 2010 | Humax Televison & Video
I have pluged a flashdrive in the usb port. Pressed the PVR buttons on the remote. Nothing happens. How do I get the PVR to work?
The best way for us to assist you is to know the exact brand and model number of your equipment. What make is your PVR?
Jan 29, 2010 | Televison & Video
WMC PC and TV no longer communcating by remote
For the remote : try replacing bateries
Device driver : try reinstalling the tv tuner from the device manager.
Please name you model number of ur pc.
Jun 20, 2009 | Dell Dimension 3100 PC Desktop
Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
Jun 06, 2009 | Panasonic TH-42PX60U Television
Mustek PVR-H140 shuts down when I insert some SD cards
Yes that's correct newer SD Cards use faster memory chips that are not always compatable, not just with this unit but you can have the same problem with cameras and other MP3 players as well.
The PVR-H140 is quite old now so stick to the older type cards, oh and they dont like being hot swapped, this can cause a shutdown or driver corruption, insert them before turning the unit on.
Jul 26, 2008 | Mustek PVR-H140 Digital Media Player
Televison & Video Logo
264 people viewed this question
Top Televison & Video Experts
Ekse
