Question about Panasonic DMR-E75V DVD Player/VCR
Suddenly cannot record DVD after years
I can see the frames of different past recordings, and can play them fine, but, when I close that screen, expecting to see TV through the DVD, all I get is "UNUSABLE SIGNAL"... which means I can no longer record. What in the world has happened? Please someone...
  • 3 more comments
  • Anonymous Oct 30, 2008
    Channel for the TV must be set to channel 3 normally, but I'm pretty sure that I must select the who/input button on my RCA remote to be able to see recorded DVDs. I would expect that the same source setup would let me see the playbacks and see live tv and record, butI think that must bypass the TV somehow.
    I cannot record anymore, but the TV should be on 3 and I record whatever channel the cable box is on.
    The cable box is a Scientific Atlanta... installed in 2002... that's all I know (away from home).
    When I stop playing a DVD, the screen goes back to "no input" or some such message with a blue screen.
    I don't know how to try changing/cycling through the different input/source of the Panasonic DVD nor changing/cycling through the different input/source of the Panasonic DVD
    I have a Wii game console in my setup. BELOW is my whole setup:
    1) From wii proprietary cable to ----> input B of an A/B switchbox
    Using triplet (white, red, yellow) audio/video connections....
    2) From Panasonic DMR-E75V to ----> Input A of the A/B switchbox
    3) From the A/B switchbox out to -----> TV
    Using cable connections:
    From wall cable to ----> cable box
    From cable box to ----> Panasonic DMR-E75V (rf IN)
    From Panasonic DMR-E75V (rf OUT) to ----> TV
    Perhaps in my jumbling trials of variations, I have messed this routing up. I hope this tells you something. Please help. Thank you for answering me.
    Technically I have a Wii game console in my setup that must be considered, as it turns out. BELOW is my whole setup:
  • Anonymous Oct 31, 2008
    So you think my connections setup is correct?
    I am pretty sure that when I try to record cable TV as your last instruction illustrated, when I set the RCA to input... that is when I get the "unusable signal" or similar error language with blue screen. j
    I will test it again later today and post again,. Thanks.
  • Anonymous Nov 01, 2008
    THANK YOU, THANK YOU, THANK YOU!
    The trick was the Panasonic DVD recorder/player being SET ON CHANNEL 3 like the TV!! Somehow that had been changed by whomever.
    It works perfectly now! Thank you for the wonderful reply, which contained the magical answer to my problem!!
    Larry
  • kjwj
    kjwj Nov 27, 2013
    I have same problem. Suddenly I can not play home recorded, non finalized DVDs. Machine does however play pre-recorded DVDs. I get a 'not recognize' message on tv screen. I can not figure out how to put in service mode to see if I can fix it. Any suggestions? Machine is: Panasonic DMR-E75V Thank you.
    Brigadier General:
  • 6,966 Answers
Apologies for the delay in response. Your concern was just brought to my attention.
To your recording, based on your second posting (and would appreciate corrective information where applicable), your system is:
  • Cable provider > Cable Decoder Box > Panasonic DMR-E75V > TV (equipment setup)
  • single coaxial cable > yellow, red & white > yellow, red & white (wiring setup).
With your indulgence, a couple clarifying questions:
  • to watch the Panasonic when you play DVDs, to what channel or source or setting must the TV be set to?
  • to record a TV program/channel, to what channel or source or setting must the Panasonic be set to?
  • what is the brand and model of your Cable Decoder Box?
Initially, pls try:
  • play any known good DVD disc/movie. power on the TV and set to watch said movie;
  • without changing anything on the TV, STOP the playing of the DVD;
  • try changing channel on your Cable Decoder Box's remote;
  • pls post back result(s); or
  • do the above steps again but before changing the channels on the decoder box's remote;
  • try changing/cycling through the different input/source of the Panasonic DVD;
  • again post back result(s).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 30, 2008
  • 1 more comment
  • Louie  Role
    Louie Role Oct 31, 2008
    If understand your postback correctly and our initial try based on your description:
    to watch cable TV:
    • the RCA powered ON & must be set to Ch3;
    • the cable box powered ON and channel selection done there;
    • the Panasonic can be powered OFF;
    • the A/B switch can be in any position.
    to record cable TV:
    • the Panasonic must be powered ON and set to channel3;
    • the RCA powered ON & must be set likewise to Ch3; or
    • the RCA powered ON & set to INPUT with A/B switch set to"A".
    to watch DVD playback:
    • the RCA powered ON & must be set to Ch3; or
    • the RCA powered ON & set to INPUT with A/B switch set to"A";
    • the Panasonic must be powered ON and playing a DVD;
    • the Scientific Atlanta Cable Box may be powered OFF;
    to watch Wii game console:
    • the RCA powered ON & set to INPUT with A/B switch set to"B";
    • all others maybe powered OFF.
    Cheers.
  • Louie  Role
    Appreciate the quick postback. A few quick notes:
    • So you think my connections setup is correct? - basically yes;
    • record cable TV ...set RCA to input..."unusable signal" - pls verify that the Panasonic is set to Ch 3 and A/B switch set to "A";
    • and post again - would appreciate update on any development(s) (or even the lack of it).
  • Louie  Role
    Louie Role Nov 01, 2008
    Glad to be of assistance and would appreciate you rating the solution as you see it fit.
SOURCE:
I have a JVC DR-M100 DVD recorder that will not record but plays.
Most likely has developed a problem with the laser pick up it would probably be cheaper to replace. Julio milleniumtvsvc@gmail.com
Jul 26, 2009 | Televison & Video
Everything has been working perfectly for 3 years or so/ done nothing different,use almost exclusively the HDD on my DMR-EH60, then suddenly the TV no longer responds to my commands. Unit goes off and on...
The DMR-EH60 has been working fine for a good five years then it started intermittedly loosing sound when using it as tuner for our display panel. Now there is not sound at all even recordings from TV onto the HDD. Any ideas?
Jul 19, 2009 | Panasonic DMR-EH60 DVD Recorder/HDD...
VCR records TV shows, but doesn't play them on other VCR's
The machines playabilty setting has gone off. take to nearest repair shop and they will probably reset or change guide posts.
These components normally will allow a tape recorded in one machine to play on another. Had many of those esp from camcorder to vcr
May 05, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Movie recording disabled
   Just delete unuseful data from drive or connect the camrea to your pc cut the required movie and paste it on your pc drive then it will work.
Thanks for using fixya.
Feb 15, 2009 | Sony DCR-DVD608E DVD Camcorder
Samsung DVD recorder will play but not record blank discs
Had mine into the repair shop. Junk it, processor is toast. Not worth the money to fix. The guy said he wouldn't even touch it.
Jan 19, 2009 | Samsung DVD-VR330 VCR and DVD Recorder
Emerson EWR 20V5
Jan 17, 2009
I posted this Jan 3, 2009 and seem to have a solution.
Similar problem. E4 54037380 Can not record on this disc. Even though it is from the same package of DVD-Rs that I have successfully recorded to previously. Contacted them about 9 months ago without a successful resolution so I am trying again. Unit will play any DVDs, will record and play back DVD-RWs but will not record on my imation DVD-Rs 8X discs that worked fine in the past. Starts to record for a few seconds and then the error message appears (sometimes with slightly different final 4 digits of error number). Other postings have suggested: maybe a firmware update is available (I requested and we will see Emerson's response), trying slower speed discs (I am skeptical since these 8x imation discs in this same package previously worked, and the instructions say 1-16x for DVD-Rs), unplugging the unit for 1/2 hour to reset the unit (did not work), playing the last disc recorded to the end and then trying a new disc (now it recorded for about 30 seconds rather than 10 seconds but then got E4 54043E02 error message, different but still did not work). So I am hoping for something more productive out of Emerson this time.
Update Jan 17,2009. Bought a CD and DVD cleaner disc with the little brushes on it. Cleaned the EWR20V5 per the cleaner instructions and tried to recod on the imation DVD-R 8X that I had used successfully in the past, no luck, same error message. So I bought another brand, maxell DVD-R 4.7GB up to 16X and IT WORKED. The instructions on pg 25 say for DVD-R "up to 16X" may be used but "4X-8X disc is recommended". Go figure, no idea why the 16X worked but they did in this case. So just a suggestion to try other brands. Someone else had suggested that also so I gave it a shot. $8 of new discs and $13 for the cleaner and I've back in business.
Jan 16, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Toshiba D-VR610KU recorded disc won't play in my Daewoo DVD5800
What are the compatible types of DVD's that the Daewoo DVD5800 player is supposed to play? Is DVD-R among the compatible types? Try playing the new recordings on a computer that has a DVD drive, or a friend's computer.
Apr 20, 2017 | Televison & Video
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
99.
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
99.
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
Panasonic DMR-E75V DVD Player/VCR Logo
526 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
