Question about KitchenAid KWVU205YBA Kitchen Hood
Light and blower speeds malfunctioning
The vent hood has two problems. First, the mid-range blower speed and indicator light quit working. If the high speed setting is turned on, the mid-range speed indicator light works.
Second, the hood light works intermittently. Sometimes the light will not work at all. Other times, the light will come on when the hood is slid out, but the on/off button does not operate the light at all.
My neighbor, who worked in the electronics field for years, tested the touch panel and was not able to find any problems with it. He was testing the continuity of the push buttons and the connector where the wiring harness connects to it. No problems were found. He believes the problem is in the microcomputer board.
    Novelist:
  • 171 Answers
Hi mutt750,
I'm Harvey the Master Plumber.
I agree. It sounds like your neighbor is doing well. I would replace the control board too. Sounds like a nice guy. Time to invite him over for a bbq?
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
6ya staff
SOURCE:
How to replace control switches for a venmar hood fan
[PDF]Download - Venmar
www.venmar.ca/DATA/.../131_5_en~v~Installation_Manual.pdf
Before servicing or cleaning unit, switch power off at ... solid-state speed controldevice. 8. ... should not be allowed to accumulate on fan, filters or in .... We recommend to install the hood at a minimum distance of 24" from an electric range and.
FAQ - Venmar
www.venmar.ca/en-faq.html
Can I use other controls than Venmar controls with my unit? What is the ... Range Hoods. Can I replace an "over-the-range" microwave with a range hood? ... VenmarConnaisseur C270 and C600M · Rocker switch control. Venmar V10 ...
Range Vent Hood Switch Parts In Stock from RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Range-Vent-Hood-Switch-Parts
Shop for your Range Vent Hood Switch from our huge inventory. Check our ... RepairHelp for Range Vent Hoods ..... Blower variable speed control switch.
Range Vent Hood Repair Help - Free troubleshooting
Jan 23, 2016 | Venmar Kitchen Ranges
Pontiac g6 2006 heater/ac fan doesnt work on #3 speed setting, fan made squealing bearing noise for a while but quit, also inside/outsied air vent switch vent makes clicking noise when set to outside air
you will need to replace the blower motor as it has probably siezed going by the squealing noise you say you heard.i`m assuming this has more than 3 speeds for the fan motor.if it wasn`t working on one speed then you probably have a bad blower motor resistor that will need to be replaced as well so you will have all fan speeds.this is located in the air duct housing near the blower motor and will have about 6 wires on it.some of these on under the hood on the firewall anywhere from the passenger side to the center of the firewall.not sure about the vent switch.if the vent switch is moving the doors and you hear a clicking then you may have a vent door problem that the door pivot is worn.
Nov 01, 2013 | 2006 Pontiac G6
Blower motor doesn't pump well even the fan switch on high
sounds like blower bearings are dried out and will eventually lock up the blower..sometimes you can spray wd40 in the blower bearings and it will work fine for a while.. also check vacuum controls to the baffle dors in the ductwork..may have some leaks there.. should hear a slight hissing if really bad..repost findings
Feb 09, 2013 | 2005 BMW 545i
I have a Best K41-1 and my variable speed on the blower does not work. It only works on high speed when slid into that position. What could be the problem?
I have the same problem (again) but with the lights not working also so something else is going on. The usual fix for the fan on high issue is to replace the switch assembly (SB06105117). It's an $80 part. This worked for me the first time it happened. If you are handy then it's a 1/2 hour project - turn the power off at the breaker.
Mar 18, 2012 | Broan-NuTone Best by Broan 30quot; 500 cfm...
I have 2001 Volvo S80 and the heater and AC comes on for a minute or two and then shuts off. The dealer said it was the blower mower burned out. How can that be if it works now and then?
Assuming that the dealer is correct and isolated the problem down to the blow motor...
it IS possible for the motor to work intermittently due to heat buildup. Malfunctions due to heat will call the motor to run fine for a bit, and then quit when the motor reaches a high enough temperature to cause a malfunction. It would then quit working until it cooled back down, and repeat the process.
Whether is it just dead, or it is intermittently dead, for all intensive purposes, the motor is no longer usable and needs to be replaced with a new unit.
Nov 06, 2009 | 2001 Volvo V70
The fan knob on the climate control panel only operates on the high range and will not even turn the a/c on in low or medium. when in high range the a/c unit overall seems to be performing like normal...
Had the identical problem in my Grand Cherokee... you need a new relay switch... mine was located under the dash on the passenger side and was ceramic -- when they go bad they only allow the climate control system to work on high speed.
Sep 02, 2009 | Heating & Cooling
2004 mazda mpv- rear heater fan only works on high
My bet is that there's a relay at fault... but first: have you checked the fuses? the high blower speed draws a lot of power, so sometimes it's fused separately from the other speeds. This means that your fuse for the slow blower speeds could be blown. Also, because theblower draws so much power, you'd need a HUGE switch to switch it directly, so they use a low-power switch inside the car, and a relay (usually under the hood, but sometimes under a seat (check your owner's manual) to do the heavy work. These are often split the same way, with the high blower on one, and the slow on the other. These are the things that are easier to check, but it could just be that the switch is bad. Mid 90s Land rovers and Range Rovers have the same problem, where the only blower speed that works is HIGH, making the cabin sound like a wind tunnel... Just the switch. The switch can be a pain to replace if you do it yourself, but do check the fuses first, and see if you can find the relays. if the fuses are okay, and you find the relays, try to find the one that's for the fan and swap it out, it shouldn't be more than 3-4 dollars from an auto parts store, just bring in the old one to match it, or swap it for another relay that's nearby and has the same pins. If the swap works, just remember to get another relay, because the one you "borrow" from another circuit could be the door locks or the headlights or something else important....
Jun 22, 2009 | 2004 Mazda MPV
Zephyr Savona range hood quit work on low spds-hi still works
Motor Speed may not be working and this means the either the motor is bad or switch is bad for motor Low Med Hi Switch
May 27, 2009 | Zephyr Savona ZSV-E30AS Stainless Steel...
A/C blower question
Thats a bad fan switch
as you stated it works at lower speed....
replace the switch
LB
Sep 22, 2008 | 2002 Jeep Grand Cherokee
BABT83.2AL Canopy Rangehood The fan/suction is not working. A slight straining noise is heard. The light is working as is the display panel.
These units have a history of fan failure due to inferior 220 volt Italian fan.
I have just had fan fail and retrofitted a ebmpapst blower fan model D2E146HT6702 which is readily available in Aus for around $120.
The fan speed control is by inverter variable output so you don't use all the speed select wires that this fan has. Connect the Red wire on the range hood to the Black on the motor (High speed winding) and the Black on the range hood to the Blue on the motor (Neutral) and the earth to the earth (Green).
Disconnect and toss the cap in the white enclosure under the PC board enclosure (the new fan has the cap on board). Don't know how easy to fit in the range hood as mine is in an acoustic fan housing in the roof (makes it wisper quiet when running)
Apr 07, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
KitchenAid KWVU205YBA Kitchen Hood Logo
518 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Jay B
Level 1 Expert
Colin Stickland
Colin Stickland
ittco
Level 1 Expert
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
