20 Most Recent Summit SCR1150 11.0 Cu. Ft. Full Sized Beverage Center Questions & Answers
Google (summit)(CL66FDOS)(manual) without parens.
Summit... | Answered on Jan 13, 2019
FROM THE DEAD REFRIGERATOR STORE CALLED JUNK YARD
Summit... | Answered on Dec 01, 2018
The right setting depends on how many door openings the fridge sees in a day and how packed with food it is. If the fridge is warm, try increasing the thermostat slightly to a higher number. Come back 24 hrs later to see if it has gotten better, You may need to do this a few times. If you don't get any results, then it's possible the thermostat is faulty or the fridge has a leak in the cooling system.
Summit... | Answered on Oct 13, 2018
Hi, One of the most common problems with frost-free refrigerators (and often with upright frost-free freezers) is drain freeze up. This is usually caused by the defrost drain clogging, then freezing. On older units, it can also happen when the insulation (usually open-cell Styrofoam) around the drain gets 'water-logged', as it often does over the years, causing ice to build up inside the drain.
The first symptom, at least in top-freezers, is usually water under the crisper drawers, on the floor of the refrigerator section.
In side-by-sides and upright freezers it'll appear as a nifty slab of ice on the freezer floor, eventually running water out onto the kitchen floor.
These are quick and easy to make. Just cut a piece of #12 copper wire (strip from regular 12-2WG 'Romex' household wire) about 6 inches long and bend it around a 1/4 inch round rod. A screwdriver shaft works well for this, but any 1/4 inch dia. piece of metal will do.
Now when your refrig or freezer drain clogs and you find the trough under the evaporator full of ice, here's what you do.
Clear the
ice, open the drain (use hot water in your one gallon pressure sprayer and a wet-vac, and hang this little piece of copper on the defrost heater, so it extends down the drain. On most units, this is a black rod under the evaporator coil. Some use a radiant heater inside a glass tube, with which you can use this method, but you must carefully bend the hook on your copper wire to the diameter of the glass, being sure it puts no pressure on the glass.
This heater is responsible for melting all that frost that we don't have to deal with since the advent of Frost-free units, and it glows a dull red during the defrost cycle, so there's plenty of excess heat for our purpose.
Anyway, since copper's such a good conductor of heat, some of the defrost heater's energy will transfer down the copper wire, into the drain, and keep it open. What I like to call 'stupidly simple', this uses no extra electricity and works extremely well!
One precaution: hang this piece of copper *loosely* over the defrost heater. Don't squeeze or crimp it on, or you risk causing a "hot spot", damaging the heater.
Note: I get a lot of questions as to whether this wire will melt the rubber drain grommet or plastic drain tubing. I've installed literally hundreds of these wires (wish I'd kept count!) and have never seen any damage caused to those areas.
Keep in mind that when the unit switches into defrost, the inside of the freezer is at or below zero. Most defrost cycles last 20 minutes max, with the heater shutting down before the cycle
ends, so the warmth that travels down this little copper wire isn't nearly intense enough to melt anything but ice.
Hope this makes sense! Good luck
David
Summit... | Answered on Jun 15, 2018
Replace ignitor assembly should come with mounting bracket
Refrigerators | Answered 9 hours ago
Either cold control thermostat / control board problem , or air flow damper is open too much
Refrigerators | Answered 15 hours ago
My kenwood ksbsx17 has a e4 code wot is this please freezer making excess noise
Refrigerators | Answered Yesterday
Summit SCR1150 11.0 Cu. Ft. Full Sized Beverage Center Logo
1 questions posted
Top Summit Refrigerators Experts
Lawrence Oravetz
ray gallant
Tom Chichester
Are you a Summit Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Summit Refrigerators
Most Popular Question
need instructions owners manual summit
  • Refrigerators
