20 Most Recent Samsung RB2155 Bottom Freezer Refrigerator Questions & Answers
Need to put ice maker parts back on
Samsung RB2155... | Answered on Aug 03, 2016
sure, just pack it good to prevent damage
Samsung RB2155... | Answered on Jan 18, 2016
Fridge freezing up- and no fan or air circulation:
AT TIMES The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
Samsung RB2155... | Answered on Apr 10, 2015
they should be set about midway of ur dial not to max or full the higher settings are for extreme tempature enviromental conditions
Samsung RB2155... | Answered on Jan 06, 2015
samsung fridge freezer srs2028 srs 2029 problems
if you a have samsung model
SRS 2026 2027 2028 OR 2029 , then you probaly need to fit the rs21 repair kit - as the srs models are the earlier version of rs21 - and suffers from the same isssues .
there is an extra component you will need as well as rs21 kit - if you look under most of the videos there is a ebay link which takes you to ebay shop where you can pruchase samsung spares
check this video out on youtube
Samsung RB2155... | Answered on Aug 17, 2014
origional should be if you remove front kick plate
Samsung RB2155... | Answered on Jun 02, 2014
I SUGGEST YOU GET IN TOUCH WITH YOUR LOCAL APPLIANCE SPARE PARTS DEALER AND ASK HIM IF THEY MAKE DOOR SEALS TO ORDER.BACK HERE IN SOUTH AFRICA WE ARE GIVEN THE OPTION OF MAKING THE DOOR SEAL PROVIDED A SAMPLE OR THE EXACT SIZE IS GIVEN IF THE MANUFACTURE HAS NO STOCK.I HAVE ALSO NOTICED THAT IT IS THE FASTEST SOLUTION THAT SAMSUNG HAS IS TO REPLACE THE DOOR AND POCKET MORE MONEY FROM YOU THE CONSUMER.
GOODLUCK.
MOHAMED
Samsung RB2155... | Answered on Apr 26, 2014
Samsung RB2155 Bottom Freezer Refrigerator Logo
194 questions posted
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Refrigerators
Most Popular Question
samsung fridge bottom freezer freezer
  • Refrigerators
