20 Most Recent Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Questions & Answers
This problem is not uncommon with small compressors and the inexpensive plastic regulators they use nowadays. The one surefire way to stop it is ti install in in-line valve before the regulator outlet, even if it involves the double ended & threaded brass soupler so they both fit on. This way you can just turn the handles across the line effectively shutting off air flow. I have two pancake compressors and ended up doing the very thing.
Then when time comes to hook up a hose and tool, just switch the handle back and you have air.
Sirwriter
Craftsman 3 gal.... | Answered Yesterday
Check amazon for fuel bulbs. There 5-14 dollars match it up. Good luck
Craftsman 3 gal.... | Answered on Sep 21, 2017
compressor will not build pressure
Craftsman 3 gal.... | Answered on Jul 13, 2017
Sounds like the compressor has failed, more than likely a scored cylinder wall.
Craftsman 3 gal.... | Answered on May 19, 2017
There's a check valve in the air line between the compressor and tank that sounds like it's failed.
Craftsman 3 gal.... | Answered on May 14, 2017
It is definitely the little spring steel flappers in the head. They are similar to the reeds in a 2-stroke motorcycle engine -- if you've ever had one. They open up a little to let air in on the down-stroke and close off the air intake port on the upstroke. Probably just a piece of one has broken off and it will allow the compressor to pressurize the tank somewhat depending how much of the flapper has broken off. You will notice that your air gage needle on the compressor pulsates when it comes up to the maximum pressure it can attain with that piece missing.
There are two different sets of the flappers in the head -- one for air intake and one for allowing the newly compressed air into the tank. Buy them both and a new head gasket or "O" ring.
Good Luck, Richard
Craftsman 3 gal.... | Answered on Dec 16, 2016
unplug it and see if you can turn the motor pulley by hand, it should turn freely. If it does, check to see if the motor runs with the belt off. If the motor runs by itself then either the belt was too tight or the compressor is seized.
Craftsman 3 gal.... | Answered on Nov 11, 2016
How to rest air compressor ssr ep. 50 se
Craftsman 3 gal.... | Answered on May 02, 2016
sounds like the regulator is fualty.
Craftsman 3 gal.... | Answered on Mar 03, 2016
You may have dropped a valve in the compressor. Same thing happened to my compressor, and I've not actually been able to fix it.
Craftsman 3 gal.... | Answered on Jul 30, 2015
STOP. What pressure does the gauge show? If it's higher than it should be, drain the tank and replace the pressure switch. If it's not unusually high, then replace the pressure relief valve.
DO NOT let that compressor run at too high air pressure! A burst air compressor is a TERRIFIC bomb, and can kill you before you know what happened!
Craftsman 3 gal.... | Answered on Feb 26, 2015
When I turn compressor on it does not build up any pressure ?
Craftsman 3 gal.... | Answered on Jan 14, 2015
I have a new Durabuilt Air compressor Model # DP0200604
6 gal. tank, Wp 0f 140psi ; I need a owners manual that I misplaced. Where can I go to down load this item? FLT 04-2010
Craftsman 3 gal.... | Answered on Sep 27, 2014
You could try this link.
This is for megadyne tb2 310 belt (nlh6ltCOM)
http://www.solenttools.co.uk/performance-power-drive-belts/performance-power-compressor-drive-belt-nlh6ltcom-2051157-331171-.php
Craftsman 3 gal.... | Answered on Aug 26, 2014
Mike:
If you have air blowing out of the oil filler cap, I would suspect that the piston rings are shot. The piston rings are supposed to keep the compressed air above the piston, and air seems to be leaking past the piston rings into the crank case.
Craftsman 3 gal.... | Answered on Jul 08, 2014
0. Check the outlet it is connected to. (this has gotten me a couple of time with GFI outlets. :-)) If the GFI kicked the last time the unit was used then just reset it and go on with life. If the outlet is live (test with lamp or test gear) then on to 1.
NOTE: One of the most common issues is the start capacitor on the side of the pump motor. If the unit is connected to a power source and the pressure gauge is reading 0 when turned on and does not start at all, this may well be the issue. Otherwise it could by be the pressure switch cutoff is stuck. Locate and lube with VERY thin oil. I like Lock ease it is a petroleum distillate with a suspended graphite power. (DO NOT GET IN CONTACT POINT AREA ONLY IN MECHANICALS TO THE SWITCH.)
1. disconnect unit from power. (I like to hang the plug where I can always see it while working on the unit. If I don't see it when I return to work on the unit I can safely unplug it and go about the repairs if some less thoughtful person plugged it in while I was out.
We will not check the linkage between the pump and the motor to make sure nothing is jammed. With power DISCONNECTED turn the motor pulley to ensure freedom of movement. If this beastie rotates then off to the next step.
2. Check the pressure gauge to ensure that the tank is not actually already full. (Hey I have a Ph.D. and I actually have had this happen early before coffee.) Good hearted ribbing from Lawrence helped me to avoid that one in the years that followed. :-)
3. If the pressure gauge is reading above 50PSI then adjust the output regulator to full open to deliver pressure to the output line. Connect an output line, and a nozzle or other pnu tool to release pressure from the tank. and test for start by fumpping off pressure to 0 at the gauge. Then connect the unit to a power source and turn to the on position.
If this did the trick make sure to dump to pressure after turning the unit off. Take the unit outside and set it on the grass (while wearing eye protection open the petcock on the bottom of the tank. Move the unit around to drain water out of the tank. )
If this did not do the trick then you need to check the start capacitor on the side of the motor, the pressure cutoff switch and the wiring to the motor. Finally the brushes in the motor may have worn to the point that there is no contact at the commutator of the pump motor. The brushes are a pair of carbon blocks that rest against the commutator to supply electrical power to the coils within the motor which results in repelling and attracting magnetic fields and thus rotary motion. You can pickup the replacement brushes at a sears repair center or a very well stocked hardware store. (I just LOVE those places)
Let me know if this got you squared away. If not, then supply me with the results of these tests and I'll set you a hopefully more fruitful path.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/john_28069c9efb56199d
Craftsman 3 gal.... | Answered on May 24, 2014
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
369 questions posted
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Craftsman Air Tools & Compressors
Most Popular Question
durabuilt air compressor oil blowout l
  • Air Tools & Compressors
