20 Most Recent Apple iPhone 3G Questions & Answers
I know an iOS system recovery https://www.joyoshare.com/ultfix-for-win that provides free option to enter and exit the recovery mode instantly with just one click. You can give it a try. It also helps you to fix iPhone is disabled connect to iTunes, black screen, white Apple logo, etc. with no data loss. Get it at 50% off discount in this Easter activity: https://www.joyoshare.com/special/2019-easter-sales/
Apple iPhone 3G | Answered 22 hours ago
  • Start by tapping the "Phone" icon on your iPhone.
  • 2 Next, access your voice mail messages by tapping the "Voicemail" icon.
  • 3 Look at your list of current voice messages. If you have any messages that are eligible for recovery, you'll see an item at the very bottom called "Deleted Messages". Tap on this to access a list of your deleted messages.
  • 4 You should now see a list of deleted voice messages. If you see the message that you want to recover, tap on it and choose "Undelete".
  • 5 Your voice message will now be sent back to the main list of current voice mail messages.
  • 6 Repeat steps 1-5 for "each" message you wish to recover. This may take time!
  • Read more: How to easily recover accidentally deleted iPhone voice messages ' eHow.com http://www.ehow.com/how_4707121_accidentally-deleted-iphone-voice-messages.html#ixzz1A58SmNWv
    Apple iPhone 3G | Answered on Apr 10, 2019
    the same exact thing happen to me......then I purchased a new connector (I used the old usb so much with the ipod)...and bingo itunes recognized the iphone......
    Apple iPhone 3G | Answered on Mar 19, 2019
    As for this situation, I think you'd better try the 3rd-party program rather than iTunes. Just follow below steps to reach this goal. Download Leawo iTransfer ' Leawo iTransfer for Mac and install it.
    Step 1. Run Leawo iTransfer for Mac and Connect iPhone
    Launch Leawo iTransfer for Mac after installing it on your new Mac computer. When the software indicates that you can connect your iOS device, plug your iPhone to Mac via the USB cable. The software will automatically detect your iPhone and show the Libraries on the left sidebar. The files will show on the right part of the window after you choose a library.
    Step 2. Select Files to Sync
    Choose a Library and then all the files in the library will show on the right part of the software (Set the Music Library as an example). Click the transfer button (the right arrow in a dark-blue rectangle) at the right bottom to transfer all the files to computer. Or you can hold Ctrl key and click to choose certain files, and then right click the chosen files and choose "Transfer to > My Computer".
    Step 3. Transfer Settings
    After choosing files, a dialog of transfer settings comes out. In this dialog, you are able to check "Transfer to List" and "Save to Folder". Checking "Transfer to List" can make sure your files be transferred to iTunes; Check "Save to Folder" and click "Change" to choose a target folder to save the transferred files. If you are using a new computer and the iTunes is newly installed, I suggest you check both options. After choosing target folder, click "Transfer Now" to start to sync iPhone to new computer.
    Step 4. Syncing iPhone to New Mac
    When the transfer begins, you will see a dialog of transfer process. A progress bar in the dialog will show you the percentage of the syncing process. When the syncing process is finished, you will find all the files in your target folder and iTunes.
    backup-ios-to-mac-2q105sdtzs05eff3zz5zngrs-5-2.jpg For more detail, check: How to Sync iPhone to New Mac without Losing Data
    Apple iPhone 3G | Answered on Feb 21, 2019
    You can do this in iTunes - with the iPhone connected select the 'photos' tab and deselect the folder containing the photos, then hit Sync to remove them.
    Alternatively, just move the photos to a different location on your hard drive (out of any folder that is set to sync to iPhone), then connect to iTunes and hit sync.
    Hope that helps!
    Apple iPhone 3G | Answered on Feb 08, 2019
    Connect your iPhone to your computer. Start iTunes, go to "Photos" tab on top and in there, tick "Sync Photos From" and select the folder you want to Sync photos from. Once selected. click on Sync in right corner at the bottom.
    For more information: Transfer photos from PC to iphone 3s
    Apple iPhone 3G | Answered on Jan 29, 2019
    go to settings
    then mail,contacts,settings
    click on your account
    then click on password
    Apple iPhone 3G | Answered on Jan 25, 2019
    If you want to get the voice memo back, it's easy to get it with Leawo iOS Data Recovery.
    Leawo iOS Data Recovery will be helpful on this issue. This program enables users to recover deleted files from iOS devices, extract data from iTunes and iCloud backups. The following guidance will show you how to do that, and you can free download the software to have a try. Download Leawo iOS Data Recovery ' Leawo iOS Data Recovery for Mac and install it.
    Step 1. Run Leawo iOS Data Recovery and choose Recover from iOS Device.
    Step 2. Connect iPad to computer with USB and click the Start button.
    Step 3. The software will scan your iPad. When the scan finishes, select the files you need and click Recover.
    select-voice-memos-itunes-tzvgcq53ljs1u3lkj5hvgsq3-5-0_0.jpg For more detail, check: How Can I Recover Deleted Voice Memos from iPhone 6/6s/SE
    Apple iPhone 3G | Answered on Jan 23, 2019
    Though iPhone uses quite a different storage mechanism, still you can recover deleted or lost data (such as text messages, voice mail, contacts, photos etc) with a third party specific iPhone data recovery software called Tenorshare iPhone Data Recovery. I used it to recover deleted videos from iPhone 4s and it worked.
    You can give it a shot! Download it from http://www.any-data-recovery.com/product/iphone-data-recovery.html
    Here is a tutorial to guide you recover your voice mails:
    How to Recover Deleted Files from iPhone
    Apple iPhone 3G | Answered on Jan 08, 2019
    You can unlock your forgotten phone password by downloading this free software,no need going to apple shop and paying the service.
    IPHONE PASSWORD REMOVER
    Be sure you have a good working USB cable
    Here's the instruction
    * download the link above
    * locate the file (usually on download folder) and extract the file
    * run the program,instruction is already given on screen so you don't have to worry on the procedure.
    * reboot your phone
    * DONE
    Hope this solution helps...Thank you for visiting Fixya...
    Apple iPhone 3G | Answered on Dec 06, 2018
    ur iphone is not starting it is the problem of ur previous ios tht u r using u have to update ur iphone it would worlk normally
    for updating iphone
    put ur cell phone into recovery mode
    than it would be connected to itunes
    go to summery pannel and restore and update iphone
    Apple iPhone 3G | Answered on Nov 24, 2018
    You can follow the guides below to recover data from iPhone.
    Guide 1: Directly Recover Data from iPhone 4, iPad 1, iTouch 4
    Step 1 Connect your iPhone to the Computer
    Step 2 Download a plug-in for your device before scanning it
    Step 3 Enter the DFU Mode and Scan your iPhone
    Step 4 Check and Restore your Lost Data
    Guide 2: Recover Previous Data from iTunes Backup from All iOS Devices
    Step 1 Choose your Device and Select the Recovery Mode
    Step 2 Scan the Backup File of your Device
    Step 3 Preview and Recover Lost Data
    Apple iPhone 3G | Answered on Nov 16, 2018
    If your iphone screen damaged, don't open by yourself, please visit at https://smartrepair.io/ you may find nearest mobile store at your location.
    iOS Data Recovery World's best Data Recovery software for iPhone, iPad and iPod Touch.
    • Recover Lost/Deleted Data from iOS Device, iTunes Backup File and iCloud Backup.
    • Recover Lost/Deleted Photos, Videos, Contacts, Call Log, SMS, iMessages, WhatsApp Message, Notes, App Data and more.
    • Fix many iOS Errors without Data Loss.
    • Support to all iOS Device models.
    • Compatible with iOS 12 and work with the latest iTunes version.
    1 iOS Data Recovery Update ' Recover iOS Devices Deleted Lost Data with ease
    How to Recover Deleted Photos from iPhone
    How to Recover Notes from iPhone iPad iPod That Were Lost or Deleted
    Recover deleted Call History on iPhone with ease
    3 Easy Ways How to Recover Deleted iMessages on iPhone 2018 Update
    Apple iPhone 3G | Answered on Oct 24, 2018
    I'd recommend that you try this iPhone data recovery software that helped me before
    http://www.001-software.com/iphone-data-recovery.html
    hope this helps.
    Apple iPhone 3G | Answered on Oct 08, 2018
    This is because the audio is being routed through the car when it is connected. The car is not setup to play text sounds only calls & (depending on your connection) music.
    Apple iPhone 3G | Answered on Oct 07, 2018
    Break-up with him to prevent farther problem, I'm available right now,
    Apple iPhone 3G | Answered on Oct 02, 2018
    Do you have backups from your lost iPhone 4?
    If not, take a look at this guide about recovering iPhone contacts without backup.
    How to Recover Deleted Contacts from iPhone without Backup
    Apple iPhone 3G | Answered on Aug 30, 2018
    5,042 questions posted
    Popular Products
    Top Apple Cell Phones Experts
    jacobcheatha
    Level 1 Expert
    Marvin
    Marvin
    Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
    View Most Popular
    iPhone Apple
    • iPhone Apple
    Most Popular Question
    retrieve deleted voicemail messages
    • Cell Phones
