20 Most Recent Citizen Eco Drive Calibre 3100 #BT0000 07E watch Questions & Answers
The problem, as I have just discovered, is that when you go to the Citizen watch website listed above, you will get no help at all for the caliber 3100, "No document found..."
Try this link instead:
http://www.citizenwatch.jp/support/pdf/e310/e.pdf
Yes, this is the actual link to the full manual for the Caliber 3100 watch
Citizen Eco... | Answered on Mar 29, 2011
Go to "citizen.com" and on the upper right there is a menu. Click on "technical
support" and then on "recharge guides"
You will see instructions on recharging watches - some patience appears to be required!
Citizen Eco... | Answered on Feb 08, 2011
For all those who lost their Citizen watch instructions. Follow this link, fill in the details and download manual. http://www.citizenwatch.com/COA/English/settings.asp Interactive setting instructions on this site is very helpful as well.
Citizen Eco... | Answered on Jul 29, 2010
You can get instructions from the Citizen web site.
support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on
"get setting instructions"
Citizen Eco... | Answered on Jul 24, 2010
Go to "citizen.com" and on the upper right there is a menu. Click on "technical support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on "get setting instructions"
or
Go to "citizen.com" and click on "watch finder".
Put your watch model into the search box on the left and click on
"search".
Click on the watch to view details.
On the right is a small menu, click on "get technical info"
On the right you you will see a list of instructions you can download.
Citizen Eco... | Answered on May 04, 2010
Citizen,
Citizen Eco... | Answered on Feb 13, 2010
Walmart, Kmart do carry Citizen watch leather-bands.
Citizen Eco... | Answered on Dec 05, 2009
The point of a radio-controlled watch is that you should not have to move the hands manually. It is meant to respond to a time signal send from various places in the USA, UK, Germany, Japan and (I think) China.
The signal's strength varies considerably, depending on where you are located and the ambient temperature. It may need some application and persistence to get the watch synchronized with the signal, this will cause the hands to move to the correct local time - even then it may need correction if you are in a different UTC time zone or on Daylight Saving Time (DST) locally. Not knowing the make complicates the validity of any information.
I have found that the sync signal is broadcast on the hour for about five minutes and is best received at night where the signal travels further.
Ensure your watch is fully charged and leave your watch by a window overnight for best results.
If you still have difficulty, use an internet search to find the nearest broadcast station to where you are and work out which direction-facing window is best sited to face it.
I have two RC watches - one Citizen and one Casio. One likes to have the left side of the watch facing the window and the other favours the 12 o'clock facing the window, As I don't know the make of your watch I would recommend trying to place it in various orientations until you find one that works for you. I have found the whole set up performs best in cold air situations - and so are more reliable in the winter.
Guessing further, If you bring up the signal display function it may force the watch into signal sync mode - always remembering the 'on the hour' signal broadcasts. You may also find a way of adjusting the hour to suit if it differs for you once it is synced.
Citizen Watches | Answered on Aug 21, 2019
Best check out the Citizen website, or vintage watch sites. :-)
Citizen Watches | Answered on Jul 17, 2019
It will be very difficult if you don't have the right tools
You would need a hand press of the right size. You would need a tool to open the case back, you would need to know how to remove the crown and stem in order to remove the dial with the movement. It would be also a good idea to have it tested for water resistance and you would need a special aparatus to do that. You may also need to replace the I ring or gasket.
Citizen Watches | Answered on Jun 28, 2019
sorry not that I am aware of .take it to a shop that sells them.
Citizen Watches | Answered on May 26, 2019
Citizen Eco Drive Calibre 3100 #BT0000 07E watch Logo
Popular Tags
20 questions posted
Top Citizen Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Are you a Citizen Watch Expert? Answer questions, earn points and help others
View Most Popular
Citizen Watches
  • Citizen Watches
Most Popular Question
set citizen 3100
  • Watches
