20 Most Recent Bulova Watch Questions & Answers
I know it's been a while since you posted this question, but I just had to do this with mine after it was lost in a drawer for a few years, and I had no luck googling so I had to figure it out for myself.
First, you have to remove the band, but you only need to do this on one end, not both. I did this by twisting the watch body around while holding the cloth/leather portion of the band still, letting the elastic part twist around with the watch body. Then, just use a fingernail to pull on the ridges on one end of one of the pins that are holding the band on; both ends are spring-loaded, so it doesn't matter which. Twist the watch body back around, and you'll now be able to flip it over to expose the back.
Now, take a thin, strong blade (I used a butterknife) and pry off the back plate. There's a tab on the upper right edge of the back plate to make this much easier. Since it probably came off in the process, place the rubber sealant ring back around the edge of the backplate.
Once you have the back plate off, there's a thin metal piece covering the battery that's held on with one screw. Remove that with an eyeglass screwdriver or any other similarly-sized Phillips-head screwdriver. There's just a small tab holding the metal piece in place on the other side, so just flip the metal piece up a bit and pull it out. You can now take the battery (a CR2016 3-volt watch battery) right out.
But wait, what's this? Beneath that battery, separated by a small plastic insert, is another, smaller one, a 377/376 1.55-volt watch battery. The 377/376 powers the analog movement, while the CR2016 powers all the digital stuff and the backlight.
Replace both batteries, making sure to place the plastic insert back on top of the 377/376 before putting the CR2016 back in, and follow the steps in reverse to put the watch back together. You may have some difficulty getting the back plate back on, but I just pressed one side in and held it while I tapped the other side down with my fist.
Bulova Watch | Answered on Aug 17, 2019
Copy and paste this link. It will take you to Bulova's service centerwhere you can download instructions for any of their watches.
http://bulova.com/service/servicecenter.aspx
If you appreciate me finding this answer for you then please rank this solution as "fixya" or at least "helpful" as what I have found for you will solve your problem. :-)
Bulova Watch | Answered on Apr 27, 2019
The watch has four buttons. The lower left button is labeled MODE on the face of the watch. There are four modes and pressing the MODE button will step through each mode until you return to the mode at the start of the process. Start at the "Normal" timekeeping mode and press the "MODE" button three times until the digital display rightmost two figures for seconds flash.
Press the lower right button labeled RESET until the item you want to change is flashing. Pressing RESET cycles through seconds, minutes, hours, day, month, day of the week in the top sub-dial and then back to seconds again.
When the item you want to change is flashing press the top right button labeled START to step the displayed item to the value you want. When you are satisfied all the settings are correct, press the lower left button marked MODE to return to normal operation.
Coleman 40-408 User's Guide
Bulova Watch | Answered on Apr 26, 2019
The FC 270 does not have a second hand, the red tipped hand points to the month.
Bulova Watch | Answered on Mar 26, 2019
Please tell me how I can get this watch on the right time and date
Bulova Watch | Answered on Mar 24, 2019
www.seikowatches.com/support/ib/index.html
Bulova Watch | Answered on Sep 27, 2018
Try to wind it up using crown (winder). If it has automatic winder it will wind itself up while you wearing it on wrist.
Bulova Watch | Answered on Sep 08, 2018
i bought a world time 50m wr watch or my boyfriend from bidup tv but no operating instructions arrived. How do i reset the digital time and date.
Bulova Watch | Answered on Aug 23, 2018
Hi need to get a date change although I have the instructions it's all about the buttons that's it sooooooo please help me plus I need to stop it from beeping every hour
Bulova Watch | Answered on Jun 12, 2018
answered as soon as they are seen. Many thanks for reading Gamecih download for android which is offered for all OS, I mean you could download and install
Bulova Watch | Answered on Dec 28, 2017
they cost about $60. they are cheaply made throw away dress watches. you didn't get ripped off. you just wasted your money on cheap chineese garbage, you are not alone.
wear the watch, throw it away when it stops or you don't like it anymore.
Bulova Watch | Answered on Apr 25, 2017
Thank you for contacting FixYa.
You can find Bulova instructions here:
http://www.bulovaspecialmarkets.com/service/servicecenter.aspx
Jewel
Bulova Watch | Answered on Dec 14, 2016
Go to "Stauer.com" and at the bottom of the page you will find "customer service".
Click on this and your customer support details will appear.
Bulova Watch | Answered on Oct 26, 2016
Go to
http://www.2instructions.com/search.php?cmarque=AURIOL&modele=RADIO%20CONTROLLED%20WATCH%202-LD2970-4
Bulova Watch | Answered on Jul 28, 2016
Bulova Watch Logo
1,052 questions posted
Top Bulova Watches Experts
Janelle Schoonover
Janelle Schoonover
Anthony Ward
Anthony Ward
Are you a Bulova Watch Expert? Answer questions, earn points and help others
View Most Popular
Bulova Watches
  • Bulova Watches
Most Popular Question
watch
  • Watches
