20 Most Recent Toshiba Satellite A215-S7422 Notebook Questions & Answers
Hello there!
You should try a different player. I personally use Media Player Classic http://mpc-hc.sourceforge.net/
VLC is also a very good choice: http://www.videolan.org/vlc/download-windows.html
I hope this helps! Thumbs up if it does!
Toshiba... | Answered on Apr 18, 2019
The most common problem with this is an easy fix. You should try updated your video card drivers. If you can't find them on the manufacturers website, the easier route is to download slim drivers. It should get it for you with no problem. Although, after you may want to turn off the service starting up at boot. If this doesn't help you could also have a virus. I've read that the FBI virus can cause lines to come up. You should try running windows defender offline on your PC. You'll need an empty USB stick or blank CD/DVD. If there are not the issue. Then it could be hardware. The video card could be going out. It could be that your motherboard may be having issues, or even your screen.
Toshiba... | Answered on Aug 05, 2014
try changing memory
Toshiba... | Answered on Mar 26, 2014
Having done all of that, if the drive D is not there, replace the drive as it is likely to be faulty.
Toshiba... | Answered on Jan 18, 2014
Getting this error during the set up process indicates a hard drive failure, usually a bad sector or the wrong system is trying to load; GPT instead of MBR and a partition cannot be created. Generally it will load and then be unable to read from the bad sector or just will not boot, creating a problem, system glitch, or blue screen error. You will have to replace the hard drive.
Toshiba... | Answered on Nov 27, 2013
Try removing the battery. It might be damaged and overloading the laptop. Also, before you replug the AC cord, press power for at least 5 seconds.
Toshiba... | Answered on Aug 15, 2013
Viruses can make this kind of problems, but also overheating. Boot to Safe mode with networking, by pressing F8 after power on, and download Speed Fan (AMD CPU) or Core Temp (Intel CPU). Start some movie and see the maximum temperature, it should not pass 70 degrees Celsius.
Toshiba... | Answered on Jul 21, 2013
Problem with chipset od graphics. This can be repaired with BGA rework machine in laptop service.
You can take it to the laptop service to reset BIOS or, if this does not help, to reprogramm BIOS.
Hello, yes you are right for that USB replacement you need to replace the motherboard, as USB port is Onboard.
Cheaper solution... there are adapters available that can convert your serial port to USB. Then purchase a 4 (or more) USB hub, to plug into that.
And that's the only issue your Laptop has? No messages that pop up or displayed as you try and run them? Vista OS, right? At this stage all I can think of another program is stopping them like Windows Defender? is that on your system and running/enabled if so look into it to see if it's blocking restricting applications running.
Toshiba... | Answered on May 03, 2013
windows users password
Toshiba... | Answered on Dec 08, 2012
Hello
The factory reseting procedure is defined on the link mentioned below
http://aps2.toshiba-tro.de/kb0/HTD9102IR0000R01.htm
Good Luck, and do rate the solution if got help
Toshiba... | Answered on Sep 24, 2012
problem with the battery, try another battery. this will fix it.
Toshiba... | Answered on Jul 17, 2012
Possible that PC is hanging up as there is fault on the OS (operating system) or a virus in the OS. Also it is possible that the backup battery (CMOS) has low voltage or the memory card is a suspect. In this case you need to check the voltage and also try and swap a memory card. Sometimes the memory card connections can be faulty either on the card or on the slot. Cleaning the slot and card must be done before you try a replacement. If the PC boots and fails then the hard disc can have bad sectors or is corrupt. However if there is no result the motherboard also can be suspected. In this case you might need the help of proper tools and equipment support to do a chip level service
Toshiba... | Answered on Jul 03, 2012
Toshiba Satellite A215-S7422 Notebook Logo
275 questions posted
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
need bios password
  • Computers & Internet
