20 Most Recent Frigidaire GLGH1642DS Front Load Stacked Washer / Dryer Questions & Answers
try checking it out here
appliancepartspro.com or repairclinic.com
have your model #
sb inside the freezer compartment or frig.
Frigidaire... | Answered on Jan 21, 2018
Check the wiring legs on the machine where you put the new cord on and make sure that the wires are not touching each-other.
Frigidaire... | Answered on Nov 21, 2010
There is no spring inside the drum that may come off except for the spring and wire hoop assembly that securely holds the door seal to the outer lip of the door opening.
Check to make sure that this spring is in its proper position at the bottom of the door opening as shown in the photo above.
It will help determine what really the spring is if you can post photo of the said spring including the exact model number of the machine. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You can continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Frigidaire... | Answered on Aug 08, 2010
Remove the lower panel on the back side .
Frigidaire... | Answered on Apr 03, 2010
step 1- remove the face of the dryer, then remove the cover for the fan, check to see if object is blocking the fan, if object is there , remove object, if not go to step 2
step 2- check to see if the belt is broken, if the belt is broken replace the belt.
step 3 - remove the belt from the motor and turn the dryer on, if the motor doesn’t turn then you need to replace the motor.
These are the only causes.
Post further comment for more help.
Good Luck!!
Thanks
Frigidaire... | Answered on Jul 10, 2009
turn the washer over on its side and look for a broken belt or broken direct drive coupler for the tub, this is how it spins.
Frigidaire... | Answered on Jul 09, 2009
You may have to change the heating element.
Frigidaire... | Answered on Jul 04, 2009
The rear drum support must be replaced.
Part number 5303281153
Frigidaire... | Answered on Apr 21, 2009
Jane, check to make sure that the drain hose has a air gap in the drain. Sometimes you will get a siphoning effect if you don't have the gap or it is pushed down to far in the drain. If this is not your problem, it's probably a timer issue...Catriver..post back
Frigidaire... | Answered on Jan 14, 2009
first try moving your drain hose higher it can cause this problem
Frigidaire... | Answered on Oct 04, 2019
Unplug it for 5 minutes. If that doesn't work, you may need to empty it of water by lowering the drain hose into a pail lower that the door.
Frigidaire... | Answered on Sep 14, 2019
Hello Deena,
Error Code e21
means the water is not pumping out fast enough.The most likely reason is because the washer drain filter is clogged.
Here is a solution:
  1. Pull the machine out from the wall.
  2. Then take the panel out in the rear. Once the panel is off you will see the drain pump.
  3. Disconnect the drain Tube between the Tub and the Pump.
  4. Look inside the pipe you will find the Drain Filter.
  5. Clean the filter out ( you will be surprised of "things" found in the filter) then put the machine back together
  6. Try a full cycle.
That should end your problem.
Best of Luck!
JP
Frigidaire... | Answered on Aug 31, 2019
Frigidaire GLGH1642DS Front Load Stacked Washer / Dryer Logo
Popular Tags
21 questions posted
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
acsess belt check tension
  • Washing Machines
