20 Most Recent LG RH1999H DVD Recorder/HDD Recorder Questions & Answers
It'll probably be cheaper to replace the DVD player. For future reference, at the front of the tray, there should be a tiny hole. If ejection fails, stick a straightened paper-clip in the hole. This should release the shuttle/tray and you won't need to open the whole machine
LG RH1999H DVD... | Answered on Nov 11, 2018
Hi Dan. Perhaps the laser lens is dirty. Get a cleaning disk from Poundland. Should sort it out
LG RH1999H DVD... | Answered on Feb 03, 2018
There are no specific settings for playback on this machine?
If the lazer does not read discs and the display shows NO DISC or UNKNOWN DISC then the lazer pick-up needs replacing.
I believe that the lazer pick-up for this LG recorder has been discontinued?
LG RH1999H DVD... | Answered on Jan 03, 2017
I would suggest firstly checking the drive belt on the mechanism.
Otherwise if not follow these instructions: When you remove the DVD mechanism open the metal case top and bottom. Underneath the mechanism with the bottom cover removed you see a small PCB soldered to the loading motor pins. Remove the small PCB turn the PCB around and you will see a micro-switch on the PCB. Replacing this will solve your problem.
Did you try to contact LG support?
LG RH1999H DVD... | Answered on Nov 19, 2015
The problem lies in a defective electrolytic capacitor in the Power Supply Board. Its the 1000 mf 25 volt. If you look carfully you will see its bulge. just repalce it and problem solve.
LG RH1999H DVD... | Answered on Apr 15, 2015
Find the web-site for your remote control, and download the manual for the remote. The remote needs to be programmed to send the correct signals to your TV.
LG RH1999H DVD... | Answered on Apr 08, 2014
Hi Andrea
Try install attenna prior doing some auto programming.
LG RH1999H DVD... | Answered on Jan 28, 2014
LG RH1999H DVD Recorder/HDD Recorder Logo
118 questions posted
Steve Allison
Steve Allison
View Most Popular
  • LG Televison & Video
Most Popular Question
lg rh387h dvd wont go past screen
  • Televison & Video
