20 Most Recent U-Line 2175BEVS-01 Uline Beverage Center Left Hinge - Black Interior - Stainless Steel Questions & Answers
E5 means that the unit is 10 degrees warmer than the set point for more than 12 hours. You may need service to help you find out if its a sealed system or maybe a thermistor in the wrong location
U-Line... | Answered on Oct 08, 2009
Put it in the off position. Turn the knob to the right. If the refrigerator comes on then continue to turn the knob to the right until you get to the temperature you want.The more you turn to then right colder it should be. Turning it back makes it warmer.
U-Line... | Answered on Jan 09, 2019
Since you did not mention what make it is .
Its usually dirt in your door seal causing your refridgirator to understand its not closed since its not sealing properly . clean the door seals and try .
Or there is a technical glitch in electrical system and you need a repairman .
Also there is usually a way to disable the alarm and you need to check your user manual for that to disable it ill its fixed
U-Line... | Answered on Jun 01, 2018
ICE CUBES IN ICE MAKER HAVE LIKLEY SHRUNK
AND ARE NOW JAMMED IN ICE MAKER INSTEAD OF FALLING OUT
CHECK THE ICE MAKER FOR JAMMED CUBE
U-Line... | Answered on Jul 21, 2017
U-Line 2175BEVS-01 Uline Beverage Center Left Hinge - Black Interior - Stainless Steel Logo
8 questions posted
Top U-Line Refrigerators Experts
Elie Balas
Marvin
Marvin
brokenrubber
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • U-Line Refrigerators
Most Popular Question
am getting flashing message e5 temp
  • Refrigerators
