20 Most Recent Frigidaire FRT18G4A Top Freezer Refrigerator Questions & Answers
Hi thanks for your question. the problem with your fridgethethat the drain tube is clogged up. the drain goes down between the walls, down to the drip tray, at the bottom by the drain pan. to repair. . the fridge has to be turned off for at least 24 hrs. to thaw the ice in the drain tube. then using a small plasti, push small hose up the drain tube,the bottom at the drain tray. blow up the tube to clear. thanks the appliance doc. please rate my answer.thanks.
Frigidaire... | Answered on Jul 16, 2013
Yes you need to adjust the thermostst located inside the fridge compartment to change the temp. setting of the fridge.
Regards.
PLZ. dont forget to rate my suggestion.
Frigidaire... | Answered on Jul 24, 2011
yes it should be fine how ever you may need to run the unti for about fifteen minutes then shut it off four half hour or so then start it back up you should not have nay problems with it./
Frigidaire... | Answered on Nov 12, 2010
You can lay a fridge down if you do it right...this tip will tell you how to do it so that it will work again when you get it moved and set it back up.
Moving a Refrigerator What is the best way
heatman101
Frigidaire... | Answered on Oct 04, 2010
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Frigidaire... | Answered on Sep 30, 2010
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Frigidaire... | Answered on May 24, 2010
the freezer actually cools the fridge via a fan usually located in the "ceiling" of the fridge. make sure this is working and check yur temp contols make sur they are adjusted right
Frigidaire... | Answered on Apr 24, 2010
Frigidaire FRT18G4A Top Freezer Refrigerator Logo
27 questions posted
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Sal De
tom wright
tom wright
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
frigidaire transported long distance
  • Refrigerators
