20 Most Recent U-Line ?chelon 2175RB-00 Questions & Answers
I believe this an electronic verstion if so not able to jump
U-Line ?chelon... | Answered on Nov 22, 2013
HI
Visit the U-line website and under customer service you will see parts locator. You should see a distributor to purchase parts from. www.u-line.com
U-Line ?chelon... | Answered on Oct 23, 2009
If your motor and compressor isnt running then replace the control. If the compressor tries to run but kicks out then you need to replace the fan. You can always bypass the thermostat to check everything before you guess at it.
U-Line ?chelon... | Answered on Oct 08, 2009
If its the 2175 then check the display. What is it telling you. Blank?If so unplug your unit wait 5 minutes then plug it back in. If its showing er then you need to call for service. If it shows -- then it needs to be reprogrammed.
If the refrigeration motor is running and it is not getting cold then it probably is low on freon the gas that is used for refrigeration. Also if the motor only runs for a few minutes then stops it is possible that the cold control is bad, This is a common problem in refrigerators and can be fixed by replacing the control. First you must determine that the motor is in fact running. If the motor is running the motor should feel warm to the touch after 10 to 20 minutes of operation, and you should feel some cooling in the refrigerator on the cooling or evaporator coil. If the motor is running and getting warm or hot and you feel no or very little cooling then it is in fact ether low on freon or a component in the refrigeration system is malfunctioning. Freon can only be replaced by a certified technician.
U-Line ?chelon... | Answered on Oct 07, 2009
Ok On the display hold the up arrow for 5 seconds then let go. It will tell you the temperature. Do you have and er at the display? Is the unit outside? What is the temperature(ambient) around the unit? If you hold the up and down arrows together for 5 seconds then release it will show you thermistor temperature for 2,3, and 4 You should only get 2 to give a temperature. 1=refrigerator temp and 2=evaporator temp.
Make sure the condenser is clean from dust.
U-Line ?chelon... | Answered on Jun 29, 2009
The sound you are hearing is the open door alarm. Make sure your door is able to close completely. If you have installed panels make sure they are aligned properly on the door and not getting caught up on the cabinets beside the unit.
U-Line ?chelon... | Answered on Feb 13, 2008
Put it in the off position. Turn the knob to the right. If the refrigerator comes on then continue to turn the knob to the right until you get to the temperature you want.The more you turn to then right colder it should be. Turning it back makes it warmer.
U-Line... | Answered on Jan 09, 2019
Since you did not mention what make it is .
Its usually dirt in your door seal causing your refridgirator to understand its not closed since its not sealing properly . clean the door seals and try .
Or there is a technical glitch in electrical system and you need a repairman .
Also there is usually a way to disable the alarm and you need to check your user manual for that to disable it ill its fixed
U-Line... | Answered on Jun 01, 2018
U-Line ?chelon 2175RB-00 Logo
23 questions posted
Top U-Line Refrigerators Experts
Elie Balas
Marvin
Marvin
brokenrubber
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • U-Line Refrigerators
Most Popular Question
frig getting drinks cold now not
  • Refrigerators
