20 Most Recent Acer Aspire 5100-5022 Notebook Questions & Answers
its on its way out i would replace it
Acer Aspire... | Answered on Jul 08, 2017
GET A VALID WINDOWS XP PROGRAM DISC AND IT WILL ALLOW A REPAIR OR WILL LOAD FRESH WINDOWS XP PROGRAM will boot itself once boot device priority is set to cd dvd rom to boot first. WHEN COMPUTER POWER IS TURNED ON HOLD F2 as computer comes on iwill come up in bios mode choose boot priority to change boot sequence from harddrive to cd or dvd rom first
Acer Aspire... | Answered on Jun 17, 2016
Take battery out. Unplug power. Push power button. reconnect battery. press power it should start. If you have a slim model you may have to take the bottom off to access the battery. The 4 black blocks on the bottom once inside are the battery cells. About the middle of these cells is a cable that connects to the motherboard. unplug it... press power button. now connect the battery and close the laptop back up. press power and it should start.
Acer Aspire... | Answered on Sep 09, 2014
I just sold my AS5103 with a new HD exhibiting the same problems, as i said replaced the HDD, have you tried running a manufacturers HDD testing utility and if you do only 2 don't have to be changed to IDE in the bios before testing, WD & i think its Hitachi.
Acer Aspire... | Answered on Jul 26, 2014
the only solution is for you to call the acer tech support and they can generate a password for you to gain access to your hard drive and bios.
visit: http://www.acerpanam.com/synapse/forms/webpage.cfm?siteid=7117&areaid=2&website=AcerPanAm.com
Acer Aspire... | Answered on Nov 13, 2013
Alan, this is a product support website. As such they do not sell, nor buy. Just try to help people.
How about posting the laptop manufacturer name, and model number?
The model number can be found on the Bottom of the laptop.
Post back in a Comment.
Regards,
joecoolvette
Acer Aspire... | Answered on Jan 06, 2013
check the display on the external monitor by connecting it through the vga port of the laptop, check whether the display is coming or not, if coming then its the problem of your screen
Acer Aspire... | Answered on Dec 16, 2012
hai my acer laptop bl51 drivers is not install plz send me acer drivers my e mail is .. imtiazbaig90@gmail.com
Acer Aspire... | Answered on Sep 12, 2012
To delete the Acer Aspire Notebook HDD user password, go to http://www.unlockbiosrecovery.com/Unlock_Acer_HDD.php The link above will show you to enter 3 wrong password and then copy down the 5 or 8 digit code it displays with Disabled message. Purchase the Acer HDD master password from the link above and submit the code and your model and they will email you the bios master password to unlock your Acer HDD in an hour.. They guarantee it to work or your money back and I have used them successfully dozens of times, saving me a ton of time and money.
Acer Aspire... | Answered on Sep 12, 2011
The other way is to right click your desktop go down to graphic options and output to monitor.
Acer Aspire... | Answered on Jul 04, 2011
Hi liquidblue7,
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left from the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F10 or F6, depends on the key designed on the keyboard to toggle between displays.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the issue not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
Acer Aspire... | Answered on Jun 12, 2011
You may have not installed soundcard driver yet. Do install it, and ensure you install MSUAA before installing the souncard driver. Good Luck
Acer Aspire... | Answered on May 12, 2011
Hi
You could try hitting the f10 key at the top of your keyboard as soon as you start the computer that should take you into factory restore to start with it looks likes its loading windows but in about a min it takes you into the option to take back to factory settings
If f10 dont work try alt\f10 or the blue fn\f10
if none of them work hit the delete key on startup and go into bios to make sure that f10 is not disabled because sometimes it is by default disabled
But be very carefull not to alter anything else in the bios or you could and probably have big problems just enable f10 0r f12 if they are disabled then hit save click yes
windows will then restart and try the f10 key again
good luck
Acer Aspire... | Answered on Nov 13, 2010
I think that is a driver problem, try to reinstall de windows OS and it may function, then you can download the original complete drivers of http://support.acer-euro.com/drivers/notebook/as_3680.html depending of the OS that you install.
Acer Aspire... | Answered on Oct 11, 2010
You probably installed Windows from a "generic" CD-ROM.
Reinstall Windows, from the ACER-modified Windows "System Restore" disk, and all the correct device-drivers will be automatically installed.
Or, find another computer with Internet access, and a CD-writer.
Access ACER's web-site. Click "support" and "download", and download the AUDIO and NETWORK and MOTHERBOARD and VIDEO drivers to a folder on the computer.
Burn the contents of that folder to a CD-recordable.
(Since you say that your 'SM Bus Controller' is not working, you won't be able to use a USB memory-stick on your computer.)
Move the CD-R to your computer, and install the MOTHERBOARD driver, and then the other drivers, from the CD.
Acer Aspire... | Answered on Sep 28, 2010
Acer Aspire 5100-5022 Notebook Logo
Popular Tags
184 questions posted
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
bios acer ms2279
  • Computers & Internet
