20 Most Recent Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Questions & Answers
"Prepare for the worst" This is a problem i'm currently dealing with at the moment, ice maker thaw'd and refroze the ice as a block, binding the crusher turbine till it quit working. then water dispenser started spitting till it quit working, but anyway i disconnected the ice maker and water dispenser power hookup, because when i tried to use it it was drawing off the power of the fridge. now i'm to the point where fridge clicks like the relay is going out. in the back of the freezer below the ice maker tray i removed the clip or screw to where when it clicks i can hand spin the cooling fan on the click, and fridge starts up and runs, but don't remove this panel because having it on helps the air push into fridge compartment and keeps cooling elements from turning to a block of ice, " so long story short " its either your cooling fan or relay on chip board that starts cooling fan, i'm no expert but this is where i'm at hope it helps.
Whirlpool 25.6... | Answered on Aug 07, 2019
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Check ur cold control thermostat, ur thermistors in both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as per ur model ), ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly.
Often, the first thing that folks do when their refrigerator starts to feel warm is turn both controls on the coldest settings.This is exactly the WRONG thing to do.Turning the cold control to the coldest settingwillkeep the compressor running longer and make lots of cold air.
But turning the air door to the coldest settingclosesthe airway to the food section. Lots of cold air is made, but most of it stays in the freezer section, and the food section actually getswarmer.
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
THE COMPRESSOR:
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, some located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur start winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
TO REPLACE RELAY AND CAPACITOR WITH A HARDSTART KIT YOU CAN USE
A 3 in 1 start kit for compressors sizes 1/4 through 1/3 HP. And a 5 in 1 for higher H.P. (BE SURE TO MATCH WITH UR COMPRESSOR MODEL NUMBER AND TYPE) The kit includes relay, capacitor, and overload device, pre-wired. The kit will replace all 3 electrical components on capillary refrigeration systems. For newer systems with a run capacitor use proper kit. For smaller horsepower compressors useTJ90RCO810.
The wire set up is as follows the red wire goes to the right side of compressor prong, the white wire to the left side prong, the black wire to the center prong, and the 2 other black wires go to the power and the ground connection
Lastly you should also check ur THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required.
1-3 TEMPERATURE CONTROL
As the food in the fridge gets colder, it gives off less heat, and the air inside the fridge will remain colder. A thermostat called aCOLD CONTROLwill cycle the cooling system on and off to keep the temperature inside your fridge within a certain range. You can adjust that range using one of the dials within your fridge.
On most fridges, all the cold air for both the food compartment and the freezer compartment is produced in one evaporator. Since the freezer is so much colder than the food compartment, most of the cold air that is produced circulates to the freezer compartment. Only a small amount is needed in the food compartment to keep it down to the proper temperature. This amount is adjusted by a smallAIR DOORin the duct between the evaporator and the food compartment. The control for this air door is the other of the two dials within your fridge.
If you hear your compressor "short-cycling" (starting and stopping at short intervals) try jumping across the two leads of the cold control thermostat ( in the fridge compartment) with an alligator jumper. You can also check both for live voltage current and ohms- If there is a greenthirdlead, ignore it for this test; it is the ground wire. If the fridge starts running constantly, the cold control is bad. Replace it.
To test or change the cold control, first Pull the knob off it and remove any plastic cover plate or housing from it.
You will see two wires leading to it. There will also be a thick, stiffCAPILLARY TUBEattached. The capillary tube is the liquid-filled temperature-sensing element of the cold control, and operates in the same manner as a thermometer
The air damper, baffle or diffuser is the device that balances the air flow from the evaporator fan housing. This normally is a mechanically controlled baffle or flapper that controls the amount of cold air entering the fresh food compartment. If the baffle is damaged or the linkage to the control knob is damaged, then you may not have enough cold air entering the fresh food compartment resulting in higher than normal temperatures. This baffle or damper will be located where the cold air enters the fresh food compartment.
Troubleshooting Thermistor Problems in Refrigerators How to Test your Defrost Timer
Whirlpool 25.6... | Answered on May 23, 2019
Hi, this problem will be with either the starter for the compressor or could actually be the compresser itself. Both of these can be replaced but it is not something any one should do unless they have done this before and know what they are doing.
Whirlpool 25.6... | Answered on Feb 18, 2019
How to remove the door handle
Whirlpool 25.6... | Answered on Dec 11, 2018
Whirlpool Refrigerator service center Hyderabad. the efficiency of your equipment increases extensively if; the servicing or changing obligations can be finished via Our service center technicians. Your Fridge may not work properly. more of people purchase Whirlpool Refrigerators. If you have any problem with your whirlpool fridge then visit us we have the topmost service agents to fix your Refrigerator issues at your doorstep http://aktechnoservice.com/whirlpool-refrigerator-service-center-in-hyderabad
whirlpool refrigerator service centre in hyderabad-3rnaeo200p5jvdfftsegpbfu-3-0.jpg
Whirlpool 25.6... | Answered on Sep 07, 2018
The refrigerator/freezer defrost system can be checked by manually initiating a defrost cycle. There
are two methods of initiating the ADC Test Mode.
First Test Method:
1. Turn the thermostat off for 15 seconds.
2. Turn the thermostat on for 5 seconds.
3. Turn the thermostat off for 15 seconds.
4. Turn the thermostat on for 5 seconds.
5. Turn the thermostat off for 15 seconds.
6. Turn the thermostat on for 5 seconds.
7. Turn the thermostat off.
In 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal closed). NOTE: The test mode will terminate when the bimetal opens. If the refrigerator/freezer is already in defrost, Test Mode can be terminated by unplugging the refrigerator/freezer from the wall outlet and waiting 30 seconds before plugging it back in. The refrigerator/freezer should immediately go into cooling mode if the thermostat is closed.
If this first test procedure fails to make the ADC initiate a defrost cycle, try the following procedure to make the ADC begin the Test Mode.
Second Test Method:
1. Disconnect the refrigerator/freezer from the wall outlet for at least 30 seconds.
2. Turn the thermostat off.
3. Reconnect power to the refrigerator/freezer.
Within 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal close). If the unit fails to go into the defrost mode during this test, the problem may not be with the ADC. A defective bimetal may be the cause of the failure. The ADC will only go into a test mode if the bimetal
is closed. If the ADC senses an open bimetal it will return to the cooling mode within 3 to 8 seconds.
HELPFUL HINT: Upon entering the Test Mode, the relay mounted on the ADC board should turn off the compressor and turn on the defrost heater. Listen for the relay to click.
• If the relay clicks one time when entering the Test Mode, check for continuity in the defrost heater.
• If the relay clicks two times, check for an open bimetal.
Whirlpool 25.6... | Answered on Apr 13, 2018
Be sure to check the door seal.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Whirlpool 25.6... | Answered on Mar 03, 2018
check to see if it is level front to back and side to side if not level the ice maker can run over the back and down on coil, you can use a hair dryer to defrost it s quicker. if digital set refrigerator to 38 degrees. you may have problem with defrost control.
Whirlpool 25.6... | Answered on Mar 02, 2018
what's the model number send the full model number off of the machine
Whirlpool 25.6... | Answered on Jan 21, 2018
Hi I t seems like the Defrost timer is not working or is stuck. It could also be the defroster coil but probably not. The timer is located in the front of the refer where the toe kick is . remove the toe kick, check for a square or rectangle box with a big plug on the back. that is probably it. Check with the appliance zone online you need the Mod. # for the parts blow up. look for the defrost timer on the print. that will also show where it is located with a part #. you can then price it out . It is not too hard to install be sure to unplug it before removing any wiring.
Good Luck, Bill
Whirlpool 25.6... | Answered on Jan 07, 2018
yes
just connect the lines in the fridge filter to each other
There are very good ceramic filters available for domestic water supply that can be fitted anywhere in the supply line to the fridge or any other tap for that matter
The ceramic filters had the added advantage that beside being the filter that removes the absolute finest particle, all you have to do is every few years is to scrape off the build up off the ceramic and they are good to be reused again
While the initial ceramic filter may be expensive, the fact that they can be scraped clean every few years makes them virtually a life time investment
Whirlpool 25.6... | Answered on Jan 04, 2018
This is common, take your model number and go to the appliance parts store and order a ice chute dispenser repair kit.
Whirlpool 25.6... | Answered on Jan 01, 2018
most likely you have a bad filter holder the part the filter connects to,next time send the model number off of the machine so whoever helps you can look up your model and send part numbers to you.
Whirlpool 25.6... | Answered on Dec 31, 2017
Probably the motor or solenoid was damaged.
Whirlpool 25.6... | Answered on Dec 09, 2017
easiest way to tell is pop off the white cover on the ice maker,you'll see letters on the ice maker,if you get a jumper wire and stick it into T and H the ice maker should start to spin,your jumping the motor out,if it doesn't the ice maker is bad,then put the jumper into the V and the L,this should fill the ice maker,you're sending power down to the valve by doing this,if you don't hear the valve buzzing or anything and no water comes right out to the ice maker the valve most likely is bad,if water doesn't fill the ice maker,you can fill it with water and after 2 hours it should produce ice in the bucket,if it does then you know it's the valve,if it doesn't drop ice the ice maker is bad.also if i were you i would change out the ice maker anyway even if the valve is bad,the mold in the ice maker usually rots out after 7 to 10 years,you'll see specks in the ice,you can look into the mold of the ice maker to see if it is bad,you'll see all the green liner peeling out and make sure you change out the water filter at least once a year,they want you to change it like every 6 months but depending on how much water you use most times you can get a year out of them.one more thing make sure there isn't any ice built up in the fill tube to the ice maker,if the valve is bad sometimes water will drip through and it will freeze up in the line,if so melt it out with hair dryer but by sticking the jumper into the V and L should let you know if it's frozen,water should come out when you jump it if it is the ice maker.these are the easiest ways to check it or just change out both parts.
Whirlpool 25.6... | Answered on Dec 03, 2017
Any frost buildup on inside back freezer wall?
Whirlpool 25.6... | Answered on Nov 07, 2017
You have one or more of your defrost components that are bad. Namely defrost heater, defrost thermostat, and defrost timer / board depending on model.
Whirlpool 25.6... | Answered on Nov 04, 2017
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
2,353 questions posted
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Refrigerators
Most Popular Question
whirlpool refrigerator side side ice
  • Refrigerators
